Headlight Door Shaft Length #919259
02/01/11 10:30 PM
02/01/11 10:30 PM
Backwoods of NC
Topher Offline OP
Topher  Offline OP
Backwoods of NC
What are the lengths of the shafts for the different years? 70, 71, 72, and so on?
Topher
topher@headlightmotorman.com
www.headlightmotorman.com
67 Charger 383 3 pedal car
[|||||||||o|||||||||]
Re: Headlight Door Shaft Length [Re: Topher] #919260
02/02/11 10:20 PM
02/02/11 10:20 PM
Backwoods of NC
Topher Offline OP
Topher  Offline OP
Backwoods of NC
Anyone?
Topher
Re: Headlight Door Shaft Length [Re: Topher] #919261
02/02/11 10:39 PM
02/02/11 10:39 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
What in the world is a headlight door shaft? And what car besides 68-70 Chargers had headlight doors? And no chargers in 71 72 or 73 had these doors....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Headlight Door Shaft Length [Re: Topher] #919262
02/02/11 10:42 PM
02/02/11 10:42 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Your going to have to be more specific then that.
What Vehical, There are probably multible length shafts for each. Even then, I dont think a answer will be readily available. I couldnt even tell you the length of my 68,69 and 70 chargers,from back in the day. mike
Re: Headlight Door Shaft Length [Re: HemiRick] #919263
02/03/11 02:09 AM
02/03/11 02:09 AM
Backwoods of NC
Topher Offline OP
Topher  Offline OP
Backwoods of NC
The shaft that goes through the headlight motor and raises and lowers the headlight doors on Chargers, Furys, New Yorkers and so on. 68-9 were vacuum actuated, 70 went to electric motors, and Yes, 71 Chargers had them. I've rebuilt motors for 72 and 73s also. So, what are the lengths for the shaft for 70 and up cars?
Topher
Re: Headlight Door Shaft Length [Re: Topher] #919264
02/03/11 03:07 PM
02/03/11 03:07 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Do you think the Imperial shaft would be the same width as a Charger?
- Stu Harmon
Re: Headlight Door Shaft Length [Re: feets] #919265
02/03/11 11:46 PM
02/03/11 11:46 PM
Backwoods of NC
Topher Offline OP
Topher  Offline OP
Backwoods of NC
Good question. Is there a demand for these shafts? I have a guy needing one for a 70 Charger. I have one that's 31" long. I'm looking into having them made and thought about the likliehood of there being different lengths.
Topher
Re: Headlight Door Shaft Length [Re: Topher] #919266
02/04/11 12:19 AM
02/04/11 12:19 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
You can look in a parts book. If they are different part #'s and don't superceed to newer numbers more than likely they are different lengths.....
Re: Headlight Door Shaft Length [Re: Topher] #919267
02/04/11 12:23 AM
02/04/11 12:23 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
[guote]
Topher, I've used ones from Chrysler C bodies, which were longer, and cut them down to fit 70 Chargers,....I also tried using cold rolled steel bar stock, didn't last long, you'll need the rods to have a spring steel temper, esp the 71-2 Charger set-ups, as the cast doors are heavy in comparison to the 70 Charger doors,...might I suggest a one length rod, that the customer cut down for their application, as the "square" shape/profile is all the same from what I've seen from B, to C, to R body concealed motor driven headlite doors
Mike
Re: Headlight Door Shaft Length [Re: DAYCLONA] #919268
02/04/11 09:41 AM
02/04/11 09:41 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I gave a motor and shaft to my kids friend for his Charger.Its still working after 15 years.I had probally 5 or 6 setups at one time.Rocky
Chrysler Firepower
Re: Headlight Door Shaft Length [Re: DAYCLONA] #919269
02/04/11 10:13 AM
02/04/11 10:13 AM
Backwoods of NC
Topher Offline OP
Topher  Offline OP
Backwoods of NC
Good idea on looking in a parts book Unfortunately I don't have any for these years. I do have a friend, Odzking, that's a parts number guru
I do like the idea of making it longer and allowing them to be cut to fit. How much longer are the C-body rods? 2"-3".
Topher
Re: Headlight Door Shaft Length [Re: Topher] #919270
02/04/11 12:15 PM
02/04/11 12:15 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Also, the 78-79 Magnums used the same setup, and maybe even the late 80's/early 90's Lebarons.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Headlight Door Shaft Length [Re: Magnumguy] #919271
02/26/11 02:05 PM
02/26/11 02:05 PM
Backwoods of NC
Topher Offline OP
Topher  Offline OP
Backwoods of NC
Does anyone have a headlight door they're not using? I need one for fitment purposes. Not real particular about the shape, or the year.
Topher
