starter/ing switch info
#943650
03/05/11 07:54 PM
03/05/11 07:54 PM
Posts: 583 Raleigh, NC
rockerbob
Raleigh, NC
My ing/starter switch has been giving me trouble so I decided to install an overhead switch panel in the bracket car. Have everything but the ing & starter button hooked up. On my stock start switch there are 6 wires. red to battery black to acc. brown to ing 2 yellow to st blue solid to ing 1 blue w/white stripe to ing 1 also The starter button on the console has 2 lugs & the toggle switch has 2 lugs. I'm not too good at this stuff. Can anyone tell me were the wires hook to. Thanks
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
1969 Satellite 318 "bracket racer"
1966 Barracuda (in progress )
1964 Dodge 330 (future race project)
1962 Belvedere (HUM????)
Re: starter/ing switch info
[Re: rockerbob]
#943651
03/05/11 07:55 PM
03/05/11 07:55 PM
rockerbob
Raleigh, NC
Oh by the way its a 69 Satellite. Here is a pic of the harness conector.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
[Re: rockerbob]
#943652
03/05/11 09:20 PM
03/05/11 09:20 PM
RapidRobert
(1) on/off ign sw, connect red to one terminal and the blue and blue w tracer to the other terminal. (2) The momentary contact start sw connect red to one terminal and yellow to the other terminal. This'll duplicate OE ex you wont have the brown (ign2) ballast bypass because if you connect the brown and yellow together on one end of the starter sw it'll let current (after you start it) feed back from the downstream (brown wire) side of the ballast to the starter solenoid because they are connected on that end of the new sw whereas on the OE ign sw they are seperate terminals.
