1970 E-Body Seat Belts
#932438
02/19/11 05:44 PM
02/19/11 05:44 PM
Posts: 1,025 NJ
EV2RTSE
NJ
Can anyone list the standard seat belt part numbers (label numbers) for a 1970 E-Body? Thanks.
Re: 1970 E-Body Seat Belts
[Re: plumcrazydave]
#932440
02/20/11 12:20 PM
02/20/11 12:20 PM
Posts: 1,025 NJ
EV2RTSE
NJ
Your picture helps a lot, thanks. If I made out the 7-digit numbers correctly, I think I have everything figured out:
2999587 (4749) - Front lap, male, with retractor 2999588 (4747) - Front shoulder, male 2999585 (4752) - Front lap and shoulder combined, female
2999631 (4770) - Rear lap, male 2999631 (4770) - Rear lap, female
I also have:
2999596 (4760) - Does anyone know if this is for the center belt for a bench seat car? My car has buckets, but most of the original belts were missing so I tracked down some extras and these were included.
[Re: EV2RTSE]
#932441
02/20/11 08:02 PM
02/20/11 08:02 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
You are correct! Those part numbers are the center tunnel belts in a bench seat equipped vehicle!
[Re: Convertcuda]
#932443
02/21/11 12:01 AM
02/21/11 12:01 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Someone took the seat belts from my car when I bought it. The car is a Hamtrack built car. Production date is April 21, 1970. E-body convertible. Would should the date code be on the seat belts? Thanks.
Hi Ken! The date for your seat-belts should be the first quarter of 1970 or 1-1970. It is also possible that they could have been the fourth quarter of 1969 or 4-1969. Hope this helps!
(I will give you a call to discuss those other decals tomorrow afternoon if that works for you.)
[Re: Convertcuda]
#932445
02/21/11 12:14 AM
02/21/11 12:14 AM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
If the originals are gone, there is no way to know for certain what it came with.
The low mile T/A has a scheduled production date of 406 & the belts in it were a mix - 1969-3 & 1970-1.
[Re: Alaskan_TA]
#932446
02/21/11 12:55 AM
02/21/11 12:55 AM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
....which is why he needs to default to the protocol build schedule. According to the original manufacturer, seat belts were typically manufactured one quarter behind the actual build date of the vehicle. Varying demand for certain belts caused the mix match in the dates. They used them as they were ordered! His other option would be to play it safe and leave them off!
