Big Cube W Head Smallblock Combos #936009
02/23/11 09:03 PM
02/23/11 09:03 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Whos running bigger than 4" on their smallblock stuff out there? I figure this will be a short thread as I havent heard of hardly any on here. Just wondering how much steam, torque, rpms, cam specs, header dia, if you care to share.
Re: Big Cube W Head Smallblock Combos [Re: Hot 340] #936010
02/23/11 09:31 PM
02/23/11 09:31 PM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
We were running 425ci 360ci stroked 4.100 12 to 1 with ported w2 heads
hughes flat tappet cam 904 trans app 7000 rpm at the traps
9.96@132.33 250 passes and crankshaft broke at 7&8 rod
this is the 2nd offset crank that we broke right now we will stay with the 4in stroke only
Thanks Thad&Ann Shiers
Re: Big Cube W Head Smallblock Combos [Re: Hot 340] #936011
02/23/11 09:37 PM
02/23/11 09:37 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I have ran two different combos with a 4.125" stroke crank from LA Enterprises. One was an Arrington head 48 degree combo. It was 4.125 bore making 441 CID. It had about .800" lift roller cam and made around 800 HP. Sprayed 225HP plate system and ran 8.41 @162 with a 3,300 lbs car.
I took the same crank and made a 457 W8 engine. CFE R&D heads from Patterson. In other words they did not work for what they were trying to do. But, great for a big cube small block. This engine cranked some big power. Never was on a dyno but compared to my current combo that make 900 HP this engine was definately making more. I sprayed as much as 450HP Nitrous and was really happy how it ran. The engine was later bored to 4.245" making 468 CID.
I currently run a short deck with only 3.800" stroke. This one loves 9,000 RPM. But, really needs three speed or a stick to shine. Does not like the glide.
Leon
Re: Big Cube W Head Smallblock Combos [Re: Leon441] #936012
02/23/11 09:42 PM
02/23/11 09:42 PM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
I know what you mean the glide will help mph but will kill the 60' we have anywhere from 1.28 to 1.32 accorking to the tracks, none of the tracks seems to be the same
Thad
Re: Big Cube W Head Smallblock Combos [Re: Hot 340] #936013
02/23/11 10:33 PM
02/23/11 10:33 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
I recently took my 364ci W5 to Ryan for a 4.125 setup. He'd have to give all the details but from what I can think of off the top of my head it's going to be 436ci ~11.3, same cam basically which i think is 274/278 108. Changing to a 360-3 Indy intake (So my old heavily modded W2 M1 is for sale)
It's in good hands with Ryan so I'm sure it'll make some pretty decent numbers.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Big Cube W Head Smallblock Combos [Re: W5Duster436] #936014
02/23/11 10:36 PM
02/23/11 10:36 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
hmmmmmmmm sounds little like mine,your gonna smile for a while
Re: Big Cube W Head Smallblock Combos [Re: W5Duster436] #936015
02/23/11 10:39 PM
02/23/11 10:39 PM
Greenville, SC
bad360rt Offline
bad360rt  Offline
Greenville, SC
Mine 425 has a 4.1" crank, 4.060 bore, with W5s, 11.2:1 cr. Made 565hp, 525tq on the old dyno that Ryan used to use. 262/270 108 hyd roller. Had 1 7/8 headers on the dyno, in the truck it's 1 7/8 stepped to 2" with 3.5" collectors. Unfortunately it hasn't hit the track yet, but will this year.
Re: Big Cube W Head Smallblock Combos [Re: fishy340] #936016
02/23/11 11:17 PM
02/23/11 11:17 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
It's a darn good thing my steering wheel is secure!
I have been counting down the days until I can go to the track and blast a good one and yell "Yeah Shady Dell Power"!!
'71 Dodge D100
'70 Dodge W100
Re: Big Cube W Head Smallblock Combos [Re: W5Duster436] #936017
02/23/11 11:39 PM
02/23/11 11:39 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
4.125 bore X 3.79 stroke. 405 inch 13.0:1 on E-85
.668 lift roller with 268 @.050
single 4 bbl to be determined.........I am leaning towards a 950 h.p.
It is still in the assembly stages , but I think I am going to like it a bunch.
It is an R-3 block and W-9 heads that flow pretty nice #'s in the mid lift.
It will see street use , so I compromised on some aspects of the build.
Re: Big Cube W Head Smallblock Combos [Re: Hot 340] #936018
02/24/11 01:08 AM
02/24/11 01:08 AM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
Im running a 4.125stroke .060over 340 think it ends up 435 ported W2s bullet sollid roller around 276 280 indy intake 1150dominator headman 1 7\8 headers through the traps around 7500 car weighs 2985 with me in it best so far is 1.30sixty et 9.77 at 134 I have not did alot of tuning on the engine as it took me a while to get the suspension to work I busted the 8 3\4 after about 15 passes Shady Dell picked the cam and rotating assembley and a few other parts and I couldnt be more satified with the customer service or performance
Re: Big Cube W Head Smallblock Combos [Re: tubtar] #936019
02/24/11 01:22 AM
02/24/11 01:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Very close to my W-9 engine... but with a bigger
cam and more carb
Re: Big Cube W Head Smallblock Combos [Re: MR_P_BODY] #936020
02/24/11 03:47 PM
02/24/11 03:47 PM
Edmonton alberta Canada
mr. 63plymouth Offline
I run a billet 4.312 stroke crank with a 340 resto block with a 4.125 bore, yelds 461 CUBES with Indy heads with a single 750 holley threw pump gas, N/A deal! Best ET 9.52@ a buck 142MPH! Awesome combo!!!!
Re: Big Cube W Head Smallblock Combos [Re: W5Duster436] #936021
02/24/11 06:52 PM
02/24/11 06:52 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
the wheel is secure its the shaft that wobbles,and trust me nothing is shakeing loose,its gonna be fixed in about 3 weeks when the weather gets warm in the 30's
Re: Big Cube W Head Smallblock Combos [Re: olemopar] #936022
02/24/11 07:35 PM
02/24/11 07:35 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
[Email]9.96@132.33[/Email] 250 passes and crankshaft broke at 7&8 rod
What crank did you break? What do you think was the cause? Damper? Ive seen some rev limiters in use that have to be hard on cranks too.
Re: Big Cube W Head Smallblock Combos [Re: W5Duster436] #936023
02/24/11 07:41 PM
02/24/11 07:41 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Re: Big Cube W Head Smallblock Combos [Re: Hot 340] #936024
02/24/11 08:40 PM
02/24/11 08:40 PM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
one was Mopar steel crand prep by Ohio Crank,broke between 7&8 and rear flange
The other was a 4340 broke between 1&2 and front dampner
both between 225 and 250 passes at app 7000 through the traps
Thad&Ann
Re: Big Cube W Head Smallblock Combos [Re: Leon441] #936025
02/25/11 10:03 PM
02/25/11 10:03 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Leon
What trans behind the 457/468? Did you run a sheetmetal or casting manifold? Thats bookin for 3300#.
Re: Big Cube W Head Smallblock Combos [Re: Hot 340] #936026
02/25/11 10:38 PM
02/25/11 10:38 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Started out with a stock gear ratio 727. Sent the converter back to dynamic three times. They would say they could not make any tighter but charge me around $300 everytime. I had a Tranzact VB, alluminum drum, billet output and deisel truck front planetary. Very enexpensive transmission. Switched to a glide and lost ET mostly 60 ft in the eighth mile. But made large gains in the quarter. The difference was in the conmverters. GM style converters are better. If I had ran a spacer between the tranny and engine and ran a different gear ratio in the trans I suspect the 727 could have been quicker. But, then you are spending a lot more money on the planetaries. With that kind of power the power glide worked well.
My 421 hates the glide.
Leon
Re: Big Cube W Head Smallblock Combos [Re: Leon441] #936027
02/25/11 11:24 PM
02/25/11 11:24 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
going to watch a 481 ci w9 in about 2 weeks stretch its legs on the dyno,maybe we can hit it with a little 2 0r 3 set of pills!! im pumped to see this
Re: Big Cube W Head Smallblock Combos [Re: fishy340] #936028
02/26/11 12:09 AM
02/26/11 12:09 AM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Can't wait to see what this 440" rpw9 does
