Tranny fluid question
#931460
02/18/11 01:31 AM
02/18/11 01:31 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
If Im way off base with this question, please forgive me.... Does the type of tranny fluid play any part in the clutch setting? In other words does Type F make the clutches act as if they are set up tighter than if you use Dexron or something else?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Tranny fluid question
[Re: cudadon]
#931462
02/18/11 10:56 AM
02/18/11 10:56 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I think it was Jim @ ATI that told me to run a good brand type F in my ATI trans & converter also. I used the B&M trans fluid it is a type F and not much more than the others and they sell it at Advance.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Von]
#931465
02/18/11 12:31 PM
02/18/11 12:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think you guys didnt read his question... does it act light it makes them a tighter clutch set up... maybe I'm wrong... but I cant answer it
[Re: MR_P_BODY]
#931466
02/18/11 12:55 PM
02/18/11 12:55 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
You are correct,Mr.P.,... Type f is supposed to make the clutches slip less,due to the lack of additives that promote a little slip while applying,so it might seem like the clutches are set up a little tighter. Not sure if that helps or not?? Keith
[Re: Dunnuck Racing]
#931467
02/18/11 01:09 PM
02/18/11 01:09 PM
Von
NE Oklahoma
[ Type f is supposed to make the clutches slip less,due to the lack of additives that promote a little slip while applying,so it might seem like the clutches are set up a little tighter. Not sure if that helps or not?? Keith
That is what I was looking for, that helps a ton!!
So what fluid would make the clutches act the loosest?
[Re: Von]
#931468
02/18/11 02:22 PM
02/18/11 02:22 PM
Posts: 2,937 A shed in England
Tig
A shed in England
I thought all you guys over there were using John Deere Hygard? Has it become unpopular?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#931470
02/18/11 02:30 PM
02/18/11 02:30 PM
MR_P_BODY
I've never used it... I use cheapo type F
Von... cant say what would make it seem loosest
