Best method for isolating a noisy hydraulic lifter #927960
02/13/11 05:24 PM
02/13/11 05:24 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
For too long I've had a noisy hyd lifter in the old boat anchor (LA 318), and it's about time to swap it out. Seems to be coming from bank one, sounds like cyl 3 or 5.
What is your best method for picking out the faulty lifter? I have a full set of brand new lifters here I can choose from, but I'd rather be certain I find the culprit while I am in there. I do get some noise on cold starts, once it's warm it sings like a bird.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Best method for isolating a noisy hydraulic lifter [Re: GoodysGotaCuda] #927961
02/13/11 06:04 PM
02/13/11 06:04 PM
Kirkland, Washington
Pacnorthcuda Offline
Take off the valve cover. Have assistant fire the engine, quickly insert a .010 feeler gauge tween valve stem and rocker--when you do it to the collapsed lifter the clack clack will immediately stop.
Messy though!
I think you can fish lifters out with a magnet on a SB (I know you can on a BB) so changing them isn't much work.
Re: Best method for isolating a noisy hydraulic lifter [Re: GoodysGotaCuda] #927962
02/13/11 06:06 PM
02/13/11 06:06 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
I honestly don't know. But why the hesitation on replacing them all since you have full a set(of lifters)?
Re: Best method for isolating a noisy hydraulic lifter [Re: GoodysGotaCuda] #927963
02/13/11 06:27 PM
02/13/11 06:27 PM
While idling push straight down on each rocker arm w a wooden hammer handle on the pushrod end & it'll quiet the offender. Your psi is good right?
Re: Best method for isolating a noisy hydraulic lifter [Re: RapidRobert] #927964
02/13/11 06:43 PM
02/13/11 06:43 PM
PENNSYLVANIA
GARAGEMAN Offline
GARAGEMAN  Offline
PENNSYLVANIA
You wiil have the top apart.Change them all not that more money. Who knows you may change one and in a week you may have another one clacking.Then you got it to do all over again. thats my luck
Re: Best method for isolating a noisy hydraulic lifter [Re: GoodysGotaCuda] #927965
02/13/11 08:47 PM
02/13/11 08:47 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
First, check for any rockers that have alot of clearance between shaft and upper pivot area of rocker itself. There are many that have a fair amount of clearance when new, but there are also some that wear out. If the rockers are worn bad, it would be a waste of time and dough to replace lifters then. I have been known to replace a questionable lone noisy lifter with one out of a used box of goodies under the bench. You did say old 318 right?
Re: Best method for isolating a noisy hydraulic lifter [Re: Leadfoot] #927966
02/13/11 09:03 PM
02/13/11 09:03 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Fear of wiping the cam out really..
I'm in no hurry to do anything. If I change two at a time on that bank it's fine with me, assuming they can be fished out? I don't recall..or at most one bank at a time.
The motor has low oil pressure. Hot idle is 15, max hot is 40 (from 3000+). It's about had enough of me driving it, but the thing keeps on going. I'm looking to just keep it as is but lose the lifter noise. I have another short block here, but I really rather keep the 318 running until I'm through with it.
Thats the hesitation for all of them, tick is not worth the engine going south (..."right now")
2020 RAM 1500
Re: Best method for isolating a noisy hydraulic lifter [Re: GoodysGotaCuda] #927967
02/13/11 10:29 PM
02/13/11 10:29 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
I don't think you're going to be able to fish them out. Grab a wrench and a 12 pack. Once inside it's a lot easier to tell which one is clicking.
Re: Best method for isolating a noisy hydraulic lifter [Re: Leadfoot] #927968
02/13/11 10:48 PM
02/13/11 10:48 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Use an extendable Magnet. works great to get them out once the rocker shaft is out of the way.
I thought that I heard that its ok to switch to new lifters, just not old lifters on new cam?
Re: Best method for isolating a noisy hydraulic lifter [Re: wally426ci] #927969
02/13/11 11:16 PM
02/13/11 11:16 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Alright, I went ahead and pulled the intake . I have one that is downright dead. Another is pretty easy to give up.
I have four that I can move about an 1/8" just by pushing down on it. Figuring those should go as well, the motor last ran about 3 hours ago and they've let up that much. Yes?
2020 RAM 1500
Re: Best method for isolating a noisy hydraulic lifter [Re: GoodysGotaCuda] #927970
02/13/11 11:30 PM
02/13/11 11:30 PM
Any that you would replace you'd want to go thru the cam breakin procedure so If you're planning on doing all of them but only several at a time if I'm reading that right you might consider doing all of em at the same time & therefore 1 breakin & unless it's on it's last leg I'd toss in a Summitt cam along w em
Re: Best method for isolating a noisy hydraulic lifter [Re: RapidRobert] #927971
02/14/11 05:59 PM
02/14/11 05:59 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
After further review I'm going to go ahead and swap them all out.
Waiting on some intake gaskets, apparently nobody out here works on a LA Chrysler engine. According to parts store inventory.
2020 RAM 1500
Re: Best method for isolating a noisy hydraulic lifter [Re: GoodysGotaCuda] #927972
02/14/11 10:37 PM
02/14/11 10:37 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
It takes patience, but on LA you can actually swap them out by snaking them out the distributor hole with a magnet. Had just done new paint and detail on my motor and ended up changing out a whole set of new Comp lifters that failed immediately because the inside bores were too tight and the plungers stuck- all without pulling the intake
Re: Best method for isolating a noisy hydraulic lifter [Re: donbarnes] #927973
02/14/11 10:39 PM
02/14/11 10:39 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yeesh! That would be a pain alright!
Hopefully this is my last set of flat tappets for a little while. If I can ever get to my magnum 360 and my set of roller hyd lifters...it'd be nice (not to say they won't fail though)
2020 RAM 1500
