Page 2 of 3 1 2 3
Re: 5.2 EFI swap into E body suggestions? [Re: Dragula] #918155
02/04/11 12:35 AM
02/04/11 12:35 AM
Canada
demon Offline OP
demon  Offline OP
Canada
Why not a FAST EZ efi?
I can buy a running Dakota for $500-$1500 and get every piece I need. All mopar and cheap
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918156
02/04/11 07:15 PM
02/04/11 07:15 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
As for the differences between the 500/518 case sizes, they're negligible. The overdrive section measures the same, and from that point forward you're talking the difference between a 904 and a 727. Both transmissions will require cutting the transmission cross member and welding a piece of fitted flat stock in its place. Make your decision based on the condition of the two, and intended use. Size matters not (obligatory Star Wars quote).
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918157
02/04/11 11:01 PM
02/04/11 11:01 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
I am beginning the same type of swap on a 68 fury 4door (why?) although I am not using the whole harness. I am going to splice the original harness with the underhood one from the Dakota. I have a friend with some experience in this, but he says there are only 5 or so wires to splice on OBD1. As for fuel system, I have a '71 tank in the car already so it has some vapor return ports. The LS1 corvettes use a fuel filter with a built in regulator, it has in, out and return, so I plan on using an inline pump. I was able to score a deal on a 95 dak with a 5.2 but a blown trans, but my car has a good 727 so I am going to use it for now. Sorry for the long post, but I thought I was the last one trying to do a EFI magnum swap!
Re: 5.2 EFI swap into E body suggestions? [Re: MarkZ] #918158
02/04/11 11:19 PM
02/04/11 11:19 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
actually, there was a post here years ago for E and '71 up B's that put a 518 in them WITHOUT cutting the t-bar xmember, but by trimming some of the ribs on the OD case....dunno if anyone has the pics saved anymore...
2017 Grand Cherokee Overland
Re: 5.2 EFI swap into E body suggestions? [Re: patrick] #918159
02/05/11 02:57 AM
02/05/11 02:57 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
A few of items to note:
1)The 92 5.2L was a return fuel system 40 psi with pump in the tank and a regulator on the fuel rail.93 up uses the returnless system with a bypass and pump in the tank.40 psi until 96.Switch the fuel rail to 93-95 type.
2)There is a very shallow Jeep tank that might bolt in.It has the pump and bypass in the tank.It will need to be modified slightly to fill it of course.
3)You can patch in the Magnum harness to the vehicle harness-8 wires
Leave the gun.......take the Cannoli's....Mike
Re: 5.2 EFI swap into E body suggestions? [Re: mike s] #918160
02/05/11 04:58 PM
02/05/11 04:58 PM
Canada
demon Offline OP
demon  Offline OP
Canada
right on! Thanks. That's some good info
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918161
02/05/11 07:44 PM
02/05/11 07:44 PM
Between Houston & Galveston TX
SattyNoCar Online happy
SattyNoCar  Online Happy
Nothing to add, just watching this post too as I want to do something similar with my 4dr Satellite. I don't need a drag-strip terror, just want a reliable driver.
John
Re: 5.2 EFI swap into E body suggestions? [Re: SattyNoCar] #918162
02/05/11 08:39 PM
02/05/11 08:39 PM
GA
roadrunninMark Offline
GA
Mark and Pat, thanks for the info on the trans differences and such. If anyone can find those older pic for shaving down the casing to make it fit, that would be excellent.
Also, is the gearing different between the two?
Re: 5.2 EFI swap into E body suggestions? [Re: roadrunninMark] #918163
02/07/11 12:05 PM
02/07/11 12:05 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
A500/42RH uses the low gear 904 setup: 2.74/1.54/1/.69 OD
A518/46RH uses the standard 727 setup, 2.45/1.45/1/.69 OD
I'm running a 42RH in my 5th ave. mark is switching from a 42RH to a 46RH.
Re: 5.2 EFI swap into E body suggestions? [Re: patrick] #918164
02/07/11 12:45 PM
02/07/11 12:45 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918165
02/11/11 02:01 AM
02/11/11 02:01 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Update on this car. Here is some progress pics of the harness. It is pretty easy to strip this harness down to what is not needed. It will use the ASD and Fuel Pump relay.
The three loops of wire are fo 12v feed, 12v run/ign feed, and 12 out to fuel pump (from relay)
Still need to finish wrapping it back up, and tie up a couple loose ends.
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 5.2 EFI swap into E body suggestions? [Re: wldtm] #918166
02/11/11 02:02 AM
02/11/11 02:02 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
another...
Re: 5.2 EFI swap into E body suggestions? [Re: wldtm] #918167
02/11/11 02:03 AM
02/11/11 02:03 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
one more...
Re: 5.2 EFI swap into E body suggestions? [Re: wldtm] #918168
02/27/11 08:47 PM
02/27/11 08:47 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Update on the Fury, engine out, trans notched, but I need a different converter. The one in the car had 11inch bolt spacing and I need one with 10 inch to fit inside the magnum flex plate. Should be bolted together in the next few weeks.
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918169
02/27/11 08:51 PM
02/27/11 08:51 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Here is the car its going in.
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918170
03/20/11 07:19 PM
03/20/11 07:19 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Update on the Fury, engine in, no problems there. Modified the gas pedal assembly to accept the dakota throttle cable, and the exhaust will have to be fabricated, but other than that no issues. Now for wiring and fuel system.
Re: 5.2 EFI swap into E body suggestions? [Re: ralphie361] #918171
03/20/11 07:36 PM
03/20/11 07:36 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Love your Fury. Great looking car!
The 5.2 looks like a natural in there.how about some details. Did you get the harness figured out?
Re: 5.2 EFI swap into E body suggestions? [Re: demon] #918172
03/20/11 09:20 PM
03/20/11 09:20 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Great info, I'll be watching this. I have a 40 Plymouth with a 92 Dakota drivetrain and harness on the back burner. Sure hope a MOD will bumpe this to the tech archive when it's done....
Re: 5.2 EFI swap into E body suggestions? [Re: RodStRace] #918173
03/20/11 09:46 PM
03/20/11 09:46 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
The harness should be installed by the end of this week (time allowing). Hopefully some pics will be taken. If you want to build your own harness PM me if you need some help or I have another one done for this swap if you want to purchase one. It will be nice to see how this first one goes. This should be a very nice driver, that anyone can drive and start without setting the choke. Looks good Ralph!
Re: 5.2 EFI swap into E body suggestions? [Re: wldtm] #918174
03/20/11 11:11 PM
03/20/11 11:11 PM
Andrewh Offline
Andrewh  Offline
did you swap out the column yet? or did you give up on that?
Page 2 of 3 1 2 3
