Page 4 of 5 1 2 3 4 5
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: 1_WILD_RT] #932693
03/11/11 10:14 PM
03/11/11 10:14 PM
WI
W
wannadrag Offline OP
W
WI
Back up for the weekend
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932694
03/18/11 10:07 PM
03/18/11 10:07 PM
WI
W
W
WI
Friday bump
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932695
03/18/11 11:05 PM
03/18/11 11:05 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I'll try him again. His wife gave me the brush off last time I tried.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932696
03/19/11 01:16 AM
03/19/11 01:16 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I think your best bet, as someone mentioned eariler is to email a few pics to Rob Wolfe/ Randy Holden at MCG,.....the range of individuals seeing it in print would probally get you answer, and maybe an offer you can't refuse quicker
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: DAYCLONA] #932697
03/19/11 11:38 AM
03/19/11 11:38 AM
WI
W
W
WI
Email with pics sent off to MCG.I will let you guys know if i get any sort of reply as to what it is.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932698
03/19/11 04:49 PM
03/19/11 04:49 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Have to wait a bit longer, found out he's out of the country on a motorcycle tour and won't be back until mid April. He says he'll get back to me then.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: NicksGarage] #932699
03/25/11 10:48 PM
03/25/11 10:48 PM
WI
W
W
WI
No news so back up to the top
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932700
03/27/11 09:22 AM
03/27/11 09:22 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
another friendly bump to keep it alive.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: migsBIG] #932701
03/27/11 01:45 PM
03/27/11 01:45 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
Having worked in a foundry for 25 years my money is that it was made by an employee on the side. I made lots of things this way.
If you had an air cleaner to use as a pattern it is very possible. Put it in a box, fill it with core sand, let it cure, turn it over, remove the air cleaner. Do the same for the other side, clean it up, drill a hole & make a gate for the metal to go in, drill a couple of vents, paste the halves together & pour. Done!
The 2 posts look like part of the gate where it was poured, or it could be vents. It probably should have been ground off when it was made.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: express] #932702
03/27/11 02:13 PM
03/27/11 02:13 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
possibly a marine air cleaner? dan
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: ph23vo] #932703
03/27/11 03:08 PM
03/27/11 03:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What do you think it's worth ?
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: JohnRR] #932704
03/27/11 03:12 PM
03/27/11 03:12 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
250.00 ish... its neat.. dan
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: ph23vo] #932705
03/27/11 03:13 PM
03/27/11 03:13 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
possible its off a jensen interceptor SP?
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: ph23vo] #932706
03/27/11 05:11 PM
03/27/11 05:11 PM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
I need it
Stand behind your word
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: ph23vo] #932707
03/27/11 10:32 PM
03/27/11 10:32 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I tend to agree with the statement made by "express".
It is likely just something made up by someone who had the time and capabilities to do it.
My contact at Fram in Canada where all the Chrysler air cleaners where manufactured, and who worked in the hobby shop design area, told me they never had a need to have anything aluminum like that in house.
Everything including prototypes was steel as per design blueprint.
Also I doubt it's a marine air cleaner......here's a real deal metal marine 440-6 air cleaner.
Anyone else one have one of these?
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: mccannix] #932708
03/27/11 11:49 PM
03/27/11 11:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That sounds like a pretty darn good source.
I'd think there's still a slight possibility of something done on the Chrysler side; like styling dept. Pretty slight at this point.
Mccannix, do you think your source seals the deal or would another non-Fram 2nd source make things more concrete.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: autoxcuda] #932709
03/27/11 11:59 PM
03/27/11 11:59 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I'm just relating what was told to me by the original manufacturer.
Any and all opinions are obviously welcome as it is a pretty neat piece.
Here's hoping some others posting here earlier have additional info to add.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: mccannix] #932710
03/28/11 12:20 AM
03/28/11 12:20 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Does your contact at Fram know anything about the painting of the air cleaners, especially the wrinkle ones? My contact from Chrysler said that Canadian Fram did the whole thing.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: NicksGarage] #932711
03/28/11 08:40 AM
03/28/11 08:40 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I'll try to talk to him this week and get an answer to that question.
I'm quite sure he told me once that they outsourced any specialized paint procedures.
They painted all the black enamel bases and orange lids but had trouble getting the argent paint to lay down on the shaker scoops and after the first 100 or so, sent them elsewhere for painting.
Same may be true for the wrinkle finish air cleaners.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: mccannix] #932712
04/01/11 11:12 PM
04/01/11 11:12 PM
WI
W
W
WI
Weekend bump
