413 cam shaft gears.?????????????? #930421
02/16/11 04:17 PM
02/16/11 04:17 PM
Newfoundland
mopar_man Offline OP
Newfoundland
Just pulled an old 413 I had in storgae out and have a look at it. Its a C413 also has ET41 stamped on the pad , 8 29 94.
Now the question is the cam is gear driven large gear on the cam small gear on the crank. Is this normal on 413s?
Re: 413 cam shaft gears.?????????????? [Re: mopar_man] #930422
02/16/11 04:52 PM
02/16/11 04:52 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it has just the 2 gears and no chain, I wonder if it was a reverse rotation marine engine? Or some H D industrial? dunno.
Re: 413 cam shaft gears.?????????????? [Re: buildanother] #930423
02/16/11 05:19 PM
02/16/11 05:19 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
THAT'S a typical RV/truck engine.
That set-up cost Mopar big-$$ compared to a cahin ... but they were KINGS of the market back then.
Re: 413 cam shaft gears.?????????????? [Re: buildanother] #930424
02/16/11 05:53 PM
02/16/11 05:53 PM
Newfoundland
Newfoundland
Thats the question, the cam is rotating opposite to the crank so that cam will not work in a 440 with a chain.
But it would be a great setup with no slack chain problems.
Doc says its a typical truck/RV engine, so if its typical , the 413 cams must be ground different if its a truck /RV engine . I can't recall tearing down a 413 car engine to see if it just had the two gears or a chain. anybody know if there is a diff ???/
Re: 413 cam shaft gears.?????????????? [Re: mopar_man] #930425
02/16/11 05:58 PM
02/16/11 05:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You could put that cam in any big block as long as you use the gears. Likewise you could use any cam in that block as long as you use a normal timing set.
Re: 413 cam shaft gears.?????????????? [Re: Stanton] #930426
02/16/11 06:36 PM
02/16/11 06:36 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
!!!! WAIT A MINUTE !!!!
Let's get this STRAIGHT!!!!
You are saying??
That there is a GEAR on the crank, and a GEAR on the cam, and NOTHING ELSE, no chain, no idler gears, etc?
THIS MEANS one of two things:
Either this is a reverse rotation marine engine
or
It's a normal rotation engine with a gear drive cam.
IF THIS IS TRUE you MAY NOT be able to use a standard distributor unless the dist. drive gear on the cam / driveshaft was ground 'reverse' to compensate.
YOU CAN EASILY tell if the distributor is "standard" CCW rotation for a BB / RB. Simply "spring" the mechanical advance. Easy---if the dist. is CCW rotation, you must "spring against the spring" CCW, and the spring will "pop back" CW
You can tell if the engine is reverse rotation by rotating it with a wrench and examining how the valve train operates.
If you have the starter, hook it to a battery and see which way it operates, then visualise it operating the flywheel. ---- OR --- "hand rotate" the starter drive to see which way it ratchets. (over runs). The starter obviously operates the other direction.
To put it differently, visualise the starter, as if you were viewing it installed, from the front of an engine. Visualize that as an engine starts (normal rotation) the flywheel rotates CW as viewed from the front. This means that the starter drive gear will be rotating CCW AND WILL RATCHET in that direction.
The chances of this being a "basackwards" engine is slim, but they do exist
Re: 413 cam shaft gears.?????????????? [Re: Yancy Derringer] #930427
02/16/11 08:10 PM
02/16/11 08:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Reverse rotation ... only the crank turns in reverse, everything else is normal. Only the firing order on the dist is reversed but the dist still rotates in the same direction ... it has to to drive the oil pump so it sucks instead of blows!
If its a reverse rotation engine then the dist. gear would be the same as any normal big block and so would the cam. The crank would be turning counterclockwise but the cam would be turning clockwise because of the gear drive.
Re: 413 cam shaft gears.?????????????? [Re: Stanton] #930428
02/16/11 09:19 PM
02/16/11 09:19 PM
Newfoundland
Newfoundland
OK I have to agree with you , as the piston only sees intake , compression, detonation, exhaust. the only thing that would change is that the piston notch that is facing forward
would now have to face toward the back of the block to stop piston slap?
Other than the starter motor and crank spinning "backward"and dist. setup nothing else really matters .
I have worked a fair amount on Jimmy diesels 71 series and 53 series engines . If you change rotation you have to change cams.
Re: 413 cam shaft gears.?????????????? [Re: Stanton] #930429
02/17/11 08:41 AM
02/17/11 08:41 AM
Newfoundland
Newfoundland
So, if its a reverse rotation 413 using just two mated gears, that cam is a standard cam , if its a normal rotation 413 using two mated gears, the cam has to be ground opposite(backwards)
Re: 413 cam shaft gears.?????????????? [Re: mopar_man] #930430
02/17/11 09:49 AM
02/17/11 09:49 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You got it sunshine!
My guess is its a reverse rotation motor and here's why ...
If its a reverse rotation motor the only things they had to change were a) the timing gears b) the starter and c) the firing order. Everything else stays the same ... cam, dist drive, oil pump, etc.
However, if its a standard rotation motor with a reverse rotation cam then they had to change a) the cam grind b) the timing gears and c) the dist drive gear. For what ... what advantage is a reverse rotation cam ?!?!?
Re: 413 cam shaft gears.?????????????? [Re: mopar_man] #930431
02/17/11 09:53 AM
02/17/11 09:53 AM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
If it's a reverse rotation engine with two mated gears, the cam turns in the normal rotation (and uses a standard distributor gear), but the lobes are positioned differently for the different firing order (1-2-7-5-6-3-4-8) that the crank throws require. This necessitates a different camshaft. Also, the reverse rotation crankshafts have a reverse angled knurl where the rear main seal rides, so if you install a reverse rotation crank in a standard rotation engine (or vice/versa), it will do a decent job of pumping oil out the back.
Re: 413 cam shaft gears.?????????????? [Re: cknight] #930432
02/17/11 10:05 AM
02/17/11 10:05 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Good point!
Re: 413 cam shaft gears.?????????????? [Re: Stanton] #930433
02/17/11 01:51 PM
02/17/11 01:51 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
Good point!
How so ? ..... what is diff here is the CAM, cam and crank gears and the distributor gear.
Re: 413 cam shaft gears.?????????????? [Re: mopar_man] #930434
02/17/11 05:55 PM
02/17/11 05:55 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Can you post some pics?
- Stu Harmon
Re: 413 cam shaft gears.?????????????? [Re: feets] #930435
02/17/11 09:24 PM
02/17/11 09:24 PM
Newfoundland
Newfoundland
Will get a pic tommorrow. The cam gear is so large It looks so close the the timing cover housing.
Re: 413 cam shaft gears.?????????????? [Re: mopar_man] #930436
02/18/11 06:25 PM
02/18/11 06:25 PM
Newfoundland
Newfoundland
ok . i got a pic of the cam gear and the pad , but the pics won't load . They are in jpg format. anyone know how to upload these so we can view them ?
Re: 413 cam shaft gears.?????????????? [Re: mopar_man] #930437
02/18/11 07:50 PM
02/18/11 07:50 PM
NC
Turbo W350 Offline
Turbo W350  Offline
NC
All 413 and 361 industrial engines used gear driven cams, nothing at all about odd here it's just a run of the mill 413 HD.
'85 W-350 Crew Cab, Turbocharged 440, NP435/205, 4.10 D60f/70r
Re: 413 cam shaft gears.?????????????? [Re: Turbo W350] #930438
02/18/11 07:54 PM
02/18/11 07:54 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
...sorry NOT ALL did ... quite-a-few ? ...Yes.
Re: 413 cam shaft gears.?????????????? [Re: IcorkSOAK] #930439
02/18/11 08:05 PM
02/18/11 08:05 PM
NC
Turbo W350 Offline
Turbo W350  Offline
NC
Yes they did, along with solid lifters, special heads and water pump for extra cooling, if it does hot have all these different parts then it's not a HD engine, just a car big block.
Re: 413 cam shaft gears.?????????????? [Re: Turbo W350] #930440
02/18/11 08:08 PM
02/18/11 08:08 PM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
Solid lifters ? .... WHERE did you come up with that ?
And I KNOW these engines ...I have ELEVEN of them.
