WORLD PRODUCT BLOCK QUESTIONS #950970
03/15/11 02:29 AM
03/15/11 02:29 AM
Affton MO
Q
qwkmopardan Offline OP
Q
Affton MO
I just picked up world product Mopar RB wedge block today. What should i expect to do before assembling? I know Bore and Hone because it is roughed to 4.310 and my pistons are 4.375. Are the mains typicaly decent and the deck equal and near 10.720. What a pig.I had to use a hoist to put the bare block on a stand. Just wanting opinions from others that have allready traveled this path. Thanks, Dan
Re: WORLD PRODUCT BLOCK QUESTIONS [Re: qwkmopardan] #950971
03/15/11 02:41 AM
03/15/11 02:41 AM
K&Q va.
BIGBLOCK_KAT Offline
K&Q va.
I would look it over ensuring it was not damaged in shipment. Check your main studs...hopefully they have the arp logo if not I would inquire their origin. Did you get your block kit? Dowel pins, plugs etc. Then take it to your machinist of choice.
Re: WORLD PRODUCT BLOCK QUESTIONS [Re: qwkmopardan] #950972
03/15/11 03:23 AM
03/15/11 03:23 AM
AndyF Offline
AndyF  Offline
Check the fit on everything before getting too far into the assembly. You'll need tall roller lifters for example. The block will interfere with the rivits on Cometic heads. Jesel belt drive won't fit without some grinding, etc. The extra material that is in those blocks just gets in the way of a number of older aftermaket parts so you have to double check it all.
Re: WORLD PRODUCT BLOCK QUESTIONS [Re: BIGBLOCK_KAT] #950973
03/15/11 05:15 AM
03/15/11 05:15 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
be cautious... the nuts had the ARP logo but not the studs!!!!
Mopar Performance
Re: WORLD PRODUCT BLOCK QUESTIONS [Re: moparniac] #950974
03/15/11 08:55 AM
03/15/11 08:55 AM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
Starter clearance
Re: WORLD PRODUCT BLOCK QUESTIONS [Re: MuscleMike] #950975
03/15/11 02:49 PM
03/15/11 02:49 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Starter clearance
Yes, a full size chrysler starter won't clear, a MP mini starter works fine. Dave
Re: WORLD PRODUCT BLOCK QUESTIONS [Re: MuscleMike] #950976
03/15/11 03:42 PM
03/15/11 03:42 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Starter clearance
I cut the post down some on my starter and got it to fit!
Mopar Performance
Re: WORLD PRODUCT BLOCK QUESTIONS [Re: qwkmopardan] #950977
03/15/11 11:48 PM
03/15/11 11:48 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Talk with Dale or Mike at Chenoweth out of Morton IL. They have done several. I took my AL block there for the short block assembly. The Source fabricated timing cover won't work with a roller cam and button.
Damon
Re: WORLD PRODUCT BLOCK QUESTIONS [Re: mopardamo] #950978
03/15/11 11:59 PM
03/15/11 11:59 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I also had to ground the block/mounts to get my motor mounts to fit!
here is how far off the bolt hole alignment was....
Mopar Performance
Re: WORLD PRODUCT BLOCK QUESTIONS [Re: moparniac] #950979
03/16/11 03:10 AM
03/16/11 03:10 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My world hemi block was cracked in a pushrod hole and the upper water pump holes were filled with casting flash. I blended out the crack, just need to verify I got it all out. Tim
