E-Brake Grommet Where to Find #938847
02/27/11 09:32 AM
02/27/11 09:32 AM
Ohio
C_B5 Offline OP
C_B5  Offline OP
Ohio
Looking to replace the Grommet on the E-Brake cable where it mounts to the mechanism. (see attached photo)
Anyone know where to find a new one ?
Re: E-Brake Grommet Where to Find [Re: C_B5] #938848
02/27/11 09:33 AM
02/27/11 09:33 AM
Ohio
C_B5 Offline OP
C_B5  Offline OP
Ohio
another photo of the plastic grommet Only
Re: E-Brake Grommet Where to Find [Re: C_B5] #938849
02/27/11 09:40 AM
02/27/11 09:40 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
In the past I've had to make my own.. If you're not into 100% correctness I'll let you in on my secret
CHECK OUT MY NEW WEB SITE !
Re: E-Brake Grommet Where to Find [Re: anlauto] #938850
02/27/11 11:45 AM
02/27/11 11:45 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Please share. I have the same problem.
Re: E-Brake Grommet Where to Find [Re: anlauto] #938851
02/27/11 12:13 PM
02/27/11 12:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Well,,,,,,,,,,,,,,?
but if you share it's not a secret any more is it?
Re: E-Brake Grommet Where to Find [Re: gtx6970] #938852
02/27/11 12:36 PM
02/27/11 12:36 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
An E clip worked for me
Re: E-Brake Grommet Where to Find [Re: N9671X2] #938853
02/27/11 12:39 PM
02/27/11 12:39 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
Re: E-Brake Grommet Where to Find [Re: C_B5] #938854
02/27/11 02:54 PM
02/27/11 02:54 PM
anlauto Offline
anlauto  Offline
Ok...Here it goes....this one's a freebie..
I have dozens of old firewall insulation "nails" kicking around, but shinny new ones will work too...
Take a drill with a bit the same size as the E Brake rod...
Drill out the open end of the firewall nail just a little, you don't have to go far...then just cut off the head of the nail....
Remove the E Brake handle, slip it in place and voila
I couldn't find a good picture of it...but you get the idea...
Re: E-Brake Grommet Where to Find [Re: anlauto] #938855
02/27/11 05:50 PM
02/27/11 05:50 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
Alan, that is a GREAT idea/solution
Re: E-Brake Grommet Where to Find [Re: N9671X2] #938856
02/27/11 10:59 PM
02/27/11 10:59 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
i used one of these from a value hardware store. plastic hole plug that i drilled out.
