Page 1 of 6 1 2 3 4 5 6
NGK Plugs ? #944319
03/06/11 07:05 PM
03/06/11 07:05 PM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
What part # or heat range NGK would work best in a .030" 440 with Indy EZ heads, FT pistons, compressions at 11.1, Resistor or non-Resistor.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: NGK Plugs ? [Re: joedust451] #944320
03/06/11 07:09 PM
03/06/11 07:09 PM
-7 or-8 on the last( ) number depending on the fuel and the tune up I like the extended tips plugs also I can go look at the numbers on the plugs if you need them
Re: NGK Plugs ? [Re: joedust451] #944321
03/06/11 07:09 PM
03/06/11 07:09 PM
5672A-9
Re: NGK Plugs ? [Re: joedust451] #944322
03/06/11 07:15 PM
03/06/11 07:15 PM
detroit area
moderncylinder Offline
detroit area
autolite ar3922 or if a little bit colder ar3911
autolite plugs make about 5-10 hp more than ngk plugs all the time,, thought the ngk are easier to read
Re: NGK Plugs ? [Re: moderncylinder] #944323
03/06/11 07:17 PM
03/06/11 07:17 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Will those work with Eddy heads also? (not trying to jack your thread, just asking...)
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: NGK Plugs ? [Re: MoparJunkie] #944324
03/06/11 07:20 PM
03/06/11 07:20 PM
I have used both the AR3911 and AR3910 plugs in my Eddy headed motors,on the street and at the strip, works good, last a long time
Re: NGK Plugs ? #944325
03/06/11 07:30 PM
03/06/11 07:30 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
R5671A-8 (4224) is non-projected tip (right) $3.99/ea
R5672A-8 (7173) is a projected tip (left) $1.99/ ea
joe, is this a project for the dart ?
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: NGK Plugs ? [Re: clovis] #944326
03/06/11 07:35 PM
03/06/11 07:35 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
What Dart
No, just helping out a friend
I'm sure the Projected tip would work better for NA.
Hey Chris, Have you fixed the Duster yet??
Re: NGK Plugs ? [Re: joedust451] #944327
03/06/11 07:58 PM
03/06/11 07:58 PM
SoCal
Brian Hafliger Offline
SoCal
Stock # 7173 for the track (-8) or a BCP7ES for the street. The 8 plug will load up and foul after a while on the street. If the 7 does too, drop down to the BCP6ES...
Brian Hafliger
IMM Engines
Brian Hafliger
Re: NGK Plugs ? [Re: Brian Hafliger] #944328
03/06/11 08:03 PM
03/06/11 08:03 PM
UK
602heavy Offline
602heavy  Offline
UK
Stay away from the projected style plug , NGK-6 will be fine on the street & track , will be difficult to read if any colder.
Re: NGK Plugs ? [Re: 602heavy] #944329
03/06/11 08:16 PM
03/06/11 08:16 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
joe, its coming together. I am hoping to get the block, crank and rods from the machine shop this week. The converter is here, heads are almost done and the dana is going in this weekend. if all goes well should have it to the track by mid April.
'75 Plymouth Duster
Re: NGK Plugs ? [Re: 602heavy] #944330
03/06/11 08:28 PM
03/06/11 08:28 PM
The lower the number the hotter the plug 10 being the coldest 6 being the hottest.
Re: NGK Plugs ? [Re: 602heavy] #944331
03/06/11 08:37 PM
03/06/11 08:37 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
what is wrong with a projected tip?? sorry just wondering. thanks mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: NGK Plugs ? [Re: clovis] #944332
03/06/11 08:54 PM
03/06/11 08:54 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Cool, so are you getting rid of the 906s?
Re: NGK Plugs ? #944333
03/06/11 09:34 PM
03/06/11 09:34 PM
UK
602heavy Offline
602heavy  Offline
UK
-5 being the hottest , to cold a plug will load up , used -6 with no problem on an 11.5:1 street motor , 7s are ok but a tad cold when 'cruising' around , the projected type plug will get too hot due to the ground strap being deep into the combustion chamber , ok for a stock type motor running low compression , the projected type plug will glow like an ember when running high compression street motors.
Re: NGK Plugs ? [Re: moderncylinder] #944334
03/06/11 09:38 PM
03/06/11 09:38 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Now theres good tech right there! I think I'll give that a try in the spring. Thanks Jeff.
Re: NGK Plugs ? [Re: moderncylinder] #944335
03/06/11 09:43 PM
03/06/11 09:43 PM
UK
602heavy Offline
602heavy  Offline
UK
wow...
Re: NGK Plugs ? [Re: moderncylinder] #944336
03/06/11 09:48 PM
03/06/11 09:48 PM
SoCal
SoCal
I will try them in the BB TR deal we'll dyno in a week or so.
Brian Hafliger
Re: NGK Plugs ? [Re: Brian Hafliger] #944337
03/06/11 10:05 PM
03/06/11 10:05 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Please do Brian, curious to know, post results
Re: NGK Plugs ? [Re: joedust451] #944338
03/06/11 10:15 PM
03/06/11 10:15 PM
ill
dennismopar73 Offline
ill
there no truth to that statement
