Flywheel question #932744
02/19/11 11:26 PM
02/19/11 11:26 PM
In a van, down by the river
jmf340 Offline OP
jmf340  Offline OP
I have a 69 340 Dart that I will be installing a 4 speed in. My question is which flywheel do I need to use with a stock set up and clutch? Is there an advantage to a heavier (50lb) variety flywheel? What was used from the factory, anyone know?
Got Mopar???
Re: Flywheel question [Re: jmf340] #932745
02/20/11 12:31 AM
02/20/11 12:31 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
http://www.americanpowertrain.com/Mopar/transmissions/flywheel.html
This list the sizes used and available. You might try calling Brewers.
I don't see an advantage to a heavy fw, but the steel fw is lower maintenance then aluminum. hope this helps
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Flywheel question [Re: jmf340] #932746
02/20/11 03:14 PM
02/20/11 03:14 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
For a stock to mild hp application, with no slicks, the stock 10.5" Borg/Beck style clutch is very adaquate.
A heavier flywheel helps with low end torque but inhibits building rpm's quickly. A 69 dart is not a heavy car, and with 3.55 gears, or higher numerically, you want the motor to spin up quickly. Small blocks that spool up quickly are the most fun.
If you were pulling tree stumps with a 3/4 granny geared 4 speed truck...........a heavy flywheel rules.
Re: Flywheel question [Re: Dean_Kuzluzski] #932747
02/20/11 03:18 PM
02/20/11 03:18 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
10.5 30 lb flywheel should be fine for your app.
Leave the gun.......take the Cannoli's....Mike
