Braided hose fittings #948414
03/11/11 11:33 AM
03/11/11 11:33 AM
bigfork mn
dragram440 Offline OP
bigfork mn
I have done them befor but these ones are giving me hell!! What do you use to keep the hose from fraying? What do you use to cut the hose?
67' charger 499 RB 10.57 at 127
Re: Braided hose fittings [Re: dragram440] #948415
03/11/11 11:54 AM
03/11/11 11:54 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Black tape cut in the middle
Re: Braided hose fittings [Re: poisondart2] #948416
03/11/11 11:55 AM
03/11/11 11:55 AM
bigfork mn
bigfork mn
I tried clear package tape on a chop saw and it just frayed to much to get the end on.
Re: Braided hose fittings [Re: dragram440] #948417
03/11/11 11:56 AM
03/11/11 11:56 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I wrap the hose with electrical or duct tape and use a cut off wheel{wiz wheel}.One of these days I will break down and get one of theses>>>>> http://www.summitracing.com/parts/SUM-900040/
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Braided hose fittings [Re: dragram440] #948418
03/11/11 12:11 PM
03/11/11 12:11 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
There's really only one way to do it right, and it doesn't require power tools, tape, cutoff wheels, sissors or saws. Good stuff, watch and learn something unusual.
It works great and doesn't make a mess! They have additional braided line assembly tutorials available too.
http://www.youtube.com/watch?v=u1J7u8sG118&feature=related
Re: Braided hose fittings [Re: jbc426] #948419
03/11/11 12:20 PM
03/11/11 12:20 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
When I used stainless braid [never will again] I wrapped it tightly in duct tape and cut with hacksaw. Rarely had a problem..
Re: Braided hose fittings [Re: dragram440] #948420
03/11/11 12:21 PM
03/11/11 12:21 PM
Greenville, SC
bad360rt Offline
bad360rt  Offline
Greenville, SC
Electrical tape and a cutoff wheel worked great for me. On the new setup I switched to Russell Pro Classic nylon braided, so much easier to work with!
Re: Braided hose fittings [Re: jbc426] #948421
03/11/11 12:26 PM
03/11/11 12:26 PM
bigfork mn
bigfork mn
That is unbelievable!! Looks like the only way to do it. Im going to try it now.
Re: Braided hose fittings [Re: dragram440] #948422
03/11/11 12:30 PM
03/11/11 12:30 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I use no tape what so ever ...
Mopar Performance
Re: Braided hose fittings [Re: dragram440] #948423
03/11/11 12:38 PM
03/11/11 12:38 PM
bigfork mn
bigfork mn
I didnt have the masonry chissel so I used a wood chissel right on the concrete floor chopped it right off clean!! Thanks for the help.
Re: Braided hose fittings [Re: dragram440] #948424
03/11/11 12:42 PM
03/11/11 12:42 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Kobalt hand cutters from lowes cuts right through also... ive used it up -8
Mopar Performance
Re: Braided hose fittings [Re: dragram440] #948425
03/11/11 01:08 PM
03/11/11 01:08 PM
London,Ontario,Canada
1962Savoy Offline
1962Savoy  Offline
I use a cut-off wheel and the braided hose is wraped in fiberglass reiforced tape.I also use a item called KOUL TOOL you get from Summit to insert the line into the fitting. Its a great tool and never had an ounce of trouble with it!
Re: Braided hose fittings [Re: dragram440] #948426
03/11/11 01:31 PM
03/11/11 01:31 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Keeping it CLEAN & CRISP is the main benefit of doing it this way. There is virtually no particle contamination introduced into the lines. The braid stays intact nicely, and the price of the tools is right too.
Re: Braided hose fittings [Re: dragram440] #948427
03/11/11 01:33 PM
03/11/11 01:33 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You're welcome....Often times a man's life in these parts depends upon a mere scrap of information.
