More cam Thoughts #945950
03/08/11 12:31 AM
03/08/11 12:31 AM
N.E. Ohio
6bblFLASH Online content OP
6bblFLASH  Online Content OP
N.E. Ohio
Just benchracing a few thoughts with some freinds:
You have a motor with a ROOTS type supercharger making 375hp.on a dyno.
Cam is 108C/L and 68* overlap 284* duration.
Makes 6-lbs boost.
Swap cams to a 114 C/L 56* overlap 278/290 duration cam, same 6-lbs boost,,,,,,, How much power difference would you expect?????????
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: More cam Thoughts [Re: 6bblFLASH] #945951
03/08/11 10:38 AM
03/08/11 10:38 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
interesting thaught.in my case of changing LSA,dur. i also added lift so i cant realy say.just for fun i will say you gain 20hp and 2" vacuum. someone who knows what thay are talking about may say otherwise.i assume the cam is a solid flat tappit,same lift.
Re: More cam Thoughts [Re: blownzoom440] #945952
03/08/11 06:41 PM
03/08/11 06:41 PM
N.E. Ohio
N.E. Ohio
No they are both HYD.
Re: More cam Thoughts [Re: 6bblFLASH] #945953
03/08/11 07:11 PM
03/08/11 07:11 PM
ELYRIA,OH
ELYRIA,OH
can you provide more info on the build or is it a general q?
Re: More cam Thoughts [Re: blownzoom440] #945954
03/08/11 10:38 PM
03/08/11 10:38 PM
N.E. Ohio
N.E. Ohio
Just B.S.ing ideas and what if`s.
Re: More cam Thoughts [Re: 6bblFLASH] #945955
03/08/11 10:42 PM
03/08/11 10:42 PM
ELYRIA,OH
ELYRIA,OH
wish there was more interest on boost here. sorry i am not much help.what i learn i forget easy.
Re: More cam Thoughts [Re: 6bblFLASH] #945956
03/09/11 11:01 AM
03/09/11 11:01 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
What are the valve timing events of these cams?
Re: More cam Thoughts [Re: 6bblFLASH] #945957
03/09/11 12:40 PM
03/09/11 12:40 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
@6 lbs of boost I don't think you'd gain anything.
Re: More cam Thoughts [Re: goldmember] #945958
03/09/11 02:46 PM
03/09/11 02:46 PM
ELYRIA,OH
ELYRIA,OH
i think having low boost is the point with that cam having less overlap but a little long on exhdur unless it is full exh system.
Re: More cam Thoughts [Re: TheOtherDodge] #945959
03/09/11 09:18 PM
03/09/11 09:18 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
284/108 cam------open---------close
intake--------34*BTDC-------70*ABDC
exhaust-------70*BBDC-------34*ATDC
278/290/114 cam----------------------
intake--------25*BTDC-------73*ABDC
exhaust-------79*BBDC-------31*ATDC
IMO, even though theres 6# of boost involved, the extra 6* of intake duration of the 284 cam will make more power. Sure it has more overlap, but at this small cam size it might not be a bad thing.
The overlap period alows the scavenging effect to take place. With enough boost and overlap you may not want that. But , with this small of cam and boost, that small snap of scavenge on overlap maybe usefull.
Id take the 6# of boost @ 284* duration over the 6# of boost @ 278* duration. Im just guessing/bench racing here.
Re: More cam Thoughts [Re: Sport440] #945960
03/09/11 10:01 PM
03/09/11 10:01 PM
ELYRIA,OH
ELYRIA,OH
thanks for posting the cam #'s
in the past i went from a 110 to a 113 and gained boost signal and VE% maintaining close maxlift #'s in the .540 range solid ft.8lbs/under.
i am going to print the spec to be sure it is what i think.
4300S .525/.555, 288/296, 254/264, 110° bds cam
.541/.559 289/297 252/260 113 comp cam
in op a .050 13/cl 59
ex op 63/cl 17
Re: More cam Thoughts [Re: blownzoom440] #945961
03/10/11 12:35 PM
03/10/11 12:35 PM
Houston, Texas
Houston, Texas
That is a lot of overlap to be running with forced induction...
Re: More cam Thoughts [Re: TheOtherDodge] #945962
03/10/11 12:54 PM
03/10/11 12:54 PM
ELYRIA,OH
ELYRIA,OH
are you talking about mine,what 1?or the op cam?i dont mean to take over the post just showing results.
Re: More cam Thoughts [Re: blownzoom440] #945963
03/10/11 01:04 PM
03/10/11 01:04 PM
Houston, Texas
Houston, Texas
These cams:
Of course, one could get a better idea of the true affective overlap if we knew the cam timing events at .050 lift rather than at 0 lift (I am assuming that is at 0 lift)
Re: More cam Thoughts [Re: blownzoom440] #945964
03/10/11 01:07 PM
03/10/11 01:07 PM
Houston, Texas
Houston, Texas
"in op a .050 13/cl 59
ex op 63/cl 17 "
Even this cam (showing .050 numbers) has a lot of overlap for use on a forced induction cam.
Re: More cam Thoughts [Re: TheOtherDodge] #945965
03/10/11 01:22 PM
03/10/11 01:22 PM
ELYRIA,OH
ELYRIA,OH
a lot of missing info but 30/40* overlap would not be too bad.
Re: More cam Thoughts [Re: TheOtherDodge] #945966
03/10/11 02:50 PM
03/10/11 02:50 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Your right those events are from the advertised numbers. The .050 numbers for the 284 cam would be around 241* dur@ .050 if it were a MP cam. For easy math let me use 240*@ .050
those events would be
284/240@.050 cam----open--------close---
intake--------------12*BTDC------48*ABDC
exhaust-------------48*BBDC------12*ATDC
Witch gives 24* of overlap @ .050
Re: More cam Thoughts [Re: Sport440] #945967
03/10/11 05:37 PM
03/10/11 05:37 PM
ELYRIA,OH
ELYRIA,OH
so how would you devide/define these cams use?[factors on using 1 over another]
Re: More cam Thoughts [Re: blownzoom440] #945968
03/10/11 05:50 PM
03/10/11 05:50 PM
Houston, Texas
Houston, Texas
I don't know about defining them...
My new turbo cam will have a total of only 3 degrees overlap...
Re: More cam Thoughts [Re: TheOtherDodge] #945969
03/10/11 05:55 PM
03/10/11 05:55 PM
ELYRIA,OH
ELYRIA,OH
i was reading on dodgetrucks.org a few yrs ago on a lot of magnum engine w/boost running very little overlap.
