Page 9 of 13 1 2 7 8 9 10 11 12 13
Re: New 5.7 hemi eagle head [Re: RTSrunner] #934457
04/04/11 10:14 AM
04/04/11 10:14 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
got this on the net." now for the useful stuff.
Cylinder heads. big changes here, new closed chamber heads have smaller chambers (duh) than previous engines , 66.3cc in fact vs 84.9cc. even smaller than the 6.1's with 73.0cc. bolting these on to a previous hemi without modification would result in nearly a 12:1 compression ratio.
Are there pistons available to get a lower compression ratio than 12:1 using these heads on an earlier engine?I assume the stock later piston would work,not sure what CR is on late hemis though.
RT
Well there is always custom. I am not sure of the 09 piston but I think they would work. I think 09 got a compression boost. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934458
04/04/11 10:34 AM
04/04/11 10:34 AM
houston texas
gremlinsteve Offline
houston texas
yes. use like a wiseco 9.0 to one piston or a diamond 8.5 that will get you into the 10.0-10.5 range with that head. i know the wiseco is more of a shelf stock piston
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: New 5.7 hemi eagle head [Re: gremlinsteve] #934459
04/04/11 11:40 AM
04/04/11 11:40 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
steve
Good to know.
Re: New 5.7 hemi eagle head [Re: MattW] #934460
05/29/11 03:12 PM
05/29/11 03:12 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Just looked at dodgeparts.com and these heads are 118.80 each.
This has to be wrong. How do you make money at that price? Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934461
05/31/11 05:11 PM
05/31/11 05:11 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Re: New 5.7 hemi eagle head [Re: MattW] #934462
05/31/11 06:04 PM
05/31/11 06:04 PM
Tuscaloosa, Alabama
speedfreak440 Offline
Tuscaloosa, Alabama
Do the 5.7 & 6.1 use the same OEM computer? Obviously the tuning is different but are the part#'s the same so that you could use the 5.7 computer & re-tune it for a 6.1?
Re: New 5.7 hemi eagle head [Re: speedfreak440] #934463
06/03/11 01:53 AM
06/03/11 01:53 AM
Missouri
Challenger Offline
Challenger  Offline
Missouri
Alright Im just a little confused on these part numbers for the Eagle head. I worked on a 07 truck with a 5.7 hemi and the part numbers on them heads were 53021608de and 53021609de which is what was said at the beginning of the post as Eagle heads BUT I didnt think that they were built til 09. So when I go to the dealer what part number should I be telling them for the Eagle heads? Sixpackgut what part numbers are yours? THANKS!
Re: New 5.7 hemi eagle head [Re: Challenger] #934464
06/03/11 07:44 AM
06/03/11 07:44 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
The part# is correct for the eagle head. 53021608DE and 609DE.
You either have made a mistake in identifying the heads or someone has already changed them. Go and see if your heads look like the ones on page 5.
Easiest way to tell D shaped exhaust. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934465
06/03/11 08:30 AM
06/03/11 08:30 AM
Missouri
Challenger Offline
Challenger  Offline
Missouri
Ive known this truck since new and engine has not been touched and I kept looking at them numbers and they are correct. Heads and engine are still in truck. I can see the numbers clearly. When I gave the parts guy those numbers, 53021608de and 53021609de he said they were remanufactured. Also the numbers have superceded to 53021608BL and 53021609BL.
Re: New 5.7 hemi eagle head [Re: Challenger] #934466
06/03/11 09:27 AM
06/03/11 09:27 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i will have to check when i get home but i think the letters are different than those. but the numbers are the same, even the same as my 04 heads. but when i bought mine i used the part numbers listed in this thread
BTW, i just picked up a 426 for less than a rotating assembly. K1 crank and rods with JE pistons
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934467
06/03/11 10:02 AM
06/03/11 10:02 AM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Are you going to sell your 5.7?
I'm Gumby dammit!
Re: New 5.7 hemi eagle head [Re: Gumbydammit] #934468
06/03/11 10:20 AM
06/03/11 10:20 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
the 5.7 has sat outside. water may have got in the cylinders. i was planning on going thru the motor. i'll let it go for $400 minus the timing cover because i had it CNC'd.
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934469
06/03/11 10:24 AM
06/03/11 10:24 AM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Pm me, where in SC are you? I may be interested.
I'm Gumby dammit!
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934470
06/03/11 02:29 PM
06/03/11 02:29 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Nice find did you see that the eagle head is going for 118.80 a piece. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934471
06/03/11 04:56 PM
06/03/11 04:56 PM
NY usa
540challenger Offline
NY usa
Where??? and is it fully assembled like th Moapr ones with plugs and all??
Re: New 5.7 hemi eagle head [Re: Challenger] #934472
06/03/11 06:04 PM
06/03/11 06:04 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
Sorry about that the numbers have been superceded to RL021608DE, RL021609DE. Not the above.
BTW Where are you finding them for $118, my cost on them is $248.
Re: New 5.7 hemi eagle head [Re: Challenger] #934473
06/03/11 10:04 PM
06/03/11 10:04 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Go to dodgeparts.com.
Remember if you order from them you will have to pay shipping. Dealer you do not. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934474
06/03/11 10:51 PM
06/03/11 10:51 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
ya, i read that. piss me off, i paid almost 90% more i was going to buy several sets at $222, glad i didnt. does dodge parts have the drag pack intake? i havnt even went over to look
FYI, my heads end in DD. why? i dont have a clue
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934475
06/04/11 09:30 AM
06/04/11 09:30 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
It's OK. I payed 248 a piece. But I did not have to pay for shipping.
Don't bother with dodge parts for the intake it's 1114.30
You can try MonicattyChrysler 747.00
You may have a hard time with availability
As to why your heads end in DD
Re: New 5.7 hemi eagle head [Re: MattW] #934476
06/04/11 01:30 PM
06/04/11 01:30 PM
Hot Rod Ridge
FastmOp Online tonguue
FastmOp  Online Tonguue
Hot Rod Ridge
I'm doing a few upgrades to my SRT Challenger and would like to run some stuff by you guys. I'm looking at doing A jegs exhaust. I have a procharger stage two kit in the mail and would like to gain a old mopar rumble when I put it on. But the cats and O2 sensors scare me. I'd hate to put headers and cat back on only to have stock cats chokeing it down.
Any tips on hooking up this IRs would be good
