Page 1 of 4 1 2 3 4
Anyone run Caltracs? Worth it? #937974
02/26/11 02:01 PM
02/26/11 02:01 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Cuda will be going for low compression 340 to a 550+ hp 418. I already have M/T Drag Radials, but have been recommended Caltracs. I'm a novice, so who here runs them? Are they worth the $$$ and hassle? Is there a better alternative? Not crazy about the traction bar look, but if it's necessary, I'll do what I need to for traction.
Thanks,
Re: Anyone run Caltracs? Worth it? [Re: OA5599] #937975
02/26/11 02:07 PM
02/26/11 02:07 PM
All the Cal Trac users that figured out how to make them work will tell you they are great, all the SS spring users that made them work will tell you they are way better than something like Cal Tracs that they haven't treid yet The guys that had SS springs, then Cal Tracs and now ladder bars(installed properly with a good set of rear shocks) will tell you ladder bars are the best they treid Let the fun began
Re: Anyone run Caltracs? Worth it? [Re: OA5599] #937976
02/26/11 02:11 PM
02/26/11 02:11 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
definitely worth it. Once we installed them, the car was not as violent as the Mopar super stock springs and the car left very square. Go for some good shocks as well, such as AFCO Double adjustable shocks. Keep in mind that our 69 Cuda is a little more track oriented as well. Stock leaf spring location, but caltracs and split mono leafs, AFCO Double adjustables in the rear, single adjustable shocks in the front, lite torsion bars (Mopar Drag bars) 28X9 Hoosier slicks. We also use a fairly budget 904 trans with a low gear set and a good 8" Turbo Action Converter and the car drives good and hooks dead up at the track with a 1.37 60 foot time best. Average is 1.40. I would say yes to the Caltracs and split monoleafs. They alone wont be the answer to any traction woes however. Its the total combination of carefully chosen parts.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Anyone run Caltracs? Worth it? [Re: Cab_Burge] #937977
02/26/11 02:17 PM
02/26/11 02:17 PM
Guitar Jones Online laugh2
but would ad that they are the best you can do while still keeping leaf springs. They are not the best suspension system ever though, but they do work well.
Re: Anyone run Caltracs? Worth it? [Re: Guitar Jones] #937978
02/26/11 03:11 PM
02/26/11 03:11 PM
ill
dennismopar73 Offline
ill
well for the money and time to put them in ,
say no do not do it
if youre running more than 10 just spend money on set of ladders
coils or laddrs and sliders,
if i had to spend 1300 dollars just go with the ladders be done
if not stay with super stock springs!!
been there done it
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #937979
02/26/11 04:26 PM
02/26/11 04:26 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
the best u can get,by far for the money...o yea try and drive on the street w a 4 link or a ladder bar car! 7 sec cars w cal's on em
Re: Anyone run Caltracs? Worth it? [Re: fishy340] #937980
02/26/11 08:01 PM
02/26/11 08:01 PM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
they work for me!
Re: Anyone run Caltracs? Worth it? [Re: fishy340] #937981
02/26/11 08:06 PM
02/26/11 08:06 PM
ill
ill
I'm sorry awbdart,,
but nope they aint,
if you are running enough hp to upgrade over ss springs
money being money,, caltracks is $1.100-1.300.00 $
you can sneak set of ladders undr a car for far less
250$ for the bars and slider and keep stock springs!!!
and be better than cals
that is a fact!!
but if he is ruuning a basic street car ss springs will be
all he needs ,
ss spring will run in the 8 -9 sec zone without any hassel!!
i have run stock springs at 11,0 s
there is alot of stupid things i have done thru out the years
waste money is one of them
there is alot to be said about the front end of the car
and making the car leave than tons of money spent on the rear
for no good reason
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #937982
02/26/11 08:12 PM
02/26/11 08:12 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
I hope they are after hearing good reports im installing them on my ride for this spring along with leaf spring sliders
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #937983
02/26/11 08:14 PM
02/26/11 08:14 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I'm sorry awbdart,,
but nope they aint,
that is a fact!!
all he needs ,
for no good reason
How are you spending $1100-1300 on Caltracs?....I used stock springs...Ranchos at $65 each and Caltracs on my Duster that ran 10.60's with a 1.40 short...Probably had a shade over $500 in the whole deal with no welding and a bolt in job...And yes they worked great.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #937984
02/26/11 08:15 PM
02/26/11 08:15 PM
jersey
Spaceman Spiff Offline
jersey
I'm sorry awbdart,,
but nope they aint,
that is a fact!!
all he needs ,
for no good reason
where do you get caltracs are $1,100?? This was for a search for a '69 cuda.
http://calvertracing.com/cart/index.php?main_page=product_info&products_id=45
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Anyone run Caltracs? Worth it? [Re: Spaceman Spiff] #937985
02/26/11 08:21 PM
02/26/11 08:21 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
I think he is talking about caltracs and mon springs
Re: Anyone run Caltracs? Worth it? [Re: sturmenater] #937986
02/26/11 08:24 PM
02/26/11 08:24 PM
ill
ill
you are correct
and yes it was 1,100 dollars
we gad stock hd springs on the car ,
went to ss spring then to cals
we actually lost 60 from ss to cals
and went to bigger motor!!
2 diffrent converts
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #937987
02/26/11 08:27 PM
02/26/11 08:27 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i'd love to see an 8 or 9 sec ss leaf spring car!! w a 8,9 or even a 10" tire..please show me?
Re: Anyone run Caltracs? Worth it? [Re: dennismopar73] #937988
02/26/11 08:33 PM
02/26/11 08:33 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
you are correct
2 diffrent converts
The Caltracs work best with a set of worn-out stock springs...or the monos. Mine hooked great with the stock springs...left side just touching...right a half turn of pre-load. Ranchos were set at 4 on a 5way shock.
Dennis...what spring did you use with the Caltracs?...how fast was the car?
Re: Anyone run Caltracs? Worth it? [Re: OA5599] #937989
02/26/11 08:35 PM
02/26/11 08:35 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Love Em
Re: Anyone run Caltracs? Worth it? [Re: B1KILLER] #937990
02/26/11 08:38 PM
02/26/11 08:38 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
My Boy ,One Bad Fish
Pic says it all
Re: Anyone run Caltracs? Worth it? [Re: Eric] #937991
02/26/11 08:49 PM
02/26/11 08:49 PM
ill
ill
thanks eric for asking
this car is a 67 coronet
440 tweek to 474 now 8 ta conv 4200
on alk, dominator.
car started life as a 12.20 car 30 over 440, full stock inter say 3800 # w 430 gears 29 tire
we put some work in it put new hd springs on it
it then ran 12.0s sixty 1.67 -1.70
since those days it now has the 474 in it
410 gear same tire 29,
running alk and as only ran the best of 11.0 s
at 123 plus mph and 60 has been in the 1.67-1.68 range
we have 60 better with the ss springs at a 1.59
there is alot going on with this combo as you can tell by
the frustration in writting
this car should be running i think alot faster
as the mph suggest
as for cal tracks the money we spent vs the money we spent on ss
we do not see any pickup any where for that
we can rebolt the ss back on this car and have
and duplicated the 1.59 60 , so idono?
Re: Anyone run Caltracs? Worth it? [Re: B1KILLER] #937992
02/26/11 08:49 PM
02/26/11 08:49 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
B1Killer,
One extreme to the other huh???
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Anyone run Caltracs? Worth it? [Re: DemonDust] #937993
02/26/11 08:55 PM
02/26/11 08:55 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
if i'm not mistaken mancini is running a special or was on the cal tracs and mono spring setup for around 5 hun.
Page 1 of 4 1 2 3 4
