Assembly/break in Oil with lotsa Zinc?? #937783
02/26/11 11:15 AM
02/26/11 11:15 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
Am now assembling My 440,would anyone be able to tell Me which Engine oil readily available has the
most Zinc rich formula to use during assembly ( I
will be dipping My Pistons in It,soaking My new Lifters in It),and during initial run in ??
Re: Assembly/break in Oil with lotsa Zinc?? [Re: gassy66] #937784
02/26/11 11:32 AM
02/26/11 11:32 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Do a search on this site, topic is posted almost weekly.
Re: Assembly/break in Oil with lotsa Zinc?? [Re: ireland383] #937785
02/26/11 12:02 PM
02/26/11 12:02 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
I tried search,got no results.Didn't want to waste
valuable time when I could be getting Grease under My fingernails searching thru thousands of
freaking pages on this forum,when somebody who
knows could post answer,and I could go to Store!
Re: Assembly/break in Oil with lotsa Zinc?? [Re: gassy66] #937786
02/26/11 12:57 PM
02/26/11 12:57 PM
bc
3
37dodge Offline
37dodge  Offline
bc
Re: Assembly/break in Oil with lotsa Zinc?? [Re: gassy66] #937787
02/26/11 02:03 PM
02/26/11 02:03 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Use shell rotella and add the comp cams break-in additive...That'll give you what you need for the initial fire-up...
Re: Assembly/break in Oil with lotsa Zinc?? [Re: screamindriver] #937788
02/26/11 03:21 PM
02/26/11 03:21 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
Re: Assembly/break in Oil with lotsa Zinc?? [Re: gassy66] #937789
02/26/11 04:30 PM
02/26/11 04:30 PM
Kansas
Menzaero Offline
Menzaero  Offline
Kansas
Use Joe Gibbs BR Break In Oil. You have lots of $$ in the engine, don't skimp on the oil at break in.
Re: Assembly/break in Oil with lotsa Zinc?? [Re: Menzaero] #937790
02/27/11 01:24 PM
02/27/11 01:24 PM
California
1970mopar Offline
1970mopar  Offline
California
Joe Gibbs Break in Oil or Brad Penn break in oil. Both have the amount of zink needed for a proper break in
Re: Assembly/break in Oil with lotsa Zinc?? [Re: gassy66] #937791
02/27/11 02:00 PM
02/27/11 02:00 PM
tucson az
frank Offline
frank  Offline
tucson az
Brad Penn is what I used to break in my engine. FWIW I read recently it's not a good idea to soak lifters. I think it was in Mopar Action a few months back.
