Challenger Photos with caltrack split mono leafsprings? #920264
02/03/11 01:57 PM
02/03/11 01:57 PM
SWEDEN
Mr500_wedge Offline OP
SWEDEN
I'm planning to order Mono split-leaf spring
anyone have some photos how the car (Challenger) sits with Caltrac split monosprings with stock height.
I don't want my car any higher, I like as it is. I have new extra heavy duty springs at the moment.
Thanks I advantage for the photos
Re: Challenger Photos with caltrack split mono leafsprings? [Re: Mr500_wedge] #920265
02/03/11 02:30 PM
02/03/11 02:30 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
photo in my sig is stock height with a 28 tire.
i used a +1 spring with a 30" tire
Re: Challenger Photos with caltrack split mono leafsprings? [Re: Mr500_wedge] #920266
02/03/11 02:35 PM
02/03/11 02:35 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Here's about the best pic I have of the car that shows the ride height. These were +1 but I had to re-arch them another inch for the wheel tyre combo we use.
From memory, your ride height above is a little lower than +1.
HTH's
Apologies for the moronic expression from the driver
Re: Challenger Photos with caltrack split mono leafsprings? [Re: Tig] #920267
02/03/11 02:51 PM
02/03/11 02:51 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Would you be interested in seeing a picture of an E-body Barracuda with stock ride height monoleafs?
295/65/15 Drag Radials w/ a B-body Dana.
Re: Challenger Photos with caltrack split mono leafsprings? [Re: Blues_Cuda] #920268
02/03/11 02:54 PM
02/03/11 02:54 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Same car with 275/60 ET Streets.
Re: Challenger Photos with caltrack split mono leafsprings? [Re: Blues_Cuda] #920269
02/03/11 02:56 PM
02/03/11 02:56 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
A better side profile shot with the 295/65's.
Car runs Cal-Trac monoleafs, bars, and Rancho 9-way shocks.
Re: Challenger Photos with caltrack split mono leafsprings? [Re: Blues_Cuda] #920270
02/03/11 02:58 PM
02/03/11 02:58 PM
an8sec70cuda Offline
Here's my 'cuda w/ stock ride height mono springs. 295-65 radial.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Challenger Photos with caltrack split mono leafsprings? [Re: an8sec70cuda] #920271
02/03/11 04:45 PM
02/03/11 04:45 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
My sig pic is stock height mono's with my 295/50/15 (26.5" tall) street tires. I also run 28x12.50 ET streets with no problems.
Re: Challenger Photos with caltrack split mono leafsprings? [Re: Mr500_wedge] #920272
02/04/11 01:21 PM
02/04/11 01:21 PM
SWEDEN
SWEDEN
Thanks all for the photos , so my ride height will not change that much when I change to mono springs
Re: Challenger Photos with caltrack split mono leafsprings? [Re: an8sec70cuda] #920273
02/04/11 01:54 PM
02/04/11 01:54 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Can you street drive it with those radials, and are they sticky?
Re: Challenger Photos with caltrack split mono leafsprings? [Re: Dragula] #920274
02/04/11 02:04 PM
02/04/11 02:04 PM
Yep, street drive on them all the time. They're the only tires I have for the car. They don't hook too great on the street on my car, but they do great at the track. I've tried several types of tires on this car and it does the best on the radials.
CHIP
