Page 2 of 3 1 2 3
Re: 440 Powered Honda Civic!!? [Re: Twostick] #938364
02/28/11 10:17 AM
02/28/11 10:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Cool, when you add the slicks will they be tucked under the car? very cool
Coming soon!!!!
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938365
02/28/11 10:24 AM
02/28/11 10:24 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I love it
It sort of reminds me of a 440 6 pack Gremlin that used to run the streets around here in the '80s.
Rich H.
Esse Quam Videri
Re: 440 Powered Honda Civic!!? [Re: ZIPPY] #938366
02/28/11 11:50 AM
02/28/11 11:50 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
A properly "modded" honda...
Does it meet the 90" wheel base?
Re: 440 Powered Honda Civic!!? [Re: Twostick] #938367
02/28/11 01:06 PM
02/28/11 01:06 PM
The driveshaft is 6" long joint center to joint center.
That won't allow for much suspension travel will it? Is that with a shorty trans?
Kevin
I have run this for about 25 years without a problem. Still the original joint it was put together with. The driveshaft tube is just under 3". I don't drive it on the street but have driven some ruff return roads.
As long as the shaft is phased in right you should not have a problem. Quicktree is the expert on this board on that topic.
The civic looks like a lot of fun. That is what hotrodding is all about.
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938368
02/28/11 01:37 PM
02/28/11 01:37 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
coooooool
Re: 440 Powered Honda Civic!!? [Re: RemCharger] #938369
02/28/11 06:41 PM
02/28/11 06:41 PM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
No, only 86"
Re: 440 Powered Honda Civic!!? [Re: RemCharger] #938370
02/28/11 06:44 PM
02/28/11 06:44 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Whats with the 90 inch wheelbase question? Is that a minimum number to pass NHRA track tech?
Re: 440 Powered Honda Civic!!? [Re: Kern Dog] #938371
02/28/11 07:17 PM
02/28/11 07:17 PM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
Yep From talking to local racers I should be able to get by the first time.
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938372
02/28/11 09:24 PM
02/28/11 09:24 PM
In the tower
RonTheAnnouncer Offline
In the tower
Here's What I found:
4:12 WHEELBASE (Jan. 6, 2010)
Minimum 85 inches, unless car has original engine in original
location and is shorter than original, or noted in class requirements.
Maximum wheelbase variation from left to right is 1 inch, unless
otherwise noted in Class Requirements.
I'd call your divisional office and try to talk to a tech guy. If the car is otherwise safe, I wouldn't be too concerned.
Ron H.
"Just when you think you have all of the answers...I change the questions!" "Rowdy" Roddy Piper
Re: 440 Powered Honda Civic!!? [Re: Dart1031] #938373
03/02/11 07:05 PM
03/02/11 07:05 PM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
It's even got a Mopar tail stripe!
Now I just have to get some "rumble bee" stickers for it!
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938374
03/02/11 07:11 PM
03/02/11 07:11 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
440Civic! Did you ever get new rims for your civic?
Re: 440 Powered Honda Civic!!? [Re: MuuMuu101] #938375
03/02/11 08:08 PM
03/02/11 08:08 PM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
Still looking, will be ordering new next week if I don't any thing used.
Fronts 15X3.5-4 with 4x4.25 bolt circle or 5x4.5 bolt circle(would have to change out the pinto rotors for bigger bolt circle)
Rears 15x10-12 with 3.75-4.5 back space and any bolt circle(will have to drill new bolt circle, mine is ford truck 5x5.5)
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938376
03/02/11 09:09 PM
03/02/11 09:09 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
It has plates and insurance.
Re: 440 Powered Honda Civic!!? [Re: POS Dakota] #938377
03/03/11 05:28 PM
03/03/11 05:28 PM
IL
furious70 Offline
furious70  Offline
IL
You're ready for the wheelstand national in Byron now, put that thing on it's roof!!!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 440 Powered Honda Civic!!? [Re: furious70] #938378
03/03/11 05:47 PM
03/03/11 05:47 PM
organ
maximum entropy Offline
organ
dude, i LOVE YOUR CAR!
Re: 440 Powered Honda Civic!!? [Re: maximum entropy] #938379
03/05/11 11:13 PM
03/05/11 11:13 PM
Manchester , Md.
67446DART Offline
67446DART  Offline
Manchester , Md.
I love it my friend had a red one this body style in high school I learned how to drive a stick in it.It was like driving a life sized go car I can only imagine what this thing is like!!
I love it!!
What does it weight?
67 Dart GT 10.5,mild,446,727,906heads,minitubbed,leafs,caltracks,410's,3290#w/out driver,10:87 @123w/ a 1.53 60ft
Re: 440 Powered Honda Civic!!? [Re: 440CIVIC] #938380
03/05/11 11:51 PM
03/05/11 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like the seat is pretty close to the front...
so your legs must be pretty bent... not very comfortable
but its cool
Re: 440 Powered Honda Civic!!? [Re: MR_P_BODY] #938381
03/06/11 05:26 AM
03/06/11 05:26 AM
Brisbane Australia
572B1 Online content
572B1  Online Content
Brisbane Australia
I spy a predator carb in the first video.
Re: 440 Powered Honda Civic!!? [Re: 572B1] #938382
03/06/11 08:34 PM
03/06/11 08:34 PM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
Predator got changed to a Race Demon 1000cfm. Predator was strong on top or on the bottom, could not get tuned for both. I will be putting two predators on a tunnel ram for a rat rod truck with a 440.(next project)
Re: 440 Powered Honda Civic!!? [Re: MuuMuu101] #938383
03/29/11 11:37 PM
03/29/11 11:37 PM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
Yep
Page 2 of 3 1 2 3
