Pinging six pack #933376
02/20/11 08:41 PM
02/20/11 08:41 PM
Australia
charger RTSE Offline OP
Australia
Basically a stock motor.
Mopar performance dissy adjustable set at 18 deg.with brown and silver springs.Timing set at 20 deg before. I set it with a vacuume guage and it idles realy good.
Rear carbs are factory 1/8 turned out on the idle screws.
6.5 power valve.
Jets in cenre carb are 63.
Car now pings when i step on it should i up the jet size to 65 what are others running or do i have to do something with the rear carbs.
Re: Pinging six pack [Re: charger RTSE] #933377
02/20/11 08:47 PM
02/20/11 08:47 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
That power valve seems kinda big.
'71 SSP - SOLD!
Re: Pinging six pack [Re: Mobarge] #933378
02/20/11 09:03 PM
02/20/11 09:03 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
That is the stock powervalve and he said it is a basicly stock engine.
Re: Pinging six pack [Re: charger RTSE] #933379
02/20/11 09:50 PM
02/20/11 09:50 PM
GomangoCuda Offline
GomangoCuda  Offline
Have you read this? Might help. http://www.moparts.org/Tech/Archive/elec/29.html
Have you checked the actual total timing with a light?
What axle gear ratio are you using? Torque Converter?
I normally use 65 or 66 jets in the center carb on 6pks.
Re: Pinging six pack [Re: charger RTSE] #933380
02/21/11 01:13 AM
02/21/11 01:13 AM
where was the timing b 4. Will need more octane or stiffer springs. You used the vac gauge method for the initial then w that figure in hand shortened the slots to get 38 total w vac adv disconnected/plugged? EDIT if so might back off the total to 36 & if still pinging at WOT then octane/springs
Re: Pinging six pack [Re: charger RTSE] #933381
02/21/11 12:38 PM
02/21/11 12:38 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
6.5 power valve.
a stock engine does not need that kind of timing. 8-10 degrees intitial is plenty. some of the "ignition advice" on this website is pure crap.
Re: Pinging six pack [Re: charger RTSE] #933382
02/21/11 01:23 PM
02/21/11 01:23 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Check the total timing, seems like the Mopar Performance distributors have a lot of timing advance built into them. If you are set at 18* initial, it's probably over 40* total timing which will ping like crazy.
Re: Pinging six pack [Re: charger RTSE] #933383
02/21/11 02:30 PM
02/21/11 02:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
6.5 power valve.
Do you have the vacuum advance connected ? If so disconnect and try it again .
Re: Pinging six pack [Re: JohnRR] #933384
02/21/11 02:43 PM
02/21/11 02:43 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
6.5 power valve.
I agree I had a ping with my next sixpack engine last spring. I have a Mopar distributor. I disconnected the vac adv & ping went away.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Pinging six pack [Re: 6PKRTSE] #933385
02/21/11 04:51 PM
02/21/11 04:51 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I'm going to guess he has over 40 degrees all in. Way too much.
If it pings only with the vac advance, try adjusting it.
I want my fair share
Re: Pinging six pack [Re: lewtot184] #933386
02/21/11 06:15 PM
02/21/11 06:15 PM
Australia
Australia
6.5 power valve.
a stock engine does not need that kind of timing. 8-10 degrees initial is plenty. some of the "ignition advice" on this website is pure crap.
Interesting may be i should set it at 8-10 deg initial and disregard the other advice on the net.
It pings with vac advance disconnected and plugged.
My diisy is adjustable set at 18 deg and initial 20 equaling 38.
Should i try stepping up the center car jet from a 63 to a 65.
thanks Steve
Re: Pinging six pack [Re: charger RTSE] #933387
02/21/11 06:27 PM
02/21/11 06:27 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
If it truly a stock motor thats likely too much initial timing.
Have you tried the max vacuum test to see what the engine requires. (up the advance until max vacuum is established then back it down 1". While doing this you will need to keep adjusting the idle rpm).
Whats the cam duration @50?
If it's truly stock then 10-14 initial would be more appropriate. Depending on which heads but 38 degrees may be too high and depending on which springs are in the distributor your curve may be too aggressive.
Re: Pinging six pack [Re: charger RTSE] #933388
02/21/11 10:03 PM
02/21/11 10:03 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
6.5 power valve.
"Car now pings...." Did it not ping before the 6 pack?
Re: Pinging six pack [Re: BSB67] #933389
02/21/11 10:49 PM
02/21/11 10:49 PM
Australia
Australia
6.5 power valve.
It use to run realy rich before and rough never idled smoothly.
I adjusted the timing this way with a vac guage.
Car now idles smooth as and more responsive.
Will it make a differance is i up the jet size on the centre carb.? from 63 to 65 ?
Re: Pinging six pack [Re: charger RTSE] #933390
02/22/11 09:42 AM
02/22/11 09:42 AM
on the timing I'd set initial w the vac gauge method (max vac then back off 1 in hg while resetting your idle speed) then shorten the slots to get 36 total (vac adv disconnected/plugged) then play w springs staying just under the pinging point at WOT up thru the gears on your hottest/driest day) THEN plug in vac adv & work w it staying just under the pinging point at PART throttle (high vacuum) above the RPM where the springs (mech adv) are fulled advanced (3/32" allen wrench & CCW delays the start of the slope (needs higher vac to start it but the amt stays the same) and may need to further limit the arm travel (the amt) into the can by soldering strips of feeler gauge on either side of the notch or source a can w less vac (it's stamped on the arm (in dist degrees) & a can w ~7-9 might be a good start. You want the can for better mileage/cleaner plugs but it will take the most work of all the dist subsystems to get it spot on as it has 2 adjustments. Get the timing right THEN on to mixture (A/F meter-best, plug reading-so so). Want no pinging/overheating & better too rich (to a point) than too lean so yeah I'd exp w bumping the jets up
Re: Pinging six pack [Re: RapidRobert] #933391
02/22/11 12:10 PM
02/22/11 12:10 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
something else to look at is if the combustion chambers are getting oiled. check the plugs an look for some "oil tracks". the intake may not be sealing properly.
Re: Pinging six pack [Re: lewtot184] #933392
03/03/11 05:26 AM
03/03/11 05:26 AM
Australia
Australia
Well put in 67 jets in the center carb now no pinging.
Timing is set at 12 initial and 22 in the dissy total 34. I might try bumping up the initial to 14 to give me a total of 36.
Re: Pinging six pack [Re: charger RTSE] #933393
03/03/11 06:15 AM
03/03/11 06:15 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Ken at Hensley performance said that a good guideline is to use a power valve that is half the number of your idle vacuum. If you idle with 13 inches of vacuum, the 6.5 PV may be within the proper range. My 493 with the '509 cam has about 7-8" of vacuum and I have a 3.5 PV. Some believe that running rich is better than lean, but dumping too much fuel into the motor can and will result in scored rings, scuffed piston skirts and cylinder wall damage. The unburned fuel washes away the oil film on the cylinder walls. I dont profess to be a pro engine builder, but I have had some experience on this one. I am currently dealing with this very thing. I had an oil consumption problem and smoke on full throttle, and upon teardown, I found the situation I described. Tuning is everything. It may be beneficial to make friends with a guy at a smog shop. These guys can get you closer to ideal than we can.
Re: Pinging six pack [Re: RapidRobert] #933394
03/03/11 09:41 AM
03/03/11 09:41 AM
ky.
K
kenworth_goose Offline
K
ky.
You don't need to increase jet size, you need to get your timing where it belongs. About 14- is enough for a stock engine. You can dump all the fuel in it you want but you don't have a "lean" condition. You have too much timing. I had a 10 to 1 360 I built 8 years ago or so and I tried that. Didn't work, ran way better and quicker with 32-34 total timing. Actually picked up a half second when I dropped below 36 degrees. I couldn't believe it. It pinged as well but was far from being lean.
