Re: clacking sound from rear brakes?
[Re: 68bb]
#950836
03/14/11 10:21 PM
03/14/11 10:21 PM
RapidRobert
look at the pin on the top of the E brake lever, the pivot pin that goes into the shoe & is held in w a small horseshoe clip. OE there is supposed to be a very thin cupped washer between the horseshoe clip & the shoe to keep tension to elim some of that play. If it's excessive could add a thin one of any type that will fit
[Re: 68bb]
#950840
03/15/11 08:37 PM
03/15/11 08:37 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I'd also guess a missing or broken spring.
But do remember to put a LITTLE white grease (or hi-temp silicone grease) on the contact pads on sides of the shoes where they contact the backing plate. You'll see the shiny spot on the backing plate where the shoes rub when they wiggle.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#950841
03/15/11 09:19 PM
03/15/11 09:19 PM
Posts: 515 Bolingbrook, IL
HemiRunner
super street
super street
Bolingbrook, IL
Sounds like the wave washer as mentioned might be missing or broken. Also E-brake could be out of adj. Check to make sure the e-brake cables aren't frozen. Using two people, take one drum off at a time & while one watches the movement of the cable & actuating arm for free movement, the other will hold the brake release out, so the ratchet won't catch & slowly move the e-brake pedal up & down a slight bit. Don't go too crazy with the pedal movement as you can over extend the shoes & pop a wheel cylinder. Antiseize works best for lubing the shoe contact points & star wheel.
Blown & Injected, need I say more?
71 Road Runner
04 Dodge Ram 2500 4x4 CTD
