Re: Six Pack Gurus? [Re: jbc426] #945864
03/12/11 01:49 PM
03/12/11 01:49 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Actually, it was more like a leap with a quick spin and a triple-2-barrel blast.
Sorry, I got excited, just had coffee, and am going out to test some bigger jets I just installed in my....Holley's.
Good for you. Do you have real Holleys, or the Mopar versions (of the Ford STYLE) from the old catalogs that you mentioned earlier?
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Six Pack Gurus? [Re: B5 Bee] #945865
03/12/11 02:17 PM
03/12/11 02:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have a dual plane intake on my car (eddy) now and want to try a single plane. I'm running indy srs mildly ported, best time last year was [Email]6.87@98[/Email] 1/8th car weighs 3550 w me in it. Where do I get one for a six pack or whats the best way to build one?
There are three options that I'm aware of, Indy two piece with the six pak lid, custom made sheet metal intake and the last is the old Weiand Super Stock cast aluminum two piece semi tunnel ram six pak intakes.IHTHs
You're forgetting one Cab, the Eldebrock STR-14 with the six pack top.
Oops, your correct, my memory is horrible:o I have seen pictures of them but never owned or work on one of them Another option would be a tunnel ram with a homemade top like Sixpak Gut used lots of options when you wnat to make your own
Re: Six Pack Gurus? [Re: Cab_Burge] #945866
03/12/11 02:26 PM
03/12/11 02:26 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Your memory isn't horrible, Cab - we all skip a beat now and then.
Re: Six Pack Gurus? [Re: Cab_Burge] #945867
03/12/11 02:27 PM
03/12/11 02:27 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
And to get really off the wall, wasn't there an Offy or Weiand intake that used Rochester carbs? OOPS those would be GM style wouldn't they.
Re: Six Pack Gurus? [Re: GomangoCuda] #945868
03/12/11 07:19 PM
03/12/11 07:19 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Re: Six Pack Gurus? [Re: Cab_Burge] #945869
03/13/11 11:34 PM
03/13/11 11:34 PM
San Diego
Redsled Offline
Redsled  Offline
San Diego
I run a STR-14-6 with mechanical carbs. The motor is a .060 over 440 w/ Eddy heads, 10.7 cr, and a Comp hydraulic in a 66 Coronet. I bought the STR partly because I was told "It will never work". I didn't believe that. I'm knocking on the 10 second door w/ a best of 11.03 @ 119. I'm working on a weight loss program......
Re: Six Pack Gurus? [Re: Redsled] #945870
03/14/11 01:02 PM
03/14/11 01:02 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
Red Sled, you have a PM
I'd love to hear some details about the times run with the Weiand tunnel ram. I tried this unit, and had some trouble with a bog (using stock style 6-pack carbs). I ran it on a 3700 pound Road Runner with 4.30 gears, a 3800RPM converter, and a modified stock motor with a .575 Comp roller cam. It was modified per the Mopar Engine book. It ran great once it got over a bog between the idle and secondary metering systems. Have you guys had this same issue? Were your set-ups anywhere near the ones mentioned in the book? Tom
Re: Six Pack Gurus? [Re: Redsled] #945871
03/14/11 02:03 PM
03/14/11 02:03 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I always wonder when I see a car with a 6 barrel that has a slightly low MPH to the ET if it's running out of air/carburetion. A setup up like yours would be easy to swap to a 2X4 barrel top with a pair of 600's for a good comparison. I'm not saying anything is wrong with your combo - it runs real hard - just curious about if it could use a little more air.
Re: Six Pack Gurus? [Re: Evil Spirit] #945872
03/14/11 04:30 PM
03/14/11 04:30 PM
San Diego
Redsled Offline
Redsled  Offline
San Diego
No, it was fuel. The air was a little better than I thought it was, as I found out later. I should have fattened it 2 jet sizes. I ran an hour later, w/no changes and ran 11.09 @ 120.4. The DA had went up 400 feet. I just keep chipping away at it and also have a good time.
Re: Six Pack Gurus? [Re: Evil Spirit] #945873
03/14/11 04:46 PM
03/14/11 04:46 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
its not the carbs, its the intakes. and IMO, i personally dont see me gaining much if anything on my combo if i bolted on a dominator
Re: Six Pack Gurus? [Re: Tommy D] #945874
03/14/11 04:47 PM
03/14/11 04:47 PM
San Diego
Redsled Offline
Redsled  Offline
San Diego
The PM didn't come through.
I had the bog issue when I ran the stock intake and carbs. I put put metering blocks in the outboard carbs so I could jet them, and put a bigger pump squirter in the center carb. A #35 squirter, #88 jets in both outboards w/ purple springs #68 jets in the center carb worked for my combo.
Re: Six Pack Gurus? [Re: sixpackgut] #945875
03/14/11 04:57 PM
03/14/11 04:57 PM
San Diego
Redsled Offline
Redsled  Offline
San Diego
Sixpackgut, I agree with you on that......I could run 1 4bbl. and maybe go a little quicker and faster, but I don't want to be like everybody else!
Re: Six Pack Gurus? [Re: sixpackgut] #945876
03/14/11 11:08 PM
03/14/11 11:08 PM
northeast texas
strokin73cuda Offline OP
northeast texas
I don,t think I have any problem with my carbs either, I ran at thunder road this sat first full quarter passes on my car with 4.56s and 28.5 effective ht on my wore out 325 -50 15 mickey thompson radials in 4 passes I could never get it to hook but ran 99+mph on every pass at the 660' and 121+mph every pass at the 1220' my et suffered from the spinning with a best 1.67 60' 10.93 et ,my 60' is usually low 1.50s The problem lies with my intake being a (dual plane) stock style-stock port window-mill with runners as crooked as polititions are famous for being. I have no "six boggers" on my ride very much Thanks to Mr. Cab and Mr. Ray (sixpackgut) helping me learn to tune it, although I can,t see a big difference in my holley 2 bbls and holley 4 bbls wich use the same parts. I would be willing anyday to let anyone switch it to a 4-bbl settup with a similar intake as mine and see if it will pick-up any et and I would be willing to bet they will be dissapointed with the results. I would simply like to try the best for the buck single plane intake under my very reliable six pack.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: Six Pack Gurus? [Re: strokin73cuda] #945877
03/15/11 01:00 AM
03/15/11 01:00 AM
My pump gas 518 with the Eddy low deck dual plane six pak intake with a set of 1970 440 vacume carbs modified by C&J engr. has gone as quick as 10:34 at 128.6 MPH running out of fuel from the hit of the throotle to the finish line according to the LM1 wide ban I put on it. That is with me in it at 3450 Lbs and with the air cleaner and mufflers on it I fixed the fuel delivery issue and then broke a roller lifter before getting the AFR perfect I loves six paks carbs systems BB Mopars love all the air you can feed them
Re: Six Pack Gurus? [Re: Cab_Burge] #945878
03/17/11 08:50 AM
03/17/11 08:50 AM
Tommy D Offline
Tommy D  Offline
Cab,
You might benefit from running the larger center carb. I purchased a 500CFM Holley Carb with the full round air cleaner horn on top. We installed the six pack carb throttle arm and milled the air cleaner bell to the same size as our 6-pack carbs. It definately shoots more fuel.
Before trying it myself, I borrowed a friend's set up. My car picked up two tenths with just this mod. Tom
