Aluminum fuel cell mounting pics #917510
01/30/11 08:37 PM
01/30/11 08:37 PM
Whitinsville Ma
superbee500 Offline OP
Whitinsville Ma
I am making some changes to my fuel system. I am thinking of moving my fuel pump ( Aeromotive A1000) to inside the trunk and upgrading from a plastic to an aluminum cell 15 to 20 gal.
I need some ideas for mounting bracket.
Kevin
69 superbee 04 ram 3500
Re: Aluminum fuel cell mounting pics [Re: superbee500] #917511
01/30/11 08:56 PM
01/30/11 08:56 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
not alum but you get the idea. [image]http://[/image]
Re: Aluminum fuel cell mounting pics [Re: superbee500] #917512
01/30/11 10:01 PM
01/30/11 10:01 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Nearly flush mounted and A1000 is in the tank...
Re: Aluminum fuel cell mounting pics [Re: Dragula] #917513
01/30/11 10:09 PM
01/30/11 10:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My preference
Re: Aluminum fuel cell mounting pics [Re: Al_Alguire] #917514
01/30/11 10:19 PM
01/30/11 10:19 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
the set up in my 69' Dart
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Aluminum fuel cell mounting pics [Re: Al_Alguire] #917515
01/30/11 10:28 PM
01/30/11 10:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My preference
Al, on my alum. cell it clearly stated that those tabs were for locating only and to use straps...........did yours say that?
Re: Aluminum fuel cell mounting pics [Re: Al_Alguire] #917516
01/30/11 10:46 PM
01/30/11 10:46 PM
Whitinsville Ma
Whitinsville Ma
My preference
That is what I was thinking of doing.
Did you have any problems not using straps?
Thank you for your replies everyone
Kevin
Re: Aluminum fuel cell mounting pics [Re: Thumperdart] #917517
01/30/11 10:47 PM
01/30/11 10:47 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
My cell is like Al's, but mine is bolted flat to the floor/ cross members with the sump and pump/filter below the floor. I purchased mine new and didn't see any info about not using those tabs for mounting. Never had a tech problem either. I think there suprised to see such a nice looking set up in a pos car. If the cell was mounted flat or on pedestals without strain on the tabs there would not be a problem. I've had mine going on 6 years and my car gets used 100's of runs per year.
Re: Aluminum fuel cell mounting pics [Re: rowin4] #917518
01/31/11 01:55 AM
01/31/11 01:55 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I never had an issue with mine. We actually welded those tabd to the cell. Also the photo does not show the structure below the cell. It has a complete "frame" under it that it mounts to. It is still in the Valiant.
Re: Aluminum fuel cell mounting pics [Re: Al_Alguire] #917519
01/31/11 04:45 AM
01/31/11 04:45 AM
Oh
His and Her 69's Offline
Oh
Mine is like Al's except my spacer blocks are the same size as the tabs. The blocks make the tank sit high enough so the sump area doesn't hit the stock floorpan. Been that way for years in street/strip use and no additional framework under it. 10.90 car.
David
Re: Aluminum fuel cell mounting pics [Re: Randy..] #917520
01/31/11 04:52 AM
01/31/11 04:52 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Is that a Jaz cell? I had one in my 66 Toronado - did yours sag over time?
Ride eternal, shiny and chrome
Re: Aluminum fuel cell mounting pics [Re: DirectSubjection] #917521
01/31/11 08:08 AM
01/31/11 08:08 AM
Dragula Offline
Dragula  Offline
Sounds more like a personal problem...
Re: Aluminum fuel cell mounting pics [Re: superbee500] #917522
01/31/11 08:33 AM
01/31/11 08:33 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Here's one
Re: Aluminum fuel cell mounting pics [Re: formula S] #917523
01/31/11 08:36 AM
01/31/11 08:36 AM
San Diego
formula S Offline
formula S  Offline
San Diego
#2
Re: Aluminum fuel cell mounting pics [Re: rowin4] #917524
01/31/11 08:53 AM
01/31/11 08:53 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Here I mine
Re: Aluminum fuel cell mounting pics [Re: superbee500] #917525
01/31/11 09:45 AM
01/31/11 09:45 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Re: Aluminum fuel cell mounting pics [Re: formula S] #917526
01/31/11 11:28 AM
01/31/11 11:28 AM
San Diego
formula S Offline
formula S  Offline
San Diego
#3
Re: Aluminum fuel cell mounting pics [Re: formula S] #917527
01/31/11 11:29 AM
01/31/11 11:29 AM
San Diego
formula S Offline
formula S  Offline
San Diego
#4
Re: Aluminum fuel cell mounting pics [Re: jughed] #917528
01/31/11 11:41 AM
01/31/11 11:41 AM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Re: Aluminum fuel cell mounting pics [Re: PolyDart] #917529
01/31/11 01:03 PM
01/31/11 01:03 PM
Bolingbrook, IL
HemiRunner Offline
super street
HemiRunner  Offline
super street
Bolingbrook, IL
Here is the way I have mine set up.
Blown & Injected, need I say more? 71 Road Runner 04 Dodge Ram 2500 4x4 CTD
