Re: New 5.7 hemi eagle head
[Re: RTSrunner]
#934457
04/04/11 10:14 AM
04/04/11 10:14 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
got this on the net." now for the useful stuff. Cylinder heads. big changes here, new closed chamber heads have smaller chambers (duh) than previous engines , 66.3cc in fact vs 84.9cc. even smaller than the 6.1's with 73.0cc. bolting these on to a previous hemi without modification would result in nearly a 12:1 compression ratio.
Are there pistons available to get a lower compression ratio than 12:1 using these heads on an earlier engine?I assume the stock later piston would work,not sure what CR is on late hemis though. RT
Well there is always custom. I am not sure of the 09 piston but I think they would work. I think 09 got a compression boost. Matt
[Re: MattW]
#934458
04/04/11 10:34 AM
04/04/11 10:34 AM
Posts: 1,828 houston texas
gremlinsteve
houston texas
yes. use like a wiseco 9.0 to one piston or a diamond 8.5 that will get you into the 10.0-10.5 range with that head. i know the wiseco is more of a shelf stock piston
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: gremlinsteve]
#934459
04/04/11 11:40 AM
04/04/11 11:40 AM
MattW
Ontario Canada
steve
Good to know. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Challenger]
#934464
06/03/11 07:44 AM
06/03/11 07:44 AM
MattW
Ontario Canada
Alright Im just a little confused on these part numbers for the Eagle head. I worked on a 07 truck with a 5.7 hemi and the part numbers on them heads were 53021608de and 53021609de which is what was said at the beginning of the post as Eagle heads BUT I didnt think that they were built til 09. So when I go to the dealer what part number should I be telling them for the Eagle heads? Sixpackgut what part numbers are yours? THANKS!
The part# is correct for the eagle head. 53021608DE and 609DE. You either have made a mistake in identifying the heads or someone has already changed them. Go and see if your heads look like the ones on page 5. Easiest way to tell D shaped exhaust. Matt
[Re: Challenger]
#934466
06/03/11 09:27 AM
06/03/11 09:27 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i will have to check when i get home but i think the letters are different than those. but the numbers are the same, even the same as my 04 heads. but when i bought mine i used the part numbers listed in this thread
BTW, i just picked up a 426 for less than a rotating assembly. K1 crank and rods with JE pistons
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#934470
06/03/11 02:29 PM
06/03/11 02:29 PM
MattW
Ontario Canada
Nice find did you see that the eagle head is going for 118.80 a piece. Matt
[Re: MattW]
#934471
06/03/11 04:56 PM
06/03/11 04:56 PM
Posts: 2,826 NY usa
540challenger
NY usa
Where??? and is it fully assembled like th Moapr ones with plugs and all??
[Re: Challenger]
#934472
06/03/11 06:04 PM
06/03/11 06:04 PM
Posts: 221 Missouri
Challenger
Missouri
. Also the numbers have superceded to 53021608BL and 53021609BL.
Sorry about that the numbers have been superceded to RL021608DE, RL021609DE. Not the above.
BTW Where are you finding them for $118, my cost on them is $248.
[Re: Challenger]
#934473
06/03/11 10:04 PM
06/03/11 10:04 PM
MattW
Ontario Canada
Go to dodgeparts.com. Remember if you order from them you will have to pay shipping. Dealer you do not. Matt
[Re: MattW]
#934474
06/03/11 10:51 PM
06/03/11 10:51 PM
sixpackgut
Charleston
ya, i read that. piss me off, i paid almost 90% more i was going to buy several sets at $222, glad i didnt. does dodge parts have the drag pack intake? i havnt even went over to look
FYI, my heads end in DD. why? i dont have a clue
[Re: sixpackgut]
#934475
06/04/11 09:30 AM
06/04/11 09:30 AM
MattW
Ontario Canada
It's OK. I payed 248 a piece. But I did not have to pay for shipping. Don't bother with dodge parts for the intake it's 1114.30 You can try MonicattyChrysler 747.00 You may have a hard time with availability As to why your heads end in DD ![](/ubbthreads/images/graemlins/shruggy.gif)
