Installing 9 position keyway sprocket on crankshaft ???
#922287
02/06/11 02:24 PM
02/06/11 02:24 PM
Posts: 1,301 Penna
70satelliteguy
Penna
I am installing a new Rollmaster timing chain and sprocket(s) on my 440. It was not very easy to remove the old Rollmaster bottom sprocket off the crank. I had to tap it while turning the crank for quite a while before it finally worked loose and came off. Are these a press on type or should it go on and off fairly easy? How do you guys get these things on and off??? Thanks Mike
Re: Installing 9 position keyway sprocket on crankshaft ???
[Re: 70satelliteguy]
#922290
02/06/11 06:02 PM
02/06/11 06:02 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
You SHOULD need a puller to get the gear off if it and the crank are sized properly. You do not want a loose timing gear as it causes unnecessary harmonics and un-even loading on the crank snout. The cause of many snout failures, often blamed on something else.
You should have to tap it on slightly to install it, and need a puller to remove it.
RIP Monte Smith
#922292
02/06/11 06:04 PM
02/06/11 06:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks for the reply Andy!!! Do you mean a burr on the crank or the sprocket? How hard is it normally to get these things on and the crankshaft? I thought it would be pretty easy ! Mike
They normally slide on and off... no press at all... sometimes the snout of the crank can be a slight bit oversize and the gear could be undersized so the stack up COULD be at the max... could check the snout and gear with a mic or even a set of calipers to see where everything is at
#922293
02/06/11 06:05 PM
02/06/11 06:05 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Depending on the crank mfg, they can vary from a light slip fit to a slight press fit. I use a gear puller, which is the proper way to remove it, but you can also have some success "warming" the gear with a propane torch. Don't go crazy, just a little heat will get it done.
What Andy is referring to, I believe, is that there are burrs that form on the keyway slots of the gear that will cause some issues with fitment. You can dress those down with a small file.
FWIW, I'd rather have a gear that is a slightly tighter fit than loose.
MB
[Re: HPMike]
#922294
02/06/11 07:40 PM
02/06/11 07:40 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
MB
I heat the gear to about 250 degrees in the oven and it slides right on.
I use a puller to remove it.
