Page 2 of 4 1 2 3 4
Re: "C" clip eliminators. [Re: DoctorDiff] #934237
02/22/11 09:01 PM
02/22/11 09:01 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I would replace the housing ends and run custom axles with Green wheel bearings.
So is there stuff to upgrade your 9 1/4 so it can handle 700 hp or are you better off going to a Dana.
Re: "C" clip eliminators. [Re: MattW] #934238
02/22/11 09:45 PM
02/22/11 09:45 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Dana 60 out of 93 Dodge RAM 250 HD. I know for a fact the ones Norfolk Southern had had the Dana 60 HD and had the tone ring. HAD HAD HAD LOL
Just find one of these and buy axles and housing ends. Or just buy a complete rear with brakes for $1,500. Pyle Bros used to advertise these in ND.
Leon
Re: "C" clip eliminators. [Re: Leon441] #934239
02/22/11 09:59 PM
02/22/11 09:59 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Thanksfor the info Leon. Is there support for the 9 1/4 as there is for the Ford 8.8.
Something for the guy running sub 11 sec. but not all out that would reqire a Dana.
Re: "C" clip eliminators. [Re: MattW] #934240
02/22/11 10:43 PM
02/22/11 10:43 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I'm sure there are some drive train experts on this sight that can shed some light on your question, but in my opinion: If there is a weak link with the 9 1/4, I would say it is the "C" clip axle retention system. The diff itself is plenty stout to handle 700HP and well beyond. Definitely stronger than the 8 3/4 in every respect. Problem is it came mostly in truck applications. Early muscle cars came with the 8 3/4 or the Dana 60, so most up grade / after market stuff was directed towards those 2 axles. Although you can now buy gears up to at least 4.56:1 for the 9 1/4, no one makes a spool for it yet and it appears no "C" clip eliminator kits - you have to have something special made? My car, like many late B body cars, came with the 9 1/4. Way overkill for the HP these cars were making from the factory. They may eventually be utilized more in the drag racing arena, simply because they are plentifull, cheap, and strong enough to handle some HP.
Fastest 300
Re: "C" clip eliminators. [Re: Leon441] #934241
02/22/11 10:46 PM
02/22/11 10:46 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Leon
As in...Ditch the 9.25
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: "C" clip eliminators. [Re: Crizila] #934242
02/23/11 01:14 AM
02/23/11 01:14 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Dana 60 housing and a trip to Comp Chassis in Glendale and it was problem solved for me!
Re: "C" clip eliminators. [Re: J_BODY] #934243
02/23/11 11:22 AM
02/23/11 11:22 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Great, But I don't have a problem. I've run the 9 1/4 in my car for over 4 years now with 4 different gears in it ( and one clutch change )and it's been working great. Made the tools ( that slide down the axle tubes ) for setting side bearing preload and backlash as well as a holding fixture for the yoke for setting pinion bearing preload. With these 2 tools, the 9 1/4 is as easy to set up as any diff - in my own garage.
Fastest 300
Re: "C" clip eliminators. [Re: Crizila] #934244
02/23/11 11:25 AM
02/23/11 11:25 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A 9 1/4" rearend is pretty stout when you run billet housing ends, custom axles with Green bearings, Detroit Locker and a crush sleeve eliminator.
Re: "C" clip eliminators. [Re: DoctorDiff] #934245
02/23/11 11:31 AM
02/23/11 11:31 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I've already got the locker. Are the billet ends, green bearings and custom axles readily available? Or is it all custom made to fit, one at a time special build stuff.
Can I pick up the phone and just order these?
Re: "C" clip eliminators. [Re: Crizila] #934246
02/23/11 12:35 PM
02/23/11 12:35 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Who has installed them in a 9 1/4? Are they necessary for an 11 second car? Thanks, John
The real need for the eliminators has NOTHING to do with the c-clips - the clips don't fail, they don't pop out, and the button doesn't break off the end - it's a failure elsewhere that is the problem. What breaks is the axle itself - an axle of that strength would fail, c-clip or not. Granted, once the axle breaks, then you can lose the wheel/tire and the problem starts, but it wasn't the clips that failed. Put in strong enough axles and the clips are never an issue. Sometimes the whole diff explodes; again, nothing to do with the c-clips. As to your situation, I'd look into stronger axles for the most bang-for-the-buck. If your wallet allows, the strongest way is as others have mentioned - new ends, bearings, and axles.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: "C" clip eliminators. [Re: Duner] #934247
02/23/11 01:37 PM
02/23/11 01:37 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: "C" clip eliminators. [Re: Adobedude] #934248
02/23/11 01:42 PM
02/23/11 01:42 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
With extra butter, please
Re: "C" clip eliminators. [Re: Evil Spirit] #934249
02/23/11 01:58 PM
02/23/11 01:58 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Housing ends are off the shelf. Custom axles are 3-4 day turn around.
All I need to know is your desired housing or assembly width and bolt pattern.
Ford 9" (Daytona) crush sleeve eliminator kit works nicely with a slight modification. 1350 U-bolt yokes are also readily available (29 spline 8 3/4" application).
Of course, you must have a shop change the housing ends with an alignment jig. I could probably rent out one of my jigs if someone wanted to do the fab work themselves.
Please E-mail me for more information.
Re: "C" clip eliminators. [Re: DoctorDiff] #934250
02/23/11 02:02 PM
02/23/11 02:02 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
At that point they just have to make sure the ends that they use match the brakes that they have, or they will need to find new brakes.
Re: "C" clip eliminators. [Re: Evil Spirit] #934251
02/23/11 06:20 PM
02/23/11 06:20 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks Evil Spirit and DoctorDiff. All good info on the 9 1/4. I don't plan on running my existing car faster than 11.50, so I'm not sure the work ( axles, new retainer style housing ends )to upgrade my existing unit is necessary. Just doesn't appear to be a lot of breakage in my ET / HP range. Still gonna get some numbers together though for the mods you mentioned.
Fastest 300
Re: "C" clip eliminators. [Re: DoctorDiff] #934252
02/23/11 07:16 PM
02/23/11 07:16 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Thanks for the info. I'll be contacting you very soon.
I've been skirting the rules and pretending that my disc brake setup was a positive axle retention device. LOL At present - my rig doesn't hook well enough to break the axles, but there's always a first time and I don't want to be along for the ride. It broke the factory LSD carrier in half on a good launch so that's where the locker came from. Hopefully the backing plates for the disc brakes will still work with the new housing ends.
Re: "C" clip eliminators. [Re: Evil Spirit] #934253
02/23/11 11:34 PM
02/23/11 11:34 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Luckily, 8 3/4" housing ends fit OEM 9 1/4" brakes.
Re: "C" clip eliminators. [Re: Duner] #934254
02/23/11 11:54 PM
02/23/11 11:54 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I smell a need for kit...There's gonna be more Dakota guys in the 10's and some in the 9's pretty soon, all running 9.25 rear ends.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: "C" clip eliminators. [Re: Adobedude] #934255
02/24/11 01:59 AM
02/24/11 01:59 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Doesnt the 9-1/4 have a "necked down" axle that gets pretty small near the splines?
Re: "C" clip eliminators. [Re: DaKuda] #934256
02/24/11 11:25 AM
02/24/11 11:25 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Yes, Don't have the sizes in front of me, but they are BIG axles, even in the spline area. BTW, when I went to install 4.56 gears a few weeks ago, I had to grind the corner off of one tooth in order to slide the center pin in. Didn't have to do that with the 4.10 or smaller ( numerically ) ratios that I have used in the past?? If someone were to come up with a kit where I could use my existing brakes, that would be great.
Fastest 300
Page 2 of 4 1 2 3 4
