Page 1 of 3 1 2 3
Approx. hours for a partial rotieserre resto... #935956
02/23/11 08:23 PM
02/23/11 08:23 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
I know it can be a very wide range... but I'll break it down for this one.
Diassemble, including interior, drivetrain, suspension, glass, etc... basically strip to a bare shell. Strip, remove undercoating, blast, some minor rust repair(minor patching, filling pin holes), better repair some previous crash work better... epoxy, prime, block and so on including the underside to prep and paint, inside panels like fender valances... repaint rear suspension, new brake/fuel lines, reassemble, and so on.
This doesn't include recovering seat, any refurbuishing to the front suspension, dash, column, and so on. Basically a rotiserre paint job on a fairly straight rust free car.
Just curious to see how many hours people have had in doing something similar or how many hours they think it should take.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935957
02/23/11 08:31 PM
02/23/11 08:31 PM
Roswell, GA - near Atlanta
cloneguy Offline
super street
cloneguy  Offline
super street
500 hours.
Martin, GA Quality Auto Restoration with Fair FIXED Pricing. Fast-N-Dangerous@comcast.net
Re: Approx. hours for a partial rotieserre resto... [Re: cloneguy] #935958
02/23/11 09:44 PM
02/23/11 09:44 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935959
02/23/11 09:51 PM
02/23/11 09:51 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I concur... that means agree
CHECK OUT MY NEW WEB SITE !
Re: Approx. hours for a partial rotieserre resto... [Re: anlauto] #935960
02/23/11 10:10 PM
02/23/11 10:10 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Thanks guys, that's a good bit higher than I expected. I should mention, not refinishing anything on the inside, not polishing trim, and alot of the small detail stuff. More just a rotisserre done car as far as paint/body. Interior, just pull and replace once painted. Engine, front suspension and such are being done by the owner. Not redoing the entire brake system, just new lines/cables. Not doing the underhood wiring, carpet and seats back in.
Does 350 hours sound realistic? I read a site from a member here that said a typical top side resto will take about 300 hours.
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935961
02/23/11 10:17 PM
02/23/11 10:17 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Only if you let Maaco do it.
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935962
02/23/11 10:29 PM
02/23/11 10:29 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
400-450. Maybe a hair more depending on your collision repairs you stated.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935963
02/23/11 11:26 PM
02/23/11 11:26 PM
anlauto Offline
anlauto  Offline
Typically shops have a minimum of 250-300 hrs just for prep and paint on the exterior body, you're talking about doing the complete underside as well.
You've done restoration work in the past so you should have an idea of how much time it will take to dismantle and strip the shell...
I personally think you're robbing yourself if you quote anything less then 500 hrs...
Re: Approx. hours for a partial rotieserre resto... [Re: anlauto] #935964
02/23/11 11:40 PM
02/23/11 11:40 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
I've done a lot more collison work and the resto work was always stuff done for myself til the past few years. I never really kept track of hours on my own cars... seems like when you do that it feels like work.
The reason I asked is because I felt like I was getting to the point on the current car that I had too much time into it. I am quite suprised to see what you guys think it will take. I've follwed your thread Alan on the ta and the time you have in the assembly and that's what got me wondering. I really thought I could get this one done in 300 hours, but say it takes 75 or so for assembly and such, where it's at now I can;t see anyway I'll have 350 plus hours into it.
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935965
02/23/11 11:46 PM
02/23/11 11:46 PM
anlauto Offline
anlauto  Offline
When I say 75 hrs for assembly, that's with having EVERYTHING ready to go...that doesn't count the engine and tranny being set-up on the K Frame, that doesn't count any of the sub assemblies being restored...
Re: Approx. hours for a partial rotieserre resto... [Re: anlauto] #935966
02/23/11 11:53 PM
02/23/11 11:53 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
Well this car, very little needed to be done. It's pretty much just needs reassembled. Some stuff will need work or refinished, but not a lot.
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935967
02/24/11 08:54 AM
02/24/11 08:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
several variables can plany in here,
example,
A- if the underside is being done, how is it being cleaned? laying on your back with a scraper and wirewheels on a drill
or
B- up on it's side and cleaned with a blaster of some kind, such as media blasting or steam cleaning
A= cheaper initially but adds in more labor time
B= faster but more costs, possibily outsourced
Re: Approx. hours for a partial rotieserre resto... [Re: gtx6970] #935968
02/24/11 09:41 AM
02/24/11 09:41 AM
midwest
68427vette Offline
68427vette  Offline
midwest
"cloneguy" just did a customers cuda i think....blue... he'd have a ballpark, alan s done a few..... also having an extra set of hands,, helps!! i get to unload a B5 today!!!
remember partial.. usually ends up being FULL restoration..
my B5 i just bought,, sounds like the car you are discribing. i'm going to keep a hour meter and expense box (sealed, and away from wife ) on this project..
the master painter for the high end shop told me he puts in 250+(400+) hrs for each paint job, his shop charges min, $15,000-30k, my cars will get done at $8500. 250hrs x $30hr= $7500(+$1000 for material)($8500)
it took me almost 2+ days with a helper to tear down "butterturd", but it was Ruff, and had no motor/trans in it. 30+hrs
blasting a whole body, 8-10 hours, plus fenders 1-3 more:= 13 hrs
250+
30
13 = 293 hours
add a few more = 293-300 hours
add body work welding 100+ hours
=400+ hours
100 for beer drinking...
500 hrs
Re: Approx. hours for a partial rotieserre resto... [Re: 68427vette] #935969
02/24/11 10:04 AM
02/24/11 10:04 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
I know nothing. My wallet does my talking. If I was estimated 500, I'd figure a thousand. I'm just saying.
Re: Approx. hours for a partial rotieserre resto... [Re: DennisH ] #935970
02/24/11 10:06 AM
02/24/11 10:06 AM
midwest
68427vette Offline
68427vette  Offline
midwest
aahh, man, do you homework.. or start lighting $100 bills.
when i first saw the number 500hrs, i thought, no way. but it adds up. don't cut yourself short.
dennis, you must have way too much money(good for you) or see an estimate, and pray for the best, and hope not to get the, "well, when we......" phone call.... i'm just saying...
Re: Approx. hours for a partial rotieserre resto... [Re: 68427vette] #935971
02/24/11 10:28 AM
02/24/11 10:28 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
500 hrs
Ah, but the beer drinking is at 1/2 the normal shop rate to save the customer some money. Be sure to check this on your next estimate.
1959 Bugeye Sprite
1971 MG Midget
Re: Approx. hours for a partial rotieserre resto... [Re: sixpackbee] #935972
02/24/11 07:14 PM
02/24/11 07:14 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
First, let me say this is a car I'm doing for someone else. It was a pretty clean car and came in looking prety straight and very little rust. Of course after being stripped it had mud and more rust once it's was cleaned/blasted. I'm doing all the work in house and on a rotiserre.
One thing is normally I find factory undercoating pretty easy to remove. Some heat and a scraper and it comes off in chunks. This one had some aftermarket crap and was a real pain. I assume it was used to cover up some of the dents and such from when it was wrecked.
After tear down, then blasting, straightening, replacing a few sections and so on, I'd say the 250 or so number will probally be pretty close to the time I have into the body and putting it in paint.
I really thought originally I could keep it under 300 hours, but like I mentioned, you find more as you remove parts, paint, and undercoating. I've done body work for around 20 years and until the past 5 years, it was always my own stuff or smaller projects for others. So I was curious to see how my pace was compared to others. I go hourly, so I don't have to cut corners. And it's not like the owner had a problem with the time that's gone into it.
Thanks for the replies. I feel much better knowing that I'm making good progress on the time I have into the car. I think 350 hours should get me pretty close, but from all this I guess I could be closer to 400.
And the beer drinking is done on my own time
Re: Approx. hours for a partial rotieserre resto... [Re: Silver70] #935973
02/24/11 07:24 PM
02/24/11 07:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I should go in business removing under coating because I can do it fast on a rotissiere. Have never had something I couldn't steam pressure wash, off of a peice of metal.
Re: Approx. hours for a partial rotieserre resto... [Re: anlauto] #935974
02/24/11 07:25 PM
02/24/11 07:25 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
....and if Alan says 500, you should probably plan on 600!
mine took 600 and I had taken the car apart and got it back as a rolling shell.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Approx. hours for a partial rotieserre resto... [Re: Challenger 1] #935975
02/24/11 07:29 PM
02/24/11 07:29 PM
Rust Belt, SW PA
Silver70 Offline OP
Silver70  Offline OP
Rust Belt, SW PA
I should go in business removing under coating because I can do it fast on a rotissiere. Have never had something I couldn't steam pressure wash off a peice of metal.
I think the pressure washer I would need to use to do that would cost more than it would be worth. Still the problem is, even if you could use that, it's not going to remove the rust. I had to blast the excess, scrape with a razor blade then reblast parts... believe me if there was an easier way I'd love to be able to do it.
Page 1 of 3 1 2 3
