1970 E-Body Seat Belts #932438
02/19/11 05:44 PM
02/19/11 05:44 PM
NJ
EV2RTSE Online content OP
EV2RTSE  Online Content OP
NJ
Can anyone list the standard seat belt part numbers (label numbers) for a 1970 E-Body? Thanks.
Re: 1970 E-Body Seat Belts [Re: EV2RTSE] #932439
02/20/11 01:17 AM
02/20/11 01:17 AM
Lakewood, CO
plumcrazydave Offline
Lakewood, CO
These are from 70 chally coupe built April of 70
Hope they help
Re: 1970 E-Body Seat Belts [Re: plumcrazydave] #932440
02/20/11 12:20 PM
02/20/11 12:20 PM
NJ
NJ
Your picture helps a lot, thanks. If I made out the 7-digit numbers correctly, I think I have everything figured out:
2999587 (4749) - Front lap, male, with retractor
2999588 (4747) - Front shoulder, male
2999585 (4752) - Front lap and shoulder combined, female
2999631 (4770) - Rear lap, male
2999631 (4770) - Rear lap, female
I also have:
2999596 (4760) - Does anyone know if this is for the center belt for a bench seat car? My car has buckets, but most of the original belts were missing so I tracked down some extras and these were included.
Re: 1970 E-Body Seat Belts [Re: EV2RTSE] #932441
02/20/11 08:02 PM
02/20/11 08:02 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
You are correct! Those part numbers are the center tunnel belts in a bench seat equipped vehicle!
Re: 1970 E-Body Seat Belts [Re: ECS] #932442
02/20/11 11:53 PM
02/20/11 11:53 PM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Someone took the seat belts from my car when I bought it. The car is a Hamtrack built car. Production date is April 21, 1970. E-body convertible. Would should the date code be on the seat belts? Thanks.
Re: 1970 E-Body Seat Belts [Re: Convertcuda] #932443
02/21/11 12:01 AM
02/21/11 12:01 AM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Hi Ken! The date for your seat-belts should be the first quarter of 1970 or 1-1970. It is also possible that they could have been the fourth quarter of 1969 or 4-1969. Hope this helps!
(I will give you a call to discuss those other decals tomorrow afternoon if that works for you.)
Re: 1970 E-Body Seat Belts [Re: ECS] #932444
02/21/11 12:13 AM
02/21/11 12:13 AM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Thanks for the help Dave. I will be getting those from you.
Ken
Re: 1970 E-Body Seat Belts [Re: Convertcuda] #932445
02/21/11 12:14 AM
02/21/11 12:14 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If the originals are gone, there is no way to know for certain what it came with.
The low mile T/A has a scheduled production date of 406 & the belts in it were a mix - 1969-3 & 1970-1.
Re: 1970 E-Body Seat Belts [Re: Alaskan_TA] #932446
02/21/11 12:55 AM
02/21/11 12:55 AM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
....which is why he needs to default to the protocol build schedule. According to the original manufacturer, seat belts were typically manufactured one quarter behind the actual build date of the vehicle. Varying demand for certain belts caused the mix match in the dates. They used them as they were ordered! His other option would be to play it safe and leave them off!
Re: 1970 E-Body Seat Belts [Re: ECS] #932447
02/21/11 10:11 AM
02/21/11 10:11 AM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
were the belts provided to the assembly line as sets
or were they in individual bins that the worker had to pull as needed per application/position?
id guess the first option
also, was there a "bin" of spares in case a belt was damaged, incorrect or mistakingly left out of a set?
i would think the above could also provde for out of the norm mis matched sets, of course not to be duplicated when you have nothing, but helps explains some oddities on assumed original cars
thanks
