Page 3 of 5 1 2 3 4 5
Re: Third generation Dakota's [Re: Sick 660r] #925065
02/11/11 05:43 PM
02/11/11 05:43 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
This is a customer truck I am doing. They like generation 3 as they are RT fanatics. Curious about drop spindles for this application. Don't like the lower control arm with the altered spring pocket because it changes the geometry in an unfavorable way. I'm hearing some big prices for the spindles though.
The other thing is lightweight lift off hoods that actually fit stock trucks. Pics of front frames as to answer where is it safe to cut weight. Just would like to see some ideas. Already got some plans just would like the added security of seeing what was done in the past.
It's not a backhalf 4-link or ladder bar. But, the framerails are very much modified with caltrac leafs and caltracs. An awesome set of shocks. Trimed down Dana 60 with some nice internals. Truck should turn out nice Holeshot Star wheels true 10.5's . I had nothing to do with the engine so we will just have to see how it runs.
Leon
I dont know of any drop spindles or lift off hoods.
I've seen lift off hoods on ebay made of carbon fiber before.
Re: Third generation Dakota's [Re: Leon441] #925066
02/11/11 05:44 PM
02/11/11 05:44 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
The column we have is a tilt wheel with shifter. I found a parts source that showed manual rack and pinion available for a 96-97 4 cylinder truck.
Just searched google. It was $129
96 and 97 are two completely different trucks. There were no manual racks for the 97 and newer. And the manual ones for 96 and older are hard to find, I'll bet what you found is out of stock or back ordered. I would look into chopping that second cross member out and fabbing a new one that uses a MII manual rack. The column should be easy, either convert to floor shift or find a 4cyl or V6 manual trans truck to pull one from.
Re: Third generation Dakota's [Re: Devilbrad] #925067
02/11/11 08:30 PM
02/11/11 08:30 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Following this thread with great interest. I'm still thinking about rodding my beater. I like the looks of the Gen 3s the best and am still thinking of ways to put mine on a diet.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Third generation Dakota's [Re: I_bleed_MOPAR] #925068
02/11/11 09:05 PM
02/11/11 09:05 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
You are absolutely right on the 96 to 97 deal I forgot my dad bought a 97 and Bought him a new one over some paint recall.
One place did say out of stock but the other was some parts depot that claimed to have one for $129.
I would not use a MII rack the mounting would be no improvement over the Dakota rack. Pinto is a better mounting IMO. I think there is a way to gut a PS rack and make it manual. Just never personally done it.
Re: Third generation Dakota's [Re: Leon441] #925069
02/11/11 09:20 PM
02/11/11 09:20 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
I've seen guys just plug the holes for the PS hoses on the rack. My idea for the MII was just to get a manual rack in there. You will need the correct width at the inner tie rod pivots to help correct/prevent bumpsteer. If you draw an imaginary line through the upper and lower control arm bushings, the inner tie rod pivot should fall on that line.
Re: Third generation Dakota's [Re: Leon441] #925070
02/11/11 09:47 PM
02/11/11 09:47 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
This is my 97. It's 2800 lbs, I have a 470 stroker in it. I'm partial to the gen 3s.
Re: Third generation Dakota's [Re: Leon441] #925071
02/11/11 09:56 PM
02/11/11 09:56 PM
southwest Alabama
southwest Alabama
OK, I have a hard time resizing and posting pics, I'll try again.
Re: Third generation Dakota's [Re: challenger73400] #925072
02/11/11 10:49 PM
02/11/11 10:49 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
What does it take to get that 3rd Gen down to that weight?
Re: Third generation Dakota's [Re: Quicksilver440] #925073
02/12/11 12:01 AM
02/12/11 12:01 AM
southwest Alabama
southwest Alabama
I built my own back half with 14GA 2"X3" tube. Remove all the interior and build a custom aluminum dash and a steering shaft kit, inter fenders, the extra crossbar up fwd, I made a aluminum bumper skeleton and installed a later model 1 piece bumper cover. 8-3/4 rear. Fiberglass hood. I could get it lighter, I still have all the glass in it but I don't want lexan.
Re: Third generation Dakota's [Re: challenger73400] #925074
02/12/11 12:28 AM
02/12/11 12:28 AM
Central Valley, CA.
Central Valley, CA.
Thanks for the run down....I may be looking to do something like that in the future.
Re: Third generation Dakota's [Re: challenger73400] #925075
02/12/11 01:00 AM
02/12/11 01:00 AM
Greenville, SC
bad360rt Offline
bad360rt  Offline
Greenville, SC
Did you put anything in it's place, or just remove it?
Re: Third generation Dakota's [Re: bad360rt] #925076
02/12/11 01:06 AM
02/12/11 01:06 AM
Canada
CrAzYMoPaRGuY Offline
Canada
^^^^^^^^STILL my favorite gen3 Dakota.....
CrAzYMoPaRGuY
Re: Third generation Dakota's [Re: Quicksilver440] #925077
02/12/11 01:22 AM
02/12/11 01:22 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
This is a start...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Third generation Dakota's [Re: challenger73400] #925078
02/12/11 02:43 AM
02/12/11 02:43 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Holy Cow!
That's L I G H T !
I'm thinking I would really like to lose 1,400# off mine. It just might help my 60' number. LOL
Re: Third generation Dakota's [Re: bad360rt] #925079
02/12/11 10:09 AM
02/12/11 10:09 AM
southwest Alabama
southwest Alabama
No, I just removed it, I see no need for it. It doesn't make the truck go faster and as far as safety, I have installed a 12 pt cage so it got the gas ax. Thanks!
Re: Third generation Dakota's [Re: Adobedude] #925080
02/12/11 10:16 AM
02/12/11 10:16 AM
southwest Alabama
southwest Alabama
This is a start...
Thats what I did, I even removed the metal dash frame. Here's a pic of mine.
Re: Third generation Dakota's [Re: challenger73400] #925081
02/12/11 11:00 AM
02/12/11 11:00 AM
Greenville, SC
bad360rt Offline
bad360rt  Offline
Greenville, SC
Cool, I've been thinking about cutting it out ever since I did my first engine swap and got a good look at it. Any idea how much it weighs?
Thanks!
Re: Third generation Dakota's [Re: POS Dakota] #925082
02/12/11 12:30 PM
02/12/11 12:30 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Its a shame to have the outside all pretty and stock looking and the inside stripped of it's beauty.
I love the style of the 3rd gen (Hense my 2000 Dakota) but they are so heavy. My 94 was 3280 with me in it (before the turbo and CM cage) with full interior, ac, ps, etc.
Re: Third generation Dakota's [Re: TheOtherDodge] #925083
02/12/11 12:38 PM
02/12/11 12:38 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Wow. Was your Gen 2 lightened any? Mine was 3450 without me, but it did have the big heavy billet wheels and a full stereo system with two 12" woofers. Absolutely no lightening at all on my truck.
Re: Third generation Dakota's [Re: TheOtherDodge] #925084
02/12/11 12:46 PM
02/12/11 12:46 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I agree, mine will look better when finished...
Did I say "finished"?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
