Re: Pinging six pack
[Re: charger RTSE]
#933380
02/21/11 01:13 AM
02/21/11 01:13 AM
RapidRobert
Car now pings when i step on it
where was the timing b 4. Will need more octane or stiffer springs. You used the vac gauge method for the initial then w that figure in hand shortened the slots to get 38 total w vac adv disconnected/plugged? EDIT if so might back off the total to 36 & if still pinging at WOT then octane/springs
[Re: charger RTSE]
#933381
02/21/11 12:38 PM
02/21/11 12:38 PM
Posts: 3,916 usa
lewtot184
usa
Basically a stock motor. Mopar performance dissy adjustable set at 18 deg.with brown and silver springs.Timing set at 20 deg before. I set it with a vacuume guage and it idles realy good. Rear carbs are factory 1/8 turned out on the idle screws. 6.5 power valve. Jets in cenre carb are 63. Car now pings when i step on it should i up the jet size to 65 what are others running or do i have to do something with the rear carbs.
a stock engine does not need that kind of timing. 8-10 degrees intitial is plenty. some of the "ignition advice" on this website is pure crap.
[Re: charger RTSE]
#933383
02/21/11 02:30 PM
02/21/11 02:30 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Do you have the vacuum advance connected ? If so disconnect and try it again .
[Re: 6PKRTSE]
#933385
02/21/11 04:51 PM
02/21/11 04:51 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
I'm going to guess he has over 40 degrees all in. Way too much.
If it pings only with the vac advance, try adjusting it.
I want my fair share
[Re: lewtot184]
#933386
02/21/11 06:15 PM
02/21/11 06:15 PM
Posts: 106 Australia
charger RTSE
Australia
a stock engine does not need that kind of timing. 8-10 degrees initial is plenty. some of the "ignition advice" on this website is pure crap.
Interesting may be i should set it at 8-10 deg initial and disregard the other advice on the net. It pings with vac advance disconnected and plugged. My diisy is adjustable set at 18 deg and initial 20 equaling 38. Should i try stepping up the center car jet from a 63 to a 65. thanks Steve
[Re: charger RTSE]
#933387
02/21/11 06:27 PM
02/21/11 06:27 PM
Posts: 153 Wpg, Mb, Canada
six-barrel
Wpg, Mb, Canada
If it truly a stock motor thats likely too much initial timing.
Have you tried the max vacuum test to see what the engine requires. (up the advance until max vacuum is established then back it down 1". While doing this you will need to keep adjusting the idle rpm).
Whats the cam duration @50?
If it's truly stock then 10-14 initial would be more appropriate. Depending on which heads but 38 degrees may be too high and depending on which springs are in the distributor your curve may be too aggressive.
[Re: charger RTSE]
#933388
02/21/11 10:03 PM
02/21/11 10:03 PM
Posts: 4,320 Prospect, PA
BSB67
Prospect, PA
"Car now pings...." Did it not ping before the 6 pack?
[Re: BSB67]
#933389
02/21/11 10:49 PM
02/21/11 10:49 PM
charger RTSE
Australia
It use to run realy rich before and rough never idled smoothly. Have you tried the max vacuum test to see what the engine requires. (up the advance until max vacuum is established then back it down 1". While doing this you will need to keep adjusting the idle rpm).
I adjusted the timing this way with a vac guage. Car now idles smooth as and more responsive. Will it make a differance is i up the jet size on the centre carb.? from 63 to 65 ?
[Re: charger RTSE]
#933390
02/22/11 09:42 AM
02/22/11 09:42 AM
RapidRobert
on the timing I'd set initial w the vac gauge method (max vac then back off 1 in hg while resetting your idle speed) then shorten the slots to get 36 total (vac adv disconnected/plugged) then play w springs staying just under the pinging point at WOT up thru the gears on your hottest/driest day) THEN plug in vac adv & work w it staying just under the pinging point at PART throttle (high vacuum) above the RPM where the springs (mech adv) are fulled advanced (3/32" allen wrench & CCW delays the start of the slope (needs higher vac to start it but the amt stays the same) and may need to further limit the arm travel (the amt) into the can by soldering strips of feeler gauge on either side of the notch or source a can w less vac (it's stamped on the arm (in dist degrees) & a can w ~7-9 might be a good start. You want the can for better mileage/cleaner plugs but it will take the most work of all the dist subsystems to get it spot on as it has 2 adjustments. Get the timing right THEN on to mixture (A/F meter-best, plug reading-so so). Want no pinging/overheating & better too rich (to a point) than too lean so yeah I'd exp w bumping the jets up
