Approx. hours for a partial rotieserre resto...
#935956
02/23/11 08:23 PM
02/23/11 08:23 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I know it can be a very wide range... but I'll break it down for this one. Diassemble, including interior, drivetrain, suspension, glass, etc... basically strip to a bare shell. Strip, remove undercoating, blast, some minor rust repair(minor patching, filling pin holes), better repair some previous crash work better... epoxy, prime, block and so on including the underside to prep and paint, inside panels like fender valances... repaint rear suspension, new brake/fuel lines, reassemble, and so on. This doesn't include recovering seat, any refurbuishing to the front suspension, dash, column, and so on. Basically a rotiserre paint job on a fairly straight rust free car. Just curious to see how many hours people have had in doing something similar or how many hours they think it should take. ![](/ubbthreads/images/graemlins/beer.gif)
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Approx. hours for a partial rotieserre resto...
[Re: cloneguy]
#935958
02/23/11 09:44 PM
02/23/11 09:44 PM
Posts: 142 NJ
70_FJ6_RR
NJ
[Re: anlauto]
#935960
02/23/11 10:10 PM
02/23/11 10:10 PM
Silver70
Rust Belt, SW PA
Thanks guys, that's a good bit higher than I expected. I should mention, not refinishing anything on the inside, not polishing trim, and alot of the small detail stuff. More just a rotisserre done car as far as paint/body. Interior, just pull and replace once painted. Engine, front suspension and such are being done by the owner. Not redoing the entire brake system, just new lines/cables. Not doing the underhood wiring, carpet and seats back in.
Does 350 hours sound realistic? I read a site from a member here that said a typical top side resto will take about 300 hours.
[Re: Silver70]
#935961
02/23/11 10:17 PM
02/23/11 10:17 PM
Posts: 4,999 North Pole,New York
formula_s
North Pole,New York
Only if you let Maaco do it.
[Re: Silver70]
#935962
02/23/11 10:29 PM
02/23/11 10:29 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
400-450. Maybe a hair more depending on your collision repairs you stated.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: Silver70]
#935963
02/23/11 11:26 PM
02/23/11 11:26 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Typically shops have a minimum of 250-300 hrs just for prep and paint on the exterior body, you're talking about doing the complete underside as well. You've done restoration work in the past so you should have an idea of how much time it will take to dismantle and strip the shell... I personally think you're robbing yourself if you quote anything less then 500 hrs... ![](/ubbthreads/images/graemlins/Twocents.gif)
CHECK OUT MY NEW WEB SITE !
[Re: Silver70]
#935965
02/23/11 11:46 PM
02/23/11 11:46 PM
anlauto
When I say 75 hrs for assembly, that's with having EVERYTHING ready to go...that doesn't count the engine and tranny being set-up on the K Frame, that doesn't count any of the sub assemblies being restored...
[Re: gtx6970]
#935968
02/24/11 09:41 AM
02/24/11 09:41 AM
Posts: 1,992 midwest
68427vette
midwest
"cloneguy" just did a customers cuda i think....blue... he'd have a ballpark, alan s done a few..... also having an extra set of hands,, helps!! i get to unload a B5 today!!! ![](/ubbthreads/images/graemlins/smoke.gif) remember partial.. usually ends up being FULL restoration.. my B5 i just bought,, sounds like the car you are discribing. i'm going to keep a hour meter and expense box (sealed, and away from wife ![](/ubbthreads/images/graemlins/whistling.gif) ) on this project.. ![](/ubbthreads/images/graemlins/drinking.gif) the master painter for the high end shop told me he puts in 250+(400+) hrs for each paint job, his shop charges min, $15,000-30k, my cars will get done at $8500. 250hrs x $30hr= $7500(+$1000 for material)($8500) it took me almost 2+ days with a helper to tear down "butterturd", but it was Ruff, and had no motor/trans in it. 30+hrs blasting a whole body, 8-10 hours, plus fenders 1-3 more:= 13 hrs 250+ 30 13 = 293 hours add a few more = 293-300 hours ![](/ubbthreads/images/graemlins/musik010.gif) add body work welding ![](/ubbthreads/images/graemlins/weld.gif) 100+ hours =400+ hours ![](/ubbthreads/images/graemlins/luck.gif) 100 for beer drinking... ![](/ubbthreads/images/graemlins/beer.gif) 500 hrs
[Re: DennisH ]
#935970
02/24/11 10:06 AM
02/24/11 10:06 AM
68427vette
midwest
aahh, man, do you homework.. or start lighting ![](/ubbthreads/images/graemlins/weld.gif) $100 bills. when i first saw the number 500hrs, i thought, no way. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) but it adds up. ![](/ubbthreads/images/graemlins/scope.gif) don't cut yourself short. dennis, you must have way too much money(good for you) ![](/ubbthreads/images/graemlins/thumbs.gif) or see an estimate, and pray for the best, and hope not to get the, "well, when we......" ![](/ubbthreads/images/graemlins/tsk.gif) phone call.... i'm just saying... ![](/ubbthreads/images/graemlins/musik010.gif)
[Re: sixpackbee]
#935972
02/24/11 07:14 PM
02/24/11 07:14 PM
Silver70
Rust Belt, SW PA
First, let me say this is a car I'm doing for someone else. It was a pretty clean car and came in looking prety straight and very little rust. Of course after being stripped it had mud and more rust once it's was cleaned/blasted. I'm doing all the work in house and on a rotiserre. One thing is normally I find factory undercoating pretty easy to remove. Some heat and a scraper and it comes off in chunks. This one had some aftermarket crap and was a real pain. I assume it was used to cover up some of the dents and such from when it was wrecked. After tear down, then blasting, straightening, replacing a few sections and so on, I'd say the 250 or so number will probally be pretty close to the time I have into the body and putting it in paint. I really thought originally I could keep it under 300 hours, but like I mentioned, you find more as you remove parts, paint, and undercoating. I've done body work for around 20 years and until the past 5 years, it was always my own stuff or smaller projects for others. So I was curious to see how my pace was compared to others. I go hourly, so I don't have to cut corners. And it's not like the owner had a problem with the time that's gone into it. Thanks for the replies. ![](/ubbthreads/images/graemlins/beer.gif) I feel much better knowing that I'm making good progress on the time I have into the car. I think 350 hours should get me pretty close, but from all this I guess I could be closer to 400. And the beer drinking is done on my own time ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Silver70]
#935973
02/24/11 07:24 PM
02/24/11 07:24 PM
Challenger 1
Cincinnati, Ohio
I should go in business removing under coating because I can do it fast on a rotissiere. Have never had something I couldn't steam pressure wash, off of a peice of metal. ![](/ubbthreads/images/graemlins/no.gif)
[Re: Challenger 1]
#935975
02/24/11 07:29 PM
02/24/11 07:29 PM
Silver70
Rust Belt, SW PA
I should go in business removing under coating because I can do it fast on a rotissiere. Have never had something I couldn't steam pressure wash off a peice of metal.
I think the pressure washer I would need to use to do that would cost more than it would be worth. Still the problem is, even if you could use that, it's not going to remove the rust. I had to blast the excess, scrape with a razor blade then reblast parts... believe me if there was an easier way I'd love to be able to do it. ![](/ubbthreads/images/graemlins/thumbs.gif)
