New AFCO shocks = New Best 60 foots and ETs. #928126
02/13/11 09:10 PM
02/13/11 09:10 PM
Rancho Cucamonga, Calif.
P
PUNK Offline OP
PUNK  Offline OP
P
Well we just purchased and installed some new AFCO double adjustable rear shocks on the Cuda and we are happy to say the least. The Cudas prior best 60 foot time was 1.402 and it only did that once when the conditions were all absolutely perfect and all the stars and moons were in alignment. The regular times were like 1.42-1.44 when the old shocks were ok. Then the car started losing 60 foot really bad and was hard to get it in the 1.4s at all. Eric is a member here at Moparts (Irun6snd8th)?? and he arranged the shocks to be made for us as they werent in stock at AFCO. They had them to us in less than a week. Now the car just went 1.37 sixty foot with a whole bunch of 1.40 sixty foots when the track started going away. Nice wheelies all day long. I was running a single adjustable rear shock that was OK at first but obviously went away in no time at all. I cant say enough for the product and the tech support from Eric. The other Eric at Afco as well.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928127
02/13/11 09:17 PM
02/13/11 09:17 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
thats great..mike
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928128
02/13/11 09:18 PM
02/13/11 09:18 PM
ohio
all spooled up Offline
ohio
what was the et
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928129
02/13/11 09:20 PM
02/13/11 09:20 PM
What settings did you start out with Compression and extention?
Are you 4 linked , ladder barred or Cal tracs?
Eric is a fantastic guy., He has hooked me up too. I had 1.40 1.39 60 foots and now 1.29-1.33 all with his shocks AFCO double adjustables are the bomb! Thanks Eric.
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928130
02/13/11 09:27 PM
02/13/11 09:27 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
THAT'S what I want.....where's that shock seminar-thingy at!!??
If you like drag racing, support your local track.
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: CHAPPER] #928131
02/13/11 09:33 PM
02/13/11 09:33 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I was wondering the same thing .
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: justinp61] #928132
02/13/11 09:40 PM
02/13/11 09:40 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Wish I could pick up on my 60 like that.
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928133
02/13/11 09:42 PM
02/13/11 09:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Arent good shocks the greatest... surprising what
can happen with good shocks
Re: New AFCO shocks = New Best 60 foots and ETs. #928134
02/13/11 09:45 PM
02/13/11 09:45 PM
P
PUNK Offline OP
PUNK  Offline OP
P
The Cuda now has a 10.53 ET best with a bunch of 10.54s and 10.55s. The prior best was 10.62 in much better air. The car has Cal-Tracs Monoleafs and Caltrak bars set on the top hole . We started the shock settings at full loose on the extension and 7 clicks stiff on the compression. The car seemed to like it and since it was a bracket race, we didnt make any adjustments. We are very happy with the 1.37-1.38 times out of the little tires and good shocks.
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928135
02/13/11 10:00 PM
02/13/11 10:00 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
What springs are on the shocks?.
Did you try other spring rates too?
Good info
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: toddd] #928136
02/13/11 10:04 PM
02/13/11 10:04 PM
P
PUNK Offline OP
PUNK  Offline OP
P
Its a leaf spring car, so no spring rates were changed.
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928137
02/13/11 10:21 PM
02/13/11 10:21 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
More impressive as the story continues....
I want some...
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928138
02/13/11 10:33 PM
02/13/11 10:33 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
nice looking car witch eric u delt with the 1 from here or the 1 from afco i would like a pair
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: one bad fish] #928139
02/13/11 10:46 PM
02/13/11 10:46 PM
P
PUNK Offline OP
PUNK  Offline OP
P
We dealt with (Irun6snd8th) Eric.
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928140
02/13/11 10:49 PM
02/13/11 10:49 PM
bronx n.y
O
O
bronx n.y
kool thanks if u dont mind how much
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: one bad fish] #928141
02/13/11 11:03 PM
02/13/11 11:03 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
what shock did you take off the car? how did you set the afcos? what shock is on the front?
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: one bad fish] #928142
02/13/11 11:07 PM
02/13/11 11:07 PM
Roanoke Va
gearjammerdart Offline
Roanoke Va
We went from 1.30 with the old Afco double adjustables to 1.25 with the new Big Gun Afco shocks.
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: sixpackgut] #928143
02/13/11 11:28 PM
02/13/11 11:28 PM
P
PUNK Offline OP
PUNK  Offline OP
P
We removed the old Rancho shocks that were supplied by Calvert Racing for there monoleafs. The Ranchos are a good shock for the money, but when you have the $$ for real shocks, AFCOs are the way to go. As far as the front shocks are concerned, we happen to be running a single adjustable QA1 Stocker "R". We were told that the front shock for our application wasnt as critical as the rear and that our current front shock would most likely be adequate, so that is what will be on there for a while until they wear out. At that point we will spring for the AFCO single adjustable front shocks. Call Eric for $$ on your particular shock needs.
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928144
02/13/11 11:31 PM
02/13/11 11:31 PM
bronx n.y
O
O
bronx n.y
can u give me his #
Re: New AFCO shocks = New Best 60 foots and ETs. [Re: PUNK] #928145
02/14/11 12:52 AM
02/14/11 12:52 AM
SoCal
Brian Hafliger Offline
SoCal
Very cool Bryan especially since this is a TRUE STREET car. So does this mean you'll be at MATS this year? Contemplating going with some kind of engine...
Congrats on the new best!
Brian
Brian Hafliger
