Victor 440 and Cuda #942839
03/04/11 06:24 PM
03/04/11 06:24 PM
Queensland,Australia
T-bar Offline OP
T-bar  Offline OP
Will a Victor 440 on rb fit under a twin snorkel type 70+ cuda hood without cutting any brace's off and run an air cleaner.
Re: Victor 440 and Cuda [Re: T-bar] #942840
03/04/11 09:03 PM
03/04/11 09:03 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I really don't think so,
When I ran the 440 in my Challenger the carb stuck up just a little into the 6 pack scoop with the flat hood cut out,and a Victor intake.I ran a R/T hood before I had the Victor intake and I know it would not have fit that.
Re: Victor 440 and Cuda [Re: Dunnuck Racing] #942841
03/04/11 09:34 PM
03/04/11 09:34 PM
T-bar Offline OP
T-bar  Offline OP
Thanks for the reply, there is a bloke in town with a challenger and a victor and he cut out some bracing he also runs a 1 1/2"cleaner with an k&n extreme top and is real close to hitting, but i thought the profile of the hoods may be a little different?
Re: Victor 440 and Cuda [Re: T-bar] #942842
03/04/11 10:01 PM
03/04/11 10:01 PM
Northern Indiana
Northern Indiana
I guess the profile could be a little different,not real sure.I would bet the advantage of a real tall single plane intake would be sacrificed with a short restrictive air cleaner though,the extreme top might help that a little.
Re: Victor 440 and Cuda [Re: Dunnuck Racing] #942843
03/04/11 10:14 PM
03/04/11 10:14 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I have both...and the victor wont fit under the RT challenger hood with a carb and aircleaner.
It appears that it will fit with a thinner fuel injection throttle body that I have...it is only 2-1/8" thick and a drop base air cleaner...but it will be close with no cutting and an RT style "AAR fiberglass" hood.
Re: Victor 440 and Cuda [Re: T-bar] #942844
03/05/11 04:12 PM
03/05/11 04:12 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Heres a Victor intake/Victor head combo in a challenger. I believe the k member is spaced . Maybe Bigsqueeze will chime in. http://www.smotherssupercars.com/m73challenger.html
