Re: SixPack Aircleaner Spacer
[Re: dart4forte]
#934639
02/22/11 12:35 AM
02/22/11 12:35 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You could use carb spacers but that wouldn't help fuel rail clearance...
[Re: 1_WILD_RT]
#934640
02/22/11 02:02 AM
02/22/11 02:02 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Hi John
check out Speedway Motors.. they have a Speedway Sure Seal O Ring that may work..
I am truckless..
[Re: 340SHORTY]
#934641
02/22/11 03:01 AM
02/22/11 03:01 AM
Posts: 16,160 Mesa, Arizona
dart4forte
Mesa, Arizona
Hi John
I did, I need one for each carb. Those are for single 4 barrels carbs.
[Re: AndyF]
#934643
02/22/11 03:26 AM
02/22/11 03:26 AM
dart4forte
Mesa, Arizona
You can put spacers under the carbs but then you need to dink with the throttle linkage and the return spring.
I thought about that however I really don't want to change the signal to the carbs.
[Re: mikemee1331]
#934645
02/22/11 10:32 AM
02/22/11 10:32 AM
Posts: 3,002 Long Island, NY
shakerjoe
Long Island, NY
someone on epay sells a billet 6pak spacer - looks like a nice piece - don't know how effective it is - try a search - sometimes it's up there...ooops just realized your question - after my coffee - this is for raising the carbs higher off of the intske - not raising the aircleaner- sorry
[Re: shakerjoe]
#934647
02/22/11 02:04 PM
02/22/11 02:04 PM
dart4forte
Mesa, Arizona
No raising the aircleaner off the top of the carb. This item was on E-bay? The reasopn for me wanting to do this is to get the base off the distributor and off the top of the carb. I'm running the Demon sixpack setup and they want you to mod the base by cutting it.
[Re: Mr.Yuck]
#934649
02/22/11 02:37 PM
02/22/11 02:37 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I have 1/2" spacers under my carbs because the center one has meth jets in it. Why does your lid hit the fuel line? did you install it upside down? Mine drops way down and isn't even close. If you raise the air cleaner you are going to put it into the hood. I had zero room w/ my stock hood so I had to go get a glass cowl hood.
He has demon carbs , fuel inlet is in a different location than the standard Holley carb.
Sounds like something easy to whip up if you have access to a CNC.
[Re: JohnRR]
#934650
02/22/11 02:43 PM
02/22/11 02:43 PM
dart4forte
Mesa, Arizona
Yeah, that's it. I know some CNC shops locally but it would be too costly Sounds like something easy to whip up if you have access to a CNC.
[Re: dart4forte]
#934653
02/22/11 04:33 PM
02/22/11 04:33 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
It is a lowdeck motor with an airgrabber so I need at least and inch raised to get the aircleaner in the correct position
I'd have a based fabbed up then. Not sure you can "space" an entire inch out.
[Re: Mr.Yuck]
#934654
02/22/11 04:40 PM
02/22/11 04:40 PM
JohnRR
U.S.S.A.
Sure you could , make a spacer that looks like the gasket , we have a prototrak on a bridgeport , make a drawing and crank out 3 in a heartbeat ... ok maybe 2 heartbeats ...
[Re: JohnRR]
#934655
02/22/11 04:42 PM
02/22/11 04:42 PM
Mr.Yuck
Brookeville, Md
well I couldn't do it with my current table saw...lol
[Re: Mr.Yuck]
#934656
02/22/11 04:44 PM
02/22/11 04:44 PM
JohnRR
U.S.S.A.
There you go , make it from wood using a router
[Re: JohnRR]
#934657
02/22/11 07:55 PM
02/22/11 07:55 PM
dart4forte
Mesa, Arizona
I was thinking of going that route, making the spacers out of wood. The challange would be getting the 1" I need
