Re: Looking for info/pics on Challenger Elastomeric bumpers
[Re: TinCuda]
#94315
10/13/11 04:06 PM
10/13/11 04:06 PM
Posts: 297 Oklahoma
TinCuda
Oklahoma
Here is the slotted rear bolt and hole.
(O O {]{]{]||[}[}[} O O)
1971 Plymouth 'Cuda 440-6
{||O||}
2000 Yamaha V-Max
(O O [========= SRT] O O)
2011 Dodge Challenger SRT 392
Making as big as a carbon footprint as I can!!!
[Re: HPMike]
#94322
10/15/11 03:18 AM
10/15/11 03:18 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Those bumpers look killer on those cars. I wish mine was optioned with them, but they likely weren't offered on GK6 cars.
MB
"dealer installed" .......I'm sure that was possible ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: YYZ]
#94324
10/15/11 12:56 PM
10/15/11 12:56 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
MB
The FJ6 V-code car pictured is in fact GK6 originally - a prior owner misread the paint code (and didn't clue in to the bronze paint elsewhere on the car....)
So....I wonder what colors it was/was not offered on?
[Re: HPMike]
#94325
10/15/11 01:27 PM
10/15/11 01:27 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
[quoteSo....I wonder what colors it was/was not offered on?
Here's what the dealer coding guide, dated as: Revised: July 6, 1970, says:
Optional on JS23-Challenger R/T only
H71 Coloured Front Bumper (Available with FJ6, GY3, GB2, EV2, FE5, FC7)
H72 Coloured Rear Bumper (Same colors as above)
NOTE: H72 has a footnote which reads: Only GY3 and EV2 are available on cars built thru August.
The info I just posted above was very early info, 7/70, and could very well have been revised again at a later date. There is no info. listed at this date which states that the bumpers must be ordered together as a pkg.
[Re: Morty426]
#94329
10/15/11 06:19 PM
10/15/11 06:19 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
My Challenger as of 6 weeks ago
Chris, The car looks AWESOME! Is that an elephant body I see?
Ray
[Re: rayztoy]
#94332
10/15/11 06:51 PM
10/15/11 06:51 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Ray
Thanks Ray - the car is a 440 SIXPACK exported to Canada
[Re: Morty426]
#94333
10/15/11 11:04 PM
10/15/11 11:04 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
Hello, I don't have all my notes in front of me, but here's some info off the top of my head...
challenger elastomeric bumpers are 71 only, and came as a package with both front and rear bumpers, and also painted side mirrors instead of chrome. You couldn't order the front/rear bumpers seperately. The top of the front bumper was always blacked out even on non R/T cars, and the grill blackout also came with the elastomeric bumper package. The hood moulding and corresponding edges of the headlight bezels also have a portion blacked out as part of the grill blackout process. If I recall correctly the hood moulding blackout was a thin vinyl strip, not paint. I've seen that strip available repro somewhere, but don't remember where at the moment. I also don't recall if the rear had any blackout like the front does. The bumpers were created from regular bumper cores with the studs in place, and then dipped in the coating. Special bumper brackets were used, but the only differance is that the brackets were slotted where they bolt on to the frame rails so that the bumper could be better adjusted in or out from the car. You could slot the holes in your original brackets, but I've heard others have installed these bumpers without needing that modification, so maybe you'll get lucky there.
That should help you out a bit.
Anyone have any good pictures? Especially of the rear would be nice.
Tav
Tav - since you got most of this wrong let me bail you out ![](/ubbthreads/images/graemlins/biggrin.gif)
True this is a 71 only option.
Unlike 'cudas Challenger rubber bumpers are NOT part of a package. In the beginning you could only order both (M73) and only in 4 colors: blue, purple, orange and yellow. Later you could order the front seperate.
The bumper is always black on top and forced you to get a black grill. The rear is also black on top.
The hood trim is painted and has the vinyl to cover the paint line.
The brackets are NOT different as Challenger metal bumper were recessed into the fender - the different bracket is a cuda thing.
I can get you detail pics upon request.
Morty
Based on this information, has anyone seen an actual non R/T 71 Challenger with a front or front and rear rubber bumpers. ALL the ones I have ever seen have been R/T cars, and hense all hardtops. If there is one or more out these, fender tag info and pictures would be great!! Thank you.
