Adding an escape door to an Enclosed trailer #951075
03/15/11 11:02 AM
03/15/11 11:02 AM
NW PA
V10nacuda Offline OP
NW PA
Any of you guys done this????? Is there a kit to buy or just square tube, aluminum angle & hinges???
I don't want to buy a new trailer & alot of the ones I have looked at don't have an escape door.
Don't know if anyone else has shopped for used trailers but some people want alot of $$$ for 10 year old trailers..
Any input??
V10
Re: Adding an escape door to an Enclosed trailer [Re: V10nacuda] #951076
03/15/11 11:17 AM
03/15/11 11:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Call any trailer manufacturer they have all the parts
but it wont be cheap.... its no different than putting
in a window in a house
Re: Adding an escape door to an Enclosed trailer [Re: MR_P_BODY] #951077
03/15/11 11:38 AM
03/15/11 11:38 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My local trailor place refused...I want one in mine, but they won't put it in. Says its not framed for one...I also assumed you could put one in like a window in a house, what do I know.
Re: Adding an escape door to an Enclosed trailer [Re: Dragula] #951078
03/15/11 11:51 AM
03/15/11 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont know why they wouldnt frame it in... its just welding
Re: Adding an escape door to an Enclosed trailer [Re: Dragula] #951079
03/15/11 11:51 AM
03/15/11 11:51 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i got tired of asking and looked for just the hinges and would make the rest.i believe the factory in indiana said thay would do it for more than 1k$ i think thay wanted.
Re: Adding an escape door to an Enclosed trailer [Re: blownzoom440] #951080
03/15/11 12:50 PM
03/15/11 12:50 PM
oh
julian2007 Offline
julian2007  Offline
oh
Its easy,I put in all my windows in my 44 foot goose, 1 inch square tube works perfect.Build a frame and install a emergency exit window,pull two leavers and the whole window pops out.Some times you can find them used at camper dealers (warranty for small defects like dents and scrapes)I gave 25 bucks each for all mine,there out there you just have to hunt.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Adding an escape door to an Enclosed trailer [Re: julian2007] #951081
03/15/11 12:58 PM
03/15/11 12:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He is looking for an escape DOOR , one you open so you can open the door of the car to make it easier to climb out .
Re: Adding an escape door to an Enclosed trailer [Re: Dragula] #951082
03/15/11 01:04 PM
03/15/11 01:04 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Sometimes there are jobs that take way more effort than people imagine. Rather than quote what would sound like a ridiculous price they just give a reason for not doing it.
I've put a door in a trailer I owned. Yes, its like putting a window in a house - frame header, etc.. But you also need plates to run between the studs for both the hinges and the lock - the studs themselves have no strength. Its easily a full day job or more - particularly if you have to build the door. Personally, if I were doing it for someone they'd be into $1000. easily by the time it was done.
Re: Adding an escape door to an Enclosed trailer [Re: JohnRR] #951083
03/15/11 01:26 PM
03/15/11 01:26 PM
Guitar Jones Offline
Why not just install a winch so you won't have to open the door in the trailer?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Adding an escape door to an Enclosed trailer [Re: JohnRR] #951084
03/15/11 01:30 PM
03/15/11 01:30 PM
CANADA
Desmond Offline
Desmond  Offline
CANADA
Where can I get one for my life?
Re: Adding an escape door to an Enclosed trailer [Re: Desmond] #951085
03/15/11 01:38 PM
03/15/11 01:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
temporary ...
Re: Adding an escape door to an Enclosed trailer [Re: JohnRR] #951086
03/15/11 01:54 PM
03/15/11 01:54 PM
oh
julian2007 Offline
julian2007  Offline
oh
sorry must have miss read,But it is still the same just welding, get some tube and some .040 alum and make it.But for all the work a winch would be easier and cheaper.
Here are my windows anyway
Re: Adding an escape door to an Enclosed trailer [Re: V10nacuda] #951087
03/15/11 01:55 PM
03/15/11 01:55 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
I installed one in mine and it was easy. The 1x2" tubing was installed on 12" centers so the material i cut out for the opening i reused to picture frame the new door. Screwed it in with some sealer and was done. Approx (4) hours total.
Re: Adding an escape door to an Enclosed trailer [Re: julian2007] #951088
03/15/11 01:55 PM
03/15/11 01:55 PM
oh
julian2007 Offline
julian2007  Offline
oh
another
Re: Adding an escape door to an Enclosed trailer [Re: Dragula] #951089
03/15/11 02:45 PM
03/15/11 02:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Depending on the trailer, its construction, where the load is carried, and the location of the escape door to the axles and the hitch, I can see that piercing the solid outer skin might causing buckling issues even with a modest door frame. Furthermore fed regulations have been greatly increased lately on trailer designs on the engineering and testing the feds require (way overkill IMO). To have a company modify an existing trailer opens them to many legal liability issues, and not likely worth the potential hassle. Any company qualified to do it, likely won't, and any who will, might not be qualified. A good analogy is the fatigue structural failures on the liberty ships in WW2.
Re: Adding an escape door to an Enclosed trailer [Re: V10nacuda] #951090
03/15/11 03:09 PM
03/15/11 03:09 PM
NW PA
NW PA
I figured MR P would have done this before.. Didn't you build your own enclosed trailer???
I was thinking that I could cut out a 54" hole & keep it square & just re use the cut out to use as the actual door after adding structure. Take some square tube to connect all the cut uprights where the material was cut out.
The only thing I was concerned about was the hinges... would I have to connect 2-3 other up rights with square tube to support the hanging weight when the door is open??
Re: Adding an escape door to an Enclosed trailer [Re: V10nacuda] #951091
03/15/11 03:28 PM
03/15/11 03:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes I did..... you double up the hinge side with
studs(metal) header off the top... I used alum angle
as trim... have you ever put a door in a house...
same as a door or window... the main frames under the
floor is the load carrying ... at least it is on mine
Re: Adding an escape door to an Enclosed trailer [Re: MR_P_BODY] #951092
03/16/11 09:54 AM
03/16/11 09:54 AM
NW PA
NW PA
No I have never put in a door or window... When I work with wood it always gets messed up...Even when I cut twice & measure once.... At least with metal I can add on material... unlike wood.
THanks for the advice
V10
