Re: "C" clip eliminators.
[Re: DoctorDiff]
#934278
02/26/11 08:38 PM
02/26/11 08:38 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Axle forgings are not a problem.
What size of rear brakes are common on 9.25" Dakota rears?
The brake book shows 9", 10" and 11" depending on the year. Do you know if the axle flange standout, brake register diameter and brake backing plate bolt pattern is consistant?
Are not the Dakota drum brakes the same as B body brakes.
[Re: DoctorDiff]
#934281
02/27/11 02:13 AM
02/27/11 02:13 AM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
Every 5 lug 9 1/4" I've seen uses standard Mopar brakes.
Do you have a 6 lug Dakota rear?
My '99 and '00 Dakotas both came with 10" drums - 6-lug.
[Re: DoctorDiff]
#934282
02/27/11 08:16 AM
02/27/11 08:16 AM
Posts: 430 Michigan
HR3128
Mine is a 5 lug.
[Re: HR3128]
#934283
02/27/11 08:31 AM
02/27/11 08:31 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
Borrowed a chevy for a pts nite ,mopar was down . 12 sec nova .without c clips wasn't pretty . pic DR
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: Duner]
#934285
02/27/11 11:03 AM
02/27/11 11:03 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
10" drum 6 lug on my 01 R/T. I think some of the newer years came with Disks.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#934286
02/27/11 02:38 PM
02/27/11 02:38 PM
MattW
Ontario Canada
OK 1986 to 1990 5 lug 4.5 spacing 71/4 to 81/4 rears. 1991 to 2004 6 lug 4.5 spacing 8 1/4 to 9 1/4 rears. 2003 to 2004 rear disk And I am almost certain that all the drum brakes are the same spacing except for numbers of lugs. The problem is with the disk. There is different spacing requirements. Where the backing plate bolts to the housing. It is closer to the end of the housing on a drum than a disk.
[Re: Duner]
#934288
02/27/11 10:04 PM
02/27/11 10:04 PM
MattW
Ontario Canada
I converted my '99 Dakota to disk brakes using '94 Jeep Gran Cherokee parts. The spacing was perfect. No cutting or welding required. Just had to drill the hat for 6 lugs.
I got this info from Dakota Durango.com in the wheels brake and tire section.
[Re: Duner]
#934289
04/11/11 05:19 PM
04/11/11 05:19 PM
Posts: 13 Oxford, OH
Blue93Dakota
Oxford, OH
I did the same thing after you did. Would that hold the axle in if it broke?
93 Dakota Club Cab
R3 Turbo Build in progress
