? DIAPER OPINIONS WANTED #941533
03/02/11 07:52 PM
03/02/11 07:52 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
here is a couple of pics of my diaper.
lookin for some opinions, good or bad.
not sfi
not made of balistic material
not fire proof
will melt if touching header
but will hold oil till you can get off the track
offer solutions if necessary
before
Re: ? DIAPERO PINIONS WANTED [Re: QWK_ENUF] #941534
03/02/11 07:53 PM
03/02/11 07:53 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
after
WAXER
Re: ? DIAPERO PINIONS WANTED [Re: QWK_ENUF] #941535
03/02/11 07:56 PM
03/02/11 07:56 PM
tboomer Offline
tboomer  Offline
Looks good,Tommy...What about us guys that use a static pickup?
Re: ? DIAPERO PINIONS WANTED [Re: QWK_ENUF] #941536
03/02/11 07:57 PM
03/02/11 07:57 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
That looks really nice!
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: ? DIAPERO PINIONS WANTED [Re: DragDart360] #941537
03/02/11 08:02 PM
03/02/11 08:02 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
both moparpitbull and myself use external oiling and motor plates
i have a rack and moparpitbull has stock rear steering
WAXER
Re: ? DIAPERO PINIONS WANTED [Re: QWK_ENUF] #941538
03/02/11 08:18 PM
03/02/11 08:18 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
LOOKS GOOD.FITS LIKE A GLOVE.
Re: ? DIAPER OPINIONS WANTED [Re: QWK_ENUF] #941539
03/02/11 08:20 PM
03/02/11 08:20 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
so what is it made out of,denim,canvis awning,shower curtain.[being a wise guy]
if it is not balistic what is the point if it wont hold oil?
i guess i just dont understand what good it is.i am not trying to be a jerk here.
Re: ? DIAPER OPINIONS WANTED [Re: blownzoom440] #941540
03/02/11 08:48 PM
03/02/11 08:48 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
it is 2 layers of treated duck cloth.tuff like denim.
inner liner is same as material on an ironing board
i guess it is an attempt to keep as much oil as possible off the track. i suppose indy thinks it is better to have something than nothing. i would say it would hold most of the oil if a rod popped. most bigblocks i've seen go, due to the extended sides of the block extending below the crank centerline, do a pretty good job of containing the parts.
WAXER
Re: ? DIAPER OPINIONS WANTED [Re: QWK_ENUF] #941541
03/02/11 09:20 PM
03/02/11 09:20 PM
ELYRIA,OH
ELYRIA,OH
i know what you mean about the rods.i am sure it will work as you are thinking.just not the best.you gunna wrap the headers by the tube touching?
Re: ? DIAPERO PINIONS WANTED [Re: QWK_ENUF] #941542
03/02/11 09:22 PM
03/02/11 09:22 PM
NC
440Jim Offline
440Jim  Offline
NC
Looks like a nice, well fitted job.
I don't know what the requirements are for the diaper (non-SFI type). Does it need to contain an absorbant mat? Does it need to cover any of the front (between damper and oil pan)?
If it meets the track rules, those oil pan studs to hold the front should make it easier to remove to change the oil. And I assume the starter is outside the diaper, so starter access should be fine.
Re: ? DIAPERO PINIONS WANTED [Re: 440Jim] #941543
03/02/11 09:33 PM
03/02/11 09:33 PM
NC
440Jim Offline
440Jim  Offline
NC
From the link on Josh's post to yellow bullet, this is an excerpt from the NHRA rule book (where SFI containment is required). It could be used as a guide for other applications.
Lower Engine Containment Device must cover the sides of the block and pan up to within one inch of the head mating surface and extend to within 1 1/2 inches of the front and rear of the cylinder case area
Are you going to sell them to Moparts.com members with BB Chrysler engines? I am considering one as I see the hand writing on the wall for "fast" bracket cars in the future (2012+)
Re: ? DIAPERO PINIONS WANTED [Re: 440Jim] #941544
03/02/11 09:38 PM
03/02/11 09:38 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
cylinder case area.
it should be lined with a oil absorbing mat like the company new pig makes
WAXER
Re: ? DIAPERO PINIONS WANTED [Re: QWK_ENUF] #941545
03/02/11 09:42 PM
03/02/11 09:42 PM
NC
440Jim Offline
440Jim  Offline
NC
Removable pieces of absorbant mat would be good for yearly cleaning.
Re: ? DIAPERO PINIONS WANTED [Re: 440Jim] #941546
03/02/11 09:42 PM
03/02/11 09:42 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Tommy, that looks pretty slick! We have these oil absorbent matts at the shop that are meant to contain oil spills. I wonder if you could line it with something like that??? Might make it kind of thick, though. I wonder what other kind of material it could be made of that may be less prone to melting? Fit looks great!
Randy
Re: ? DIAPERO PINIONS WANTED [Re: 440Jim] #941547
03/02/11 09:48 PM
03/02/11 09:48 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
hadn't really thought about that.just trying to get legal at indy to help support josh king in the 10.0 class.
WAXER
Re: ? DIAPERO PINIONS WANTED [Re: Dartin] #941548
03/02/11 09:53 PM
03/02/11 09:53 PM
ky
68roadrunner Offline
ky
looks good, maybe check into some melt proof patches to sew on near the headers, and line it with absorbent pads.
should satisfy them for a bracket race
Re: ? DIAPERO PINIONS WANTED [Re: QWK_ENUF] #941549
03/02/11 09:57 PM
03/02/11 09:57 PM
sg66mopar Offline
sg66mopar  Offline
Man, that's just Bill's color. Maybe you could hook him up.
Re: ? DIAPERO PINIONS WANTED [Re: sg66mopar] #941550
03/02/11 10:09 PM
03/02/11 10:09 PM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
Thats mine, Bill might need the extra absorbent.
Re: ? DIAPERO PINIONS WANTED [Re: QWK_ENUF] #941551
03/02/11 10:26 PM
03/02/11 10:26 PM
ELYRIA,OH
ELYRIA,OH
what thread did you use to sew it?buying a pattern and making your own might become comin. 12 oz duck cloth was listed at 8.95 fot 60" piece.[quick search on it.]
Re: ? DIAPERO PINIONS WANTED [Re: MoparPitBull] #941552
03/02/11 10:35 PM
03/02/11 10:35 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I'ld much rather keep it all inside this time around
