E body Rally dash tachometer #927855
02/13/11 02:38 PM
02/13/11 02:38 PM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
How can I know if my factory tach is accurate? How accurate are they usually?
Also, can the electronics be upgraded to work in conjunction with my MSD 6AL ignition? I have been using an Auto meter for the past 10 years, and I want to get back to a stock look, but make sure the factory tach is accurate.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: E body Rally dash tachometer [Re: 11secaarcuda] #927856
02/13/11 03:22 PM
02/13/11 03:22 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
MSD makes a electronic unit that is a go between the stock wire and the MSD 6L plug. It works fine on my same set up in my 71 B. The unit is small, a coup
Re: E body Rally dash tachometer [Re: 11secaarcuda] #927857
02/13/11 03:22 PM
02/13/11 03:22 PM
Pittsburgh, PA
Deuces-Wild Offline
Deuces-Wild  Offline
Pittsburgh, PA
To Connect your stock OEM Mopar tach to your MSD ignition box, MSD has a tach adapter that plugs into the Ignition box. (Part no 8910 or 8920) It converts the MSD signal for your stock OEM mopar tach.
A second option, there was a posting from a Moparts member, Mr Heaterbox, who was making new replacement circuit boards for OEM mopar tachs to work with MSD style ignitions. Search on this posting number: 5790084. Seems interesting but not sure how well it works.
Re: E body Rally dash tachometer [Re: DANA60] #927858
02/13/11 03:24 PM
02/13/11 03:24 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
sorry---couple inches square and easy to hide.
I'm not sure how accurate it is, it seems OK and maybe I should hook up a "real" tach to see. Keep in mind the original stock ones were probably off as well.
Re: E body Rally dash tachometer [Re: Deuces-Wild] #927859
02/13/11 03:45 PM
02/13/11 03:45 PM
Pittsburgh, PA
Deuces-Wild Offline
Deuces-Wild  Offline
Pittsburgh, PA
Pic for scale....
Re: E body Rally dash tachometer [Re: Deuces-Wild] #927860
02/13/11 04:58 PM
02/13/11 04:58 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And if the unit is going to be out where you can see it mopar performance has MSD's tach adapter unit rebadged for their offering...My rallye dash tach is accurate but the weight of the moving parts gives it a slow sweep....My 500hp 440-6 will rev up much faster{in neutral} than the tach can sweep when bliping the throttle...Definitely not the instant response of a new performance tach
Re: E body Rally dash tachometer [Re: 11secaarcuda] #927861
02/13/11 06:00 PM
02/13/11 06:00 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I tried the MSD tach adapter and my factory tach works....some of the time. It reads way higher other times. The cluster is well grounded.
I have since had Redline gauges rebuild my cluster including replacing the tach internals with modern VDO internals. There is no need to use the tach adapter with this setup, which is vastly more accurate. Let me know if you want my slightly used adapter.
Re: E body Rally dash tachometer [Re: DANA60] #927862
02/13/11 06:27 PM
02/13/11 06:27 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Seems like ALL original tachs read way high. While I can't prove it, it seems like this might have been intentional to try to keep people from blowing stuff up under the factory warranty. Just seems very odd that they never seem to read too low, always too high.
MB
Re: E body Rally dash tachometer [Re: Deuces-Wild] #927863
02/14/11 10:08 AM
02/14/11 10:08 AM
cataclysm80 Offline
cataclysm80  Offline
The MSD tach adapter works, but it makes a rapid tic-tic-tic sound while operating. I hid mine up under the dash, but I can still hear it if I don't have the radio on and the windows are rolled up. Kind of anoying.
I'd suggest trying one of the other methods.
Tav
Re: E body Rally dash tachometer [Re: cataclysm80] #927864
02/14/11 04:34 PM
02/14/11 04:34 PM
, PA
sleepyhead416 Offline
, PA
Change it over with a NEW kit. Do u clock while ur @ it.I did mine.
Re: E body Rally dash tachometer [Re: sleepyhead416] #927865
02/14/11 04:36 PM
02/14/11 04:36 PM
, PA
, PA
DASH WORX FROM RTE
Re: E body Rally dash tachometer [Re: 11secaarcuda] #927866
02/15/11 02:18 PM
02/15/11 02:18 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I would bet most any mopar factory tach is WAY off. You can sent the tach to Redline gauge works and have the internals replaced with a modern ( think he uses VDO)tach keepin the OEM face and pointer. Did this on my Challenger and Charger.
Re: E body Rally dash tachometer [Re: 11secaarcuda] #927867
02/15/11 02:26 PM
02/15/11 02:26 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My experience is they are WAAAAAY off... indicated my bone stock 340 'Cuda was turning close to 7000 RPM when it was probably hitting valve float more like 5800-6000.
Re: E body Rally dash tachometer [Re: BradH] #927868
02/15/11 04:36 PM
02/15/11 04:36 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Ditto on factory tach being off. Also, I tried a tach adapter and that too was unreliable.
I have had three rallye tachs upgraded to accomodate for a multple spark ignition system.
If you go this route, depending on who you use, you likely need to specify that you will be using a MSD type ignition. Otherwise, they may rebuild/recalibrate for a factory system.
I tried the tach adapter however, my tach was off so I didn't trust the information that
