amd hood #950575
03/14/11 03:20 PM
03/14/11 03:20 PM
indiana
mopar mike Offline OP
indiana
anybody ran into there being no holes in the front of the hood for the hood to rad support seal? (amd) if so do you have any pics of how it is supposed to be mounted and the number of holes to drill. thanks moparts
Re: amd hood [Re: mopar mike] #950576
03/14/11 05:31 PM
03/14/11 05:31 PM
indiana
indiana
nobody has bought a shaker amd hood? and had this problem?
Re: amd hood [Re: mopar mike] #950577
03/14/11 07:37 PM
03/14/11 07:37 PM
washington
AB&E Offline
AB&E  Offline
washington
That sucks. they are all the same flat hood shaker hood bulge hood all the same location & holes. hope this helps I have all 3
Re: amd hood [Re: AB&E] #950578
03/15/11 07:34 AM
03/15/11 07:34 AM
indiana
indiana
do you have any pics with the seal installed? it has been 5 years since i started this project and i can't remember how it was on the hood. thanks
Re: amd hood [Re: mopar mike] #950579
03/15/11 03:01 PM
03/15/11 03:01 PM
washington
AB&E Offline
AB&E  Offline
washington
I have no pics. sorry
Re: amd hood [Re: mopar mike] #950580
03/15/11 03:56 PM
03/15/11 03:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I know this might not show much, but the rubber seals 90 degree edge w/push clips mounts along the first "rib", on the vertical surface, and follows the contour of the hood,....and yes, none of the AMD hoods are drilled for this seal
Re: amd hood [Re: DAYCLONA] #950581
03/15/11 04:20 PM
03/15/11 04:20 PM
indiana
indiana
thanks for the pic, but i need a closer look at where the seal attatches. it looks like from here those holes are on my hood. but there are holes all along the flap that does a 90 bend. can't tell if it goes on the front or the rear? thanks again all
Re: amd hood [Re: mopar mike] #950582
03/15/11 04:29 PM
03/15/11 04:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Tough to find a pic at that angle, maybe this helps
Re: amd hood [Re: DAYCLONA] #950583
03/15/11 04:35 PM
03/15/11 04:35 PM
indiana
indiana
great i beleive all those holes on the back side of the fron brace is what i am missing? thanks again, i am calling amd and see if they have had anybody else has come across this?
