Re: Big Cube W Head Smallblock Combos
[Re: Hot 340]
#936010
02/23/11 09:31 PM
02/23/11 09:31 PM
Posts: 115 louisiana,usa
olemopar
louisiana,usa
We were running 425ci 360ci stroked 4.100 12 to 1 with ported w2 heads hughes flat tappet cam 904 trans app 7000 rpm at the traps 9.96@132.33 250 passes and crankshaft broke at 7&8 rod this is the 2nd offset crank that we broke right now we will stay with the 4in stroke only Thanks Thad&Ann Shiers
[Re: Hot 340]
#936011
02/23/11 09:37 PM
02/23/11 09:37 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I have ran two different combos with a 4.125" stroke crank from LA Enterprises. One was an Arrington head 48 degree combo. It was 4.125 bore making 441 CID. It had about .800" lift roller cam and made around 800 HP. Sprayed 225HP plate system and ran 8.41 @162 with a 3,300 lbs car.
I took the same crank and made a 457 W8 engine. CFE R&D heads from Patterson. In other words they did not work for what they were trying to do. But, great for a big cube small block. This engine cranked some big power. Never was on a dyno but compared to my current combo that make 900 HP this engine was definately making more. I sprayed as much as 450HP Nitrous and was really happy how it ran. The engine was later bored to 4.245" making 468 CID.
I currently run a short deck with only 3.800" stroke. This one loves 9,000 RPM. But, really needs three speed or a stick to shine. Does not like the glide.
Leon
[Re: W5Duster436]
#936017
02/23/11 11:39 PM
02/23/11 11:39 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
4.125 bore X 3.79 stroke. 405 inch 13.0:1 on E-85 .668 lift roller with 268 @.050 single 4 bbl to be determined.........I am leaning towards a 950 h.p. It is still in the assembly stages , but I think I am going to like it a bunch. It is an R-3 block and W-9 heads that flow pretty nice #'s in the mid lift. It will see street use , so I compromised on some aspects of the build.
[Re: tubtar]
#936019
02/24/11 01:22 AM
02/24/11 01:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Very close to my W-9 engine... but with a bigger cam and more carb
[Re: W5Duster436]
#936021
02/24/11 06:52 PM
02/24/11 06:52 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
hmmmmmmmm sounds little like mine,your gonna smile for a while
It's a darn good thing my steering wheel is secure!
I have been counting down the days until I can go to the track and blast a good one and yell "Yeah Shady Dell Power"!!
the wheel is secure its the shaft that wobbles,and trust me nothing is shakeing loose,its gonna be fixed in about 3 weeks when the weather gets warm in the 30's
[Re: olemopar]
#936022
02/24/11 07:35 PM
02/24/11 07:35 PM
Posts: 3,395 Pa
Hot 340
Pa
We were running 425ci 360ci stroked 4.100 12 to 1 with ported w2 heads hughes flat tappet cam 904 trans app 7000 rpm at the traps [Email]9.96@132.33[/Email] 250 passes and crankshaft broke at 7&8 rod this is the 2nd offset crank that we broke right now we will stay with the 4in stroke only Thanks Thad&Ann Shiers
What crank did you break? What do you think was the cause? Damper? Ive seen some rev limiters in use that have to be hard on cranks too.
[Re: W5Duster436]
#936023
02/24/11 07:41 PM
02/24/11 07:41 PM
Posts: 3,395 Pa
Hot 340
Pa
[Re: Hot 340]
#936024
02/24/11 08:40 PM
02/24/11 08:40 PM
olemopar
louisiana,usa
one was Mopar steel crand prep by Ohio Crank,broke between 7&8 and rear flange The other was a 4340 broke between 1&2 and front dampner both between 225 and 250 passes at app 7000 through the traps Thad&Ann
[Re: Leon441]
#936025
02/25/11 10:03 PM
02/25/11 10:03 PM
Posts: 3,395 Pa
Hot 340
Pa
Leon
What trans behind the 457/468? Did you run a sheetmetal or casting manifold? Thats bookin for 3300#.
[Re: Hot 340]
#936026
02/25/11 10:38 PM
02/25/11 10:38 PM
Leon441
Lynchburg, VA
Started out with a stock gear ratio 727. Sent the converter back to dynamic three times. They would say they could not make any tighter but charge me around $300 everytime. I had a Tranzact VB, alluminum drum, billet output and deisel truck front planetary. Very enexpensive transmission. Switched to a glide and lost ET mostly 60 ft in the eighth mile. But made large gains in the quarter. The difference was in the conmverters. GM style converters are better. If I had ran a spacer between the tranny and engine and ran a different gear ratio in the trans I suspect the 727 could have been quicker. But, then you are spending a lot more money on the planetaries. With that kind of power the power glide worked well.
My 421 hates the glide.
Leon
