Re: NGK Plugs ?
[Re: Thumperdart]
#944419
03/08/11 08:49 PM
03/08/11 08:49 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Just to reiterate. I wasn't thinking that I was going to find some "magic bullet" in new plugs. I just wanted to know what plugs people would suggest and what heat range.
Again if people have suggestions or a way to make an educated guess. I would be interested.
Mike
1969 Dodge Dart Swinger
Re: NGK Plugs ?
[Re: BradH]
#944421
03/08/11 09:50 PM
03/08/11 09:50 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Personally i`ve dyno`ed several different types of plugs. Look in my trailer, garage, and in my car. AUTOLITES
I forgot the exact number I picked up, but after I dyno`ed a second engine and got the same results, I never looked back....
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
Re: NGK Plugs ?
[Re: dusturbd340W5]
#944422
03/08/11 10:03 PM
03/08/11 10:03 PM
Posts: 1,200 UK
602heavy
UK
then I would say go climb back under the rock.
You're the 2nd one to say that , just gotta go find that rock.
Looks like i'm goin with the flow & gonna start using autolites , guess the BS does'nt wash on here , interesting thread.
Re: NGK Plugs ?
[Re: 602heavy]
#944423
03/08/11 10:15 PM
03/08/11 10:15 PM
Posts: 25,963 United Socialist States of Ame...
tboomer
Guys..How much does it cost to chsnge plugs? If you can pick it up a bit for not much money spent,isn't worth it? Jeff comes on here and gives some tech...And a lot of people cry B.S!!! How many of you guys gave seen his work? I think don't knock it till tou try it...
Re: NGK Plugs ?
[Re: 602heavy]
#944424
03/08/11 10:33 PM
03/08/11 10:33 PM
Posts: 2,177 ill
dennismopar73
ill
just so everyone knows , i have run autolites, alot!! i have run ngk alot!! on gas as well as alcohol having said that, 1 plug will not outperform the other , , in my case and in the cars i have run. as for the o p in this , if he is running pump gas 89-92 oct- 8-9 range plug (med ) of any varity will work just fine in street application/ strip good coil, cap/rotor, wires are a wise investment ! the right size carb, adjusted correctly, properly tuned , and timed will leed to alot of enjoyment at the track and on the road,
Re: NGK Plugs ?
[Re: r69cuda]
#944426
03/10/11 07:17 PM
03/10/11 07:17 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I have a question that I hope maybe some of you can help me with. On a Wedge engine with 572-13 heads a true 15.2-1 CR using the Champion C59CX plug is there any need to index the plugs? I have been told it is a waste of time,but I will do it if it helps. In the past I have never seen in results one way or the other at the track. Also what number Autolite plug would I need to use? I run alcohol if that matters. Indy says use Champion but I will try a set of Autolites. PS Great post, I am always eager to learn more Speed Secrets!!!!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: NGK Plugs ?
[Re: r69cuda]
#944429
03/10/11 07:52 PM
03/10/11 07:52 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
you looked at average power? not just peaks?
not telling people this is the way to do it,, but when i dyno something say from 6300-9100,, my hemi stuff i average from 6500-7500 7000-8000 7500-8500 and 8000-9000 then look at those 4 numbers to compare pulls,, i can throw out the bottom number now,, but still start at 6300,, though convertors are above 7000
