magnum intake bolt spec from chrysler?
#930941
02/17/11 10:26 AM
02/17/11 10:26 AM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Anyone know the factory intake manifold bolt torque spec for the 5.2/5.9L magnum intake manifold (twelve 5/16 bolts)? One source I found indicated 72 in/lb, that sounded light to me. Thanks
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: magnum intake bolt spec from chrysler?
[Re: Rapid340]
#930942
02/17/11 10:41 AM
02/17/11 10:41 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
It is lite, 12 ft lbs. Use the factory torque procedure to get there too. Some say you have to use the factory torque to yield bolts, I've just used SS bolts for years.
Oh yeah...5/16-18 x 2 1/4" long
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#930943
02/17/11 10:44 AM
02/17/11 10:44 AM
Rapid340
oberlin, Ohio
Is the torque procedure different than LA intake?
[Re: Adobedude]
#930944
02/17/11 10:56 AM
02/17/11 10:56 AM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
Specs? Torque procedure?
I just bolt it down and go. ;>)
