Trans cooler??? #941997
03/03/11 04:53 PM
03/03/11 04:53 PM
Overpriced Housing Central
RobX4406 Offline OP
RobX4406  Offline OP
Anyone use this style cooler?
Seen a couple of cars with this style cooler mounted below the car behind the front wheel off a subframe connector.
I really don't want to plumb the lines to the front of the car if these coolers work well.
Wondered how they worked from an efficiency standpoint for a lightly street driven car?
Re: Trans cooler??? [Re: RobX4406] #941998
03/03/11 09:27 PM
03/03/11 09:27 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Personally I would want something more substantial.
Re: Trans cooler??? [Re: WILD BILL] #941999
03/03/11 09:51 PM
03/03/11 09:51 PM
They are better than nothing but not great.If that answers your question.
I like the radiator front mounted units with 3/8" inlet and outlet with -6AN lines going up to the cooler.
Re: Trans cooler??? [Re: RobX4406] #942000
03/03/11 10:06 PM
03/03/11 10:06 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
Go to emeraldcoastdragway.com that is like the supercooler that there bracket 1 champ uses. But it went in back by the wing. They mite have an ad.
Section 8 Racing We are nuts about racing.
Re: Trans cooler??? [Re: RobX4406] #942001
03/03/11 10:23 PM
03/03/11 10:23 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Try and find a deep pan with the front to rear cooling tubes built into the bottom of the pan. Try to get as much heat as possible out directly at the source.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Trans cooler??? [Re: GO_Fish] #942002
03/03/11 10:31 PM
03/03/11 10:31 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I had one on my Arrow....ditched it for a B&M Supercooler....MUCH better and I really like having a fan on there back by the rearend.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Trans cooler??? [Re: GO_Fish] #942003
03/03/11 10:32 PM
03/03/11 10:32 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
A friend of mine with a big block chevy/powerglide has run one for years with no trans. problems, he's pushing 900 + hp. He does also runs a remote trans. filter. the cooler is mounted under the car next to the trans.filter on the firewall.
Re: Trans cooler??? [Re: RobX4406] #942004
03/03/11 10:53 PM
03/03/11 10:53 PM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
Rob, I don't use that one, but I do use that style. I have it mounted near where the bottom of the rear seat would be (under the car, near the rear axle), on the vertical bulk head. #5 stratoflex line running to and from it. Been on my car for many years, last 3 years close to 1,000 passes total. The transmission (727) has not been apart in 3 years. I foot brake this car, leaving at 3000 RPMs, sometimes on the convertor for over 10 sec @3000 when I spot the slower vehicles in the 1/4 mile Sportsman class.
So far, I've not had a problem.
Brian Dunnigan
Re: Trans cooler??? [Re: Eric] #942005
03/03/11 11:22 PM
03/03/11 11:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a super cooler also.... no problems... they have
alot of surface area for cooling plus a big inlet and
outlet so no restriction in the cooler... I'm going
to put one on my trans AND my engine oil for my new car
