Page 3 of 3 1 2 3
Re: Fan to radiator location what is optimal? [Re: MidPenMopar] #945802
03/09/11 06:01 PM
03/09/11 06:01 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
i would agree with alot of others, fan is too close and use a 7 blade one, hope the you you got works, I heard he only wants $659.99, thats a deal
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Fan to radiator location what is optimal? [Re: deansrr] #945803
03/09/11 06:22 PM
03/09/11 06:22 PM
NJ
rth Offline
rth  Offline
NJ
another thing is proper coolant mixture.it should be 50/50.a high concentrate of coolant will cause high temp.i have used flex fans and shrouds since forever and never had a problem with 440's stock or not,auto or 4spd.a good rad and proper fan spacing is all that's needed.
Re: Fan to radiator location what is optimal? [Re: rth] #945804
03/09/11 10:12 PM
03/09/11 10:12 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I use more of 75% distilled H20 and 25% antifreeze with a bottle of Redline water wetter as well.
Re: Fan to radiator location what is optimal? [Re: rhad] #945805
03/09/11 10:27 PM
03/09/11 10:27 PM
Huber Heights Ohio
greenpigs Offline
greenpigs  Offline
Huber Heights Ohio
What PSI radiator cap are you using? The higher the better according to Mopar Action. 16 is normal but E booger says 20 is fine if everything works well. It raises the boiling point of the coolant if I remember right.
69 Charger RT
Re: Fan to radiator location what is optimal? [Re: greenpigs] #945806
03/09/11 10:48 PM
03/09/11 10:48 PM
Got one of those caps with the temp guage built right in it made by Mr. Gasket. I thinks it's a 16 or better.
Re: Fan to radiator location what is optimal? [Re: MidPenMopar] #945807
03/10/11 12:04 AM
03/10/11 12:04 AM
ahhhh didn't know that (if no shroud) that the fan should not b kissing the rad that this can cause turbulence (Thanks Yancy) & reduce flow
Re: Fan to radiator location what is optimal? [Re: RapidRobert] #945808
03/12/11 07:17 PM
03/12/11 07:17 PM
Ok got the clutch fan installed in place of the fixed fan. I did not have the correct factory bolts so i just used some hardware store bolts to attach the fan to the water pump housing.
Is that sufficant or does it require a hardened bolt??
Re: Fan to radiator location what is optimal? [Re: MidPenMopar] #945809
03/12/11 07:20 PM
03/12/11 07:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Grade 8 I'm pretty sure. Nope I just looked Grade 5 5/16-18 X .75" long.
Re: Fan to radiator location what is optimal? [Re: Challenger 1] #945810
03/12/11 07:23 PM
03/12/11 07:23 PM
I made it to grade 12 myself but what does that have to do with the fan bolts??
Re: Fan to radiator location what is optimal? [Re: MidPenMopar] #945811
03/12/11 07:32 PM
03/12/11 07:32 PM
Is that sufficant
It's sufficant
Re: Fan to radiator location what is optimal? [Re: Challenger 1] #945812
03/12/11 07:37 PM
03/12/11 07:37 PM
I noticed mine needed 1.25 inch long bolts. The ones that came with it are .3/4 inch though. The P.O. had to put in some spacers to get the pullys to all line up for some reason that i don't understand.
Re: Fan to radiator location what is optimal? [Re: Challenger 1] #945813
03/13/11 02:39 AM
03/13/11 02:39 AM
Well my old Mr. Murphy was with me today. I got the clutch fan installed and all looked good but on a trial run the fan blades hit the top of the radiator and cut into the upper tank.
I looked but there no way to move the fan back any further so if the radiator is not messed up bad enough to need replacing (too dark to tell now) i guess the only thing i can do is redrill the radiator mounting holes and raise it say 3/8's or so maybe??
Re: Fan to radiator location what is optimal? [Re: MidPenMopar] #945814
03/13/11 09:46 AM
03/13/11 09:46 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
dang Stu! sorry to hear about your luck! how close was the fan to the radiator before you drove it?
if you're getting a lot of movement, how are your motor mounts/Trans mount? are they letting your engine move around to much when you put load on it from driving?
**Photobucket sucks**
Re: Fan to radiator location what is optimal? [Re: 70Cuda383] #945815
03/13/11 11:19 AM
03/13/11 11:19 AM
You know i found i have to have the main fan pully shimmed out about 3/8" to make the other pullys line up and that's exactly how much the fan is hitting the radiator of course. The flex fan i was using did not have that problem though so i never got into why it all is like this?
Re: Fan to radiator location what is optimal? [Re: MidPenMopar] #945816
03/13/11 02:23 PM
03/13/11 02:23 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Airflow is the problem here, but an (overly) advanced camshaft can cause hot(ter) idling aswell
Was the cam degreed properly in your motor?
Re: Fan to radiator location what is optimal? [Re: BigBlockMopar] #945817
03/13/11 02:35 PM
03/13/11 02:35 PM
No idea at all as it was in there when i bought the car over 10 years ago. All i know is it is way too much duration for a mostly stoch engine.
Ok so i got the radiator out and i think i will look for a new one now anyway.
Re: Fan to radiator location what is optimal? [Re: MidPenMopar] #945818
03/13/11 03:30 PM
03/13/11 03:30 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Take your time and get it figured out. I got advice and help from jbc426. My 26" was recored to a 4 row and we got enough clearance. The factory thermal fan works great. Fresh coolant and 180 superstat. The extra row could increase how close it is.
Re: Fan to radiator location what is optimal? [Re: DennisH ] #945819
03/13/11 04:30 PM
03/13/11 04:30 PM
Well i have it all apart now and going to try and replace as much stuff as i can while the engine bay is open.
I hope to find a direct fit radiator that has increased cooling as wel as no extra width if that is possible??
Page 3 of 3 1 2 3
