Re: 350 Chevy Engine in Hot Rods???
[Re: wannadrag]
#946436
03/09/11 09:07 PM
03/09/11 09:07 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You can always tell the uninformed response.
Anyway, The SBC got it's start in the 50's. It was much smaller than most of the V8's of the time, fit the early Fords most were hopping up better and outpowered the stock, or even hot Flathead Ford V8. Granted back in the day teh early Hemi was put into them, but they were expensive, much larger, harder to fit and way heavier. The SBC had a 10 year headstart on the LA engine and it's still smaller than an LA. Not to mention it's not that expensive to make power with the SBC.
Combine all that together and the SBC had a headstart no other engine has over come.
[Re: Supercuda]
#946437
03/09/11 10:08 PM
03/09/11 10:08 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
They ain't just in hotrods either. And if you thought it was bad with the gen I/II small blocks, the LS stuff is just as prominent now. And more importantly, they have the backing from just about every aftermarket company under the sun---can't really say that for mopar stuff. Plus what the above poster said, that I have to say was really thought out and written well.
Does it stink to see them in other makes? I guess that is your own take on it. To me, its old school hot rodding---to a certian extent. You cant stick your nose to high in the air and be ignorant, because i'll tell you in building engines chuck full of aftermarket parts that there is more crossbreeding on parts than you can even imagine. Its funny to look at a cylinder head or valve train and you can see almost whose original plans were taken.
I am doing a build on a guys 383 and he just about flipped when I mentioned I had to use spring retainers listed for a BB Chevy. Really!? The engine doesn't know and under the valve covers, neither will anyone else. Shoulda kept my mouth shut. But anyhow, back to the topic, a statement I always pose when someone cries about a SBC in another vehicle, what if that Ford, or Chevy had a 440 or Hemi in it---would you own it? Most still say no.
I can screw together an aluminum headed SBC 383 stroker for about $2500 including outside machine work If the right parts are bought. I don't think your going to do that with a Mopar small block sorry to say--ok, maybe with iron heads you could.
I have a 454 on the stand now that will have about $2500 for an iron headed/roller cam/ mild performance build. As a comparison, there is a 383 and a 440 on the stands also that have real mild performance build with hydralic flat tappets and I am at about $3000 ish on those---to do a roller cam was around around another $1000--maybe about $600-700 if you bought used stuff. Sorry to say, they chevy stuff is just so plentiful and just cheaper to do whether buying new or used.
Then as far as hotrods are concerned, you have to remember some of these older cars got a camaro front clips just making the SBC swap a natural for the simplicity in that situation. Its really up to the individual to do or redo what they feel is right, and sometimes, just sometimes, there is a really interesting story to go along with what was done----like the guy at our track that runes a 68 Nova with a 440 in it.
Make of it what you will, and I totally understand the whole mopar in a mopar thing, but in the end, to each thier own.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#946440
03/10/11 01:15 AM
03/10/11 01:15 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I feel the same way, hot rodding or not , the same old small block chevy in every rod gets a little old. It seems like some of those guy's would try to be a little different. Heck put in a slant 6, it would probably get more looks. As a matter of fact , there is a guy up in the west Michigan area that has a rat rod pick up with a turbo charged slant 6, people are all over it as it different.
[Re: Supercuda]
#946442
03/10/11 12:59 PM
03/10/11 12:59 PM
Posts: 1,392 Thayer, MO
bohmer2
Thayer, MO
This is a great explanation as to why it started. The big reason they are still so widely used is the aftermarket support they have received. Go to SEMA and see how many hundreds of times you will see more parts for a SBC than all other motors combined. Because there is such widespread support you can pick up anything you need for them cheap and you can pick up parts for them in any town US.
[Re: rowin4]
#946443
03/10/11 02:16 PM
03/10/11 02:16 PM
DaytonaTurbo
Manitoba, Canada
I feel the same way. The chevy 350 is so overdone I would rather see anything else under the hood of a hot rod. I do understand why, they are your best bang for your buck v8 out there with cheap and widely available performance parts from every manufacturer, everything you could want is produced for them. But that still does not make them any less boring or overdone.
[Re: DaytonaTurbo]
#946444
03/11/11 09:14 PM
03/11/11 09:14 PM
Supercuda
About to go away
About to go away
up yours
To be honest, if I were to build a rod right now I would be very hard pressed not to run an LS motor.
Heck, I am even thinking about putting one in the 65 Cuda, I have even measured things out to see if it's possible. Only oil pan issues are apparent.
Why? Simple, dollar for dollar nothing can beat it. Want an all aluminum V8? The LS can accommodate you for less than any MoPar engine. Wnat 500hp? Again, the LS is cheaper, 600hp? Same deal. More than that? you're on crack, lol.
I probably won't cause all my spares are Mopar stuff and I don't want to restock with another brand.
[Re: Supercuda]
#946445
03/11/11 10:17 PM
03/11/11 10:17 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Yeah they are used in everything and over used in my opinion. I don't care how much power they make or how "CHEAP" they are to build and buy parts for. they do not belong in a mopar I don't care if its a 30 plymouth or a 70 challenger, a mopar deserves a mopar in it. I have built many streetrod and I always use a mopar in a mopar. I have built 4 cars with chevys in them A 40 willys coupe with a small block A 41 willys coupe with a BB chevy a 37 chevy sedan with a SBC and a 34 chevy sedan with a SBC nothing wrong with those engines in those cars but they were for sale cars I built. anything I keep will be mopar powered. I don't care how cheap or easy a chevy is, I will never build a mopar with one in it like I said a mopar deserves a mopar in it, and that is just my opinion the way I look at it if you want to run a chevy engine just get some GM car and have fun, they make some nice cars too.. Ron...
[Re: Ply36]
#946449
03/13/11 11:03 AM
03/13/11 11:03 AM
Posts: 1,531 AZ
Mike P
AZ
I went to the small local cruise last night and ran into an old friend who had brought out his SBC powered T Bucket. The car is very well done with some interesting features which we talked about......basically we talked about everything about the car EXCEPT the engine/drive train.
Then we wandered over to my 57 Plymouth. As usual with the hood down my old Plaza gets a lot of comments about the body style, interior, 4 speed etc. When the hood goes up, inevitably the conversation always revolves around the Tri-Power first generation Hemi and people usually don’t seem to notice the rest of the car it’s in.
What I’m getting at I guess is that most custom builds will have certain areas where the builder will pace there emphasis. Just my opinion, but in case of most of SBC powered rods the drive train itself almost just an afterthought.
Don’t get me wrong I’m not anti SBC...... they’re good engines, but relatively speaking they are the easy way out, not very impressive visually and way over done.
And really which would you really rather have???
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
[Re: Mike P]
#946451
03/13/11 01:04 PM
03/13/11 01:04 PM
Supercuda
About to go away
About to go away
up yours
Oh I agree, but unless it's a Hemi a MoPar engine isn't all that visually different enough from a SBC or BBC to make it stand out. In fact it could be argued that the SBC has a lot more available to it in the aftermarket to make it stand out visually than a MoPar does.
Me, I am more of a form follows function kind of guy. I prefer the stealth look and want performance over pretty any day. By definition a street rod is more looks over performance and a hot rod is more performance over looks. So I guess it's all in what you want.
