Re: 440 Powered Honda Civic!!?
[Re: 440CIVIC]
#938365
02/28/11 10:24 AM
02/28/11 10:24 AM
Posts: 17,861 S.E. Michigan
ZIPPY
S.E. Michigan
I love it It sort of reminds me of a 440 6 pack Gremlin that used to run the streets around here in the '80s.
Rich H.
Esse Quam Videri
[Re: Twostick]
#938367
02/28/11 01:06 PM
02/28/11 01:06 PM
The driveshaft is 6" long joint center to joint center.
That won't allow for much suspension travel will it? Is that with a shorty trans?
Kevin
I have run this for about 25 years without a problem. Still the original joint it was put together with. The driveshaft tube is just under 3". I don't drive it on the street but have driven some ruff return roads.
As long as the shaft is phased in right you should not have a problem. Quicktree is the expert on this board on that topic.
The civic looks like a lot of fun. That is what hotrodding is all about.
[Re: RemCharger]
#938369
02/28/11 06:41 PM
02/28/11 06:41 PM
Posts: 64 Merrill, WI
440CIVIC
Merrill, WI
A properly "modded" honda... Does it meet the 90" wheel base?
No, only 86"
[Re: Kern Dog]
#938371
02/28/11 07:17 PM
02/28/11 07:17 PM
440CIVIC
Merrill, WI
Whats with the 90 inch wheelbase question? Is that a minimum number to pass NHRA track tech?
Yep From talking to local racers I should be able to get by the first time.
[Re: 440CIVIC]
#938372
02/28/11 09:24 PM
02/28/11 09:24 PM
Posts: 4,617 In the tower
RonTheAnnouncer
In the tower
Here's What I found: 4:12 WHEELBASE (Jan. 6, 2010) Minimum 85 inches, unless car has original engine in original location and is shorter than original, or noted in class requirements. Maximum wheelbase variation from left to right is 1 inch, unless otherwise noted in Class Requirements.
I'd call your divisional office and try to talk to a tech guy. If the car is otherwise safe, I wouldn't be too concerned.
Ron H. "Just when you think you have all of the answers...I change the questions!" "Rowdy" Roddy Piper
[Re: Dart1031]
#938373
03/02/11 07:05 PM
03/02/11 07:05 PM
440CIVIC
Merrill, WI
It's even got a Mopar tail stripe!
Now I just have to get some "rumble bee" stickers for it!
[Re: MuuMuu101]
#938375
03/02/11 08:08 PM
03/02/11 08:08 PM
440CIVIC
Merrill, WI
440Civic! Did you ever get new rims for your civic?
Still looking, will be ordering new next week if I don't any thing used.
Fronts 15X3.5-4 with 4x4.25 bolt circle or 5x4.5 bolt circle(would have to change out the pinto rotors for bigger bolt circle)
Rears 15x10-12 with 3.75-4.5 back space and any bolt circle(will have to drill new bolt circle, mine is ford truck 5x5.5)
[Re: maximum entropy]
#938379
03/05/11 11:13 PM
03/05/11 11:13 PM
Posts: 83 Manchester , Md.
67446DART
Manchester , Md.
I love it my friend had a red one this body style in high school I learned how to drive a stick in it.It was like driving a life sized go car I can only imagine what this thing is like!!
I love it!!
What does it weight?
67 Dart GT 10.5,mild,446,727,906heads,minitubbed,leafs,caltracks,410's,3290#w/out driver,10:87
@123w/ a 1.53 60ft
[Re: 440CIVIC]
#938380
03/05/11 11:51 PM
03/05/11 11:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looks like the seat is pretty close to the front... so your legs must be pretty bent... not very comfortable but its cool
[Re: 572B1]
#938382
03/06/11 08:34 PM
03/06/11 08:34 PM
440CIVIC
Merrill, WI
I spy a predator carb in the first video.
Predator got changed to a Race Demon 1000cfm. Predator was strong on top or on the bottom, could not get tuned for both. I will be putting two predators on a tunnel ram for a rat rod truck with a 440.(next project)
[Re: MuuMuu101]
#938383
03/29/11 11:37 PM
03/29/11 11:37 PM
440CIVIC
Merrill, WI
Yep
