Page 2 of 3 1 2 3
Re: 4bbl vs six pack [Re: lewtot184] #933340
02/22/11 12:31 PM
02/22/11 12:31 PM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
Because my wagon is a low-compression 73, I wasn't sure if a 6bbl setup would be worth anything performance-wise. It would look cool, though.
Earning every penny of that moderator paycheck.
DBAP
Re: 4bbl vs six pack [Re: not_a_charger] #933341
02/22/11 12:40 PM
02/22/11 12:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
probably not. I'd spend that cash on some new gutts for the motor.
Re: 4bbl vs six pack [Re: Mr.Yuck] #933342
02/22/11 01:22 PM
02/22/11 01:22 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Yes, the observations that the 6 pack is pricier is true. OTOH, the whole "you'll make more power with a 4bbl" thing; maybe, maybe not...it all depends on the motor, which aftermarket manifold and what you mean by "more power".
Read the first article I linked, I really like it because the tests were done at around 450hp which is very realistic for alot of enthusiasts. This is the only comprehensive dyno test of the various mopar manifolds that I'm aware of. My only gripe is that they didn't test a stock cast iron 4bbl intake and carb.
For those who can't be bothered to read it;
Offy dual port - 412hp/436ft lbs
offy dual quad - 425/431
Edelbrock performer - 439/455
Weiand Team G - 442/437
Weiand Action Plus - 442/452
Eddy DP4B - 445/456
Mopar 6 Pack - 450/459
Eddy Performer RPM - 451/457
Eddy TM6 - 452/449
Weiand Tunnel Ram - 453/455
Holley Street Dominator - 455/449
Mopar M1 and Eddy Victor - 456/449
Edelbrock Torker - 457/456
...As you can see the 6 pack (on this setup, anyway) is within 7hp of the best aftermarket setup tested but has the highest peak torque of all of them. 3 of them give up 10 ft lbs to get 2-6 hp more which is no win. The tunnel ram; well, it's a tunnel ram and few people want to have thier carbs sticking through thier hood so that leaves the torker and the RPM as the only real equals.......not bad considering the 6 Pack is a stock setup.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 4bbl vs six pack [Re: stateroadhog] #933343
02/22/11 07:19 PM
02/22/11 07:19 PM
NY
W
WICKD6PK Offline
WICKD6PK  Offline
W
NY
6 pk allllllll the way
Re: 4bbl vs six pack [Re: Mr.Yuck] #933344
02/22/11 09:15 PM
02/22/11 09:15 PM
Kinda what I was thinking. The motor runs fine now. I actually hope to do a pump gas stroker for it in the next few years. Had never thought about a 6bbl for it until I read this thread.
DBAP
Re: 4bbl vs six pack [Re: not_a_charger] #933345
02/22/11 09:26 PM
02/22/11 09:26 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
MAKE MINE a single 4 ....with a big Plastic-Fantastic ...
BUT for those who prefer a 6P ....I have JUST the intake ferr you ....
ONE that is welded UP for max wedge heads ...
Re: 4bbl vs six pack [Re: dOoC] #933346
02/22/11 10:24 PM
02/22/11 10:24 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Simple solution:
Money, not being an option - run the "six pack"
It guarantees MORE smiles per mile.
OR
Run the single 4bbl and high flow manifold. The
power factor is phenominal and budget conscious.
Either way, it's a win-win situation!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 4bbl vs six pack [Re: HYPER8oSoNic] #933347
02/22/11 10:30 PM
02/22/11 10:30 PM
michigan woods
imfixinmopars426 Offline
michigan woods
open the hood,for yourself,or for the buddys,and no one cares about the eddy rpm,and a holley.....440+6 rocks!
Re: 4bbl vs six pack [Re: DPelletier] #933348
02/22/11 10:36 PM
02/22/11 10:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Eddy DP4B - 445/456
Eddy TM6 - 452/449
At this power level, IMO the DP4B is the better choice than the RPM. The rpm gives up a small amount of torq down low because it's ports are needlessly large for a a guy running stock/unported or only mildly touched up stock heads. The DP4B looks like a stock intake and only gives up 5hp at peak rpm to the RPM intake but makes more down low. You're always looking for the bottleneck, and so long as you run stock heads, any 1/2 decent aftermarket intake is NOT where the flow bottleneck is. At least with the DP (ch4b if you're doing a 440) you don't have the hood clearance issues, etc.
Re: 4bbl vs six pack [Re: DaytonaTurbo] #933349
02/23/11 01:56 AM
02/23/11 01:56 AM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
I'll have the Fettucini!!
Re: 4bbl vs six pack [Re: lokalik] #933350
02/23/11 10:16 AM
02/23/11 10:16 AM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
i'll add one more for the 6pk. it's very cool,love the sound when they all come in and the mpg while crusing on the center kicks a 4brls azz. when i had a 4barl 12 to 15 was the best mpg crusing, 20 to 22 mpg with the 6pk crusing. more is better.
This is the kinda info I'm looking for on this subject...Looking cool, going fast, AND getting improved MPG when cruising... Any more MPG numbers out there to share?
[oo]======[oo]
Re: 4bbl vs six pack [Re: Scatransit] #933351
02/23/11 10:45 AM
02/23/11 10:45 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
16 mpg with 3.55s. 0.80 4th gear, 26" tire, 400 rear wheel hp. 416 small block
I think the point many are missing about the six pack - a properly tuned one that is - besides the gas mileage - is the roll on/acceleration [power] a six pack produces that the seatofthepantsometer will confirm - a four barrel can't even come close to...It's like having a passing gear. Just ask those fools in their new corvettes who get suckered from a roll by that old muscle car. .
Reminder we are discussing street cars not drag race cars.
Re: 4bbl vs six pack [Re: ThermoQuad] #933352
02/23/11 12:17 PM
02/23/11 12:17 PM
Marion, SC USA
69RR383 Offline
69RR383  Offline
Marion, SC USA
Properly tuned, a six pack will definitely put a smile on your face both from performance and looks. Add a 4-speed and you have twice the fun
Re: 4bbl vs six pack [Re: 69RR383] #933353
02/23/11 01:45 PM
02/23/11 01:45 PM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
We ran my car on the dyno a few years ago with the 4bbl. and then the 6bbl. Way better numbers with the 6bbl. The difference when you turn it on is awesome as others have said. You have to feel the results in order to appreciate what everyone is saying. 6bbls rock!
Re: 4bbl vs six pack [Re: Scatransit] #933354
02/23/11 02:10 PM
02/23/11 02:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
70 Charger 440/6 450 HP, DANA 60 4:10, 28" tire, Keisler 5spd TKO .64OD avg 22 MPG,....on the hand my Challenger T/A, 340/6 4" stroker 443 RWHP, factory 883 4spd, 3;91, 28" tire gets about 10 MPG
Re: 4bbl vs six pack [Re: DAYCLONA] #933355
02/23/11 02:12 PM
02/23/11 02:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that's because you have to spin the SB to get the HP numbers.
Re: 4bbl vs six pack [Re: ThermoQuad] #933356
02/23/11 02:27 PM
02/23/11 02:27 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
There is one CERTAIN CARB(with those big secondairies) .... that IS a passing-gear ...
Re: 4bbl vs six pack [Re: Mr.Yuck] #933357
02/23/11 02:29 PM
02/23/11 02:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Dosen't help with the 3:91's with a 1:1 ratio 4spd,.........the 440/6 with the Keisler 5spd .64OD turns those 4:10's into 2:65's....big difference
Re: 4bbl vs six pack [Re: Scatransit] #933358
02/23/11 03:00 PM
02/23/11 03:00 PM
cataclysm80 Offline
cataclysm80  Offline
1970 340 'Cuda 4 barrel automatic trans with cruise control on = 14 MPG highway miles for me.
Same car swapped to a six barrel with cruise still on = 16 MPG highway miles for me.
4 barrel is 2 barrels + 2 secondaries.
6 barrel is 2 barrels + 4 secondaries = more seat of pants feel.
6 barrel is more expensive and you'll have to learn to tune it to get it set right the first time. (I haven't had to make any adjustments to mine since I put it on about 5 years ago.) 6 barrel has the WOW factor.
Tav
Re: 4bbl vs six pack [Re: cataclysm80] #933359
02/23/11 03:07 PM
02/23/11 03:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Looks good against hi-impact colors too.
Page 2 of 3 1 2 3
