Anyone run an engine oil cooler? Pics? #928561
02/14/11 03:10 AM
02/14/11 03:10 AM
United States
STLDuster Offline OP
United States
Does anyone here run an engine oil cooler? If so how did you do it?
I am interested in seeing how it is done with a stock style oil pump.
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Anyone run an engine oil cooler? Pics? [Re: STLDuster] #928562
02/14/11 01:08 PM
02/14/11 01:08 PM
AndyF Offline
AndyF  Offline
You can do it like the factory did. They took oil out the back of the block and then just dumped it back at the fuel pump.
Re: Anyone run an engine oil cooler? Pics? [Re: AndyF] #928563
02/14/11 01:58 PM
02/14/11 01:58 PM
United States
United States
Oh that is a neat idea. Does anyone have any pictures of that setup? (or any others)
Re: Anyone run an engine oil cooler? Pics? [Re: AndyF] #928564
02/14/11 02:41 PM
02/14/11 02:41 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
does using that small size of line do anything compared to using one from a filter base adapter
home of the
Sox and Martin Hemi Duster
Re: Anyone run an engine oil cooler? Pics? [Re: AndyF] #928565
02/14/11 08:03 PM
02/14/11 08:03 PM
United States
United States
Does any one have pictures?
Re: Anyone run an engine oil cooler? Pics? [Re: STLDuster] #928566
02/14/11 09:04 PM
02/14/11 09:04 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Wouldn't the best way just be to buy an oil filter relocation kit and buy an oil cooler and splice the two together? This way the oil gets cooled after it's pumped but before it hits the rest of the engine. You could do the whole thing for about 100 bucks.
Re: Anyone run an engine oil cooler? Pics? [Re: DaytonaTurbo] #928567
02/14/11 09:17 PM
02/14/11 09:17 PM
IN
ahy Offline
ahy  Offline
IN
I don't have one but its on my things to do list. My plan is to use an oil filter sandwich adaptor which routes the full oil flow through the cooler mounted in front of the radiator then back the the filter base and oil circuit. Summit lists several adaptors for MOPAR. I would probably use 10 an lines.
This is also a handy way to plumb up an oil accumulator - also the approach recommended by Accusump.
An additional element that can be added is a thermostat which bypasses the cooler when the oil is cold. They are available built into the sandwich adaptor or as seperate elements to be plumbed in.
I'll be watching this post for ideas and comments.
Re: Anyone run an engine oil cooler? Pics? [Re: STLDuster] #928568
02/14/11 09:21 PM
02/14/11 09:21 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
36.00
http://www.glowshiftdirect.com/oil-coole...1_a_7cGS_d_OC02
home of the
Re: Anyone run an engine oil cooler? Pics? [Re: ahy] #928569
02/15/11 02:45 AM
02/15/11 02:45 AM
United States
United States
That is exactly how I was thinking about doing it but I didn't know if there was a better way to go about it. Sounds like it is the way to go.
I would like to put an oil temp gauge in either before or after a cooler to keep an eye on the entire system. Probably overkill though.
Re: Anyone run an engine oil cooler? Pics? [Re: STLDuster] #928570
02/15/11 07:15 PM
02/15/11 07:15 PM
scratchnfotraction Offline
I use the stock mopar oil cooler off a 88 gran fury cop car that had a sb,but have it on the 440 now also
it hooks a line right to the oil sender passage with a hard line and fitting,then turns to high presure rubber hose,then back to a hard line
has a tee for the carb choke relay and a stock oil sender to dash
another high pressure hose/hardline with a flar fitting/bushing.short 1/4" steel nipple/pipe fitted to a hollow fuel pump bolt
not sure about the mopar hollow fuel pump bolt,but you can still get the hoses at napa,I used some seel line and comp fittings to plumb it to fit the truck
the cooler is a stacked plate style and is rather small looking,but disapates a lot of heat,this could be replaced with aftermarket and larger capacity
the hollow bolt is the key to the hook up,I have only found it in the JY on cop cars from the mid 80s
Re: Anyone run an engine oil cooler? Pics? [Re: scratchnfotraction] #928571
02/15/11 08:24 PM
02/15/11 08:24 PM
AndyF Offline
AndyF  Offline
Right, the hole in the hollow bolt has to be small enough to keep the oil pressure at a reasonable level. If the there isn't enough flow resistance in the oil cooler path then the oil pressure drops too much.
Re: Anyone run an engine oil cooler? Pics? [Re: scratchnfotraction] #928572
02/17/11 01:12 AM
02/17/11 01:12 AM
United States
United States
has a tee for the carb chock relay and a stock oil sender to dash
You wouldn't happen to be able to get a picture of the fuel pump bolt would you? If you could I would greatly appreciate it!
Re: Anyone run an engine oil cooler? Pics? [Re: STLDuster] #928573
02/17/11 08:19 AM
02/17/11 08:19 AM
yes its on the shelf,i will get some postd up of the bolt and the fittings for the hard lines
Re: Anyone run an engine oil cooler? Pics? [Re: STLDuster] #928574
02/17/11 07:32 PM
02/17/11 07:32 PM
Vallejo California
T748 Offline
super street
T748  Offline
super street
Vallejo California
I have a setup thats a bit different than most. I have the heat exchanger style cooler that uses the cooling system to stabilize oil temps. These are a bit expensive new, but can be found on ebay at a good price. If you run a cement filled block these are good for getting the oil up to temperature and holding it steady. It can be seen here on the upper radiator hose.
If your interested (PM me)I have a sandwich style oil cooler adapter I'd let go for cheap. It has 10 An fittings with it. I ended up going with an remote filter, so this ended up on the shelf. -Tom.
Re: Anyone run an engine oil cooler? Pics? [Re: scratchnfotraction] #928575
02/17/11 11:08 PM
02/17/11 11:08 PM
here are the pics of a stock cooler and lines
note the hole size in the hollow bolt
and the double tee is the way it came with the 2 senders as it came out of the block
Re: Anyone run an engine oil cooler? Pics? [Re: scratchnfotraction] #928576
02/17/11 11:09 PM
02/17/11 11:09 PM
Re: Anyone run an engine oil cooler? Pics? [Re: scratchnfotraction] #928577
02/17/11 11:10 PM
02/17/11 11:10 PM
Re: Anyone run an engine oil cooler? Pics? [Re: scratchnfotraction] #928578
02/17/11 11:11 PM
02/17/11 11:11 PM
brass invert flare fitting in the block high presure rubber/hard line
Re: Anyone run an engine oil cooler? Pics? [Re: scratchnfotraction] #928579
02/17/11 11:24 PM
02/17/11 11:24 PM
hollow bolt/pipe nipple/invert flare fitting
stubs it out from behind the FP for the high pressure/hard line return
its for longevity at sustained idle time lubing the fp ecentric,t-chain,lowering oil temps and oils at full psi in the heavy duty cooling package on cop cars
whats funny is this 88 gran fury 318-4v cop engine had a windage tray and a 4 qrt car oil pan/90* oil filter adaptor but would take 5.5 qrts to read full when lines were flushed out with oil change
Re: Anyone run an engine oil cooler? Pics? [Re: scratchnfotraction] #928580
02/18/11 01:03 AM
02/18/11 01:03 AM
United States
United States
That is a huge help! Thank you!
